Old 04-27-2011, 09:02 AM   #1
Robudda723's Avatar
Trader Rating: 24 (100%+)
Default TC3 FDR Help
Trying my hand in on road and have picked up a TC3. I am running a 17.5 Brushless. The GT Sedan class I am running in has a 3.5 FDR rule. However the instructions for that car do not show a Brushless system. Any recommendations on the spur and pinion to come up with the 3.5 FDR with a 17.5 Brushless system? And what is the proper math to get the FDRs for the TC3?
Thanks,
Rob
Robudda723 is offline   Reply With Quote
Old 04-27-2011, 09:24 AM   #2
We are running a FDR of 3.75 for VTA with 74 spur and 50 pinion in 64 pitch, with no modifications to the chassis.
2SiX is offline   Reply With Quote
Old 04-27-2011, 09:52 AM   #3
Thanks,
Rob
Can't guarentee you can reach your FDR without a slight mod to the chassis in order to make room for larger pinions but try it first and then do the mod if needed. FDR is simple. internal drive ratio of the tc3 is 2.5 if i remember correctly.
So...spur tooth count / pinion tooth count = ? then ? x 2.5 = FDR
EX: 72 / 40 = 1.8 then 1.8 x 2.5 = 4.5 FDR.
www.gearchart.com. should help.
Evoracer is offline   Reply With Quote
Old 04-27-2011, 09:57 AM   #4
Robudda723's Avatar
Awsome Guys, Thanks for the info. I will use that as a starting point. And adjust from there.
Rob
TC3 Forum Lowrider Electric On-Road 12196 10-13-2017 09:47 PM
TC3 17.5 GEARING haywood Electric On-Road 11 02-24-2009 08:08 PM
Pinion question on a TC3 with a mamba 5700....HELP! smarking1212 Electric On-Road 8 04-19-2008 03:10 PM
TC3 Gone Brushless, now what? DraKhen99 Electric On-Road 13 12-12-2003 04:39 PM
