Old 05-13-2011, 06:16 AM   #31
andrewdoherty's Avatar
Trader Rating: 47 (100%+)
I had a TC5 for a bit and oprdered one HB DCJ not realizing they came one to a package. I have since sold the TC%, but still have the brand new DCJ. If anyone's interested make me an offer. I need this out of my hair!
Old 05-13-2011, 08:27 AM   #32
Verndog's Avatar
Trader Rating: 16 (100%+)
I'll be needing a backup you have a PM.
--->Dial-a-Grip for TC6
Kevin -- PPDBillet---TC6---Exoray 008
---Team Hoarders---
Verndog is offline   Reply With Quote
Old 05-13-2011, 09:53 AM   #33
JayBee's Avatar
Trader Rating: 31 (100%+)
Hey Kev, send me a PM w/all the parts needed (including spares), so I can have you do this mod for me
R C 3 G R A F I X _ F U S I O N . G R A P H I X _ S E A T T L E - R/C - R A C E R S _ E M E R A L D C I T Y R C . C O M
A E - 12R5.2 _ S M - REV8 PRO
JayBee is offline   Reply With Quote
Old 05-23-2011, 12:27 PM   #34
Originally Posted by Verndog View Post
Here is what you need to convert the Hot Bodies DCJ driveshafts to fit the TC5 / TC6
Tools: Dremel with 1/8 rotary file - #40 .098 dia. drill bit - 1.5 and 2.0 mm hex drivers and wheel wrench.
Parts: Hot Bodies DCJ 67699 drive shafts - Hot Bodies HB70742 5mm wheel hex's (comes with 4 hex's, pins and screws) - CRC CLN 4741 5mm shims - stock TC6 blades - (4) 3 x 5 x 10 mm wheel bearings.
Hi.
Are you sure about the bearing dimensions?. Hot Bodies TC bearings are 4mm thick, the same as TC5. Shouldn´t they be 4x5x10?.
Regards.
Nitroblood is offline   Reply With Quote
Old 05-23-2011, 12:52 PM   #35
Verndog's Avatar
Originally Posted by Nitroblood View Post
Hi.
Regards.
Positive. If you have an older TC5 manual there is a misprint on the bearing size. It's 3 x 6 x 10....I've bought and run plenty. The Hot bodies thickness doesn't matter as that is dependent on the hub bore depth from each manufacturer.
---Team Hoarders---
Old 06-02-2011, 04:06 PM   #36
Hi again.
The Hot Bodies DCJ drive shafts came already assembled. Do you need to apply grease inside them?.
Is it recommended to wrap the joint?. I´ve seen people doing this with Xray or Arrowmax shafts, but these ones seem to be more protected.
Thanks.
Old 06-02-2011, 04:16 PM   #37
Verndog's Avatar
It's always a good idea to grease or oil moving parts anywhere there is friction, so yes. I'd clean and check and lube them after each race day as well. Don't have to overdo it, just enough to keep them smooth and reduce friction. Personally I like the Associated black grease on mine...but your right they seem to be better protected.
Hi again.
Thanks.
---Team Hoarders---
Old 01-12-2012, 12:08 PM   #38
tr1kstanc3's Avatar
Trader Rating: 18 (100%+)
Any updates on how these have been holding up? Just ordered myself a pair to play with.
tr1kstanc3 is offline   Reply With Quote
Old 01-12-2012, 06:46 PM   #39
Logi Maker's Avatar
Trader Rating: 49 (100%+)
http://www.rctech.net/forum/electric...ns-etc-45.html
Problem will solved shortly....
www.Reflexracing.net
Kyle Predmore
FB AE Fanboy/Insta @ae_fanboy
Sticky Kicks RC\MIP\JConcepts\Schelle\ProlevelRC
Logi Maker is offline   Reply With Quote
Old 02-13-2012, 09:23 PM   #40
Jochim_18's Avatar
Just ordered mine too today and the bearing..
Localrcracing.com - Your premiere source of Radio controlled Racing in central California.
Visaliahobbies.com * SkyRC * casterracingparts.com
Old 02-14-2012, 07:07 AM   #41
Any body tried specr-V2 (for BD-5) in TC5 or TC6 ?
Need any mod on C-hub?
mos-leung is offline   Reply With Quote
