Old 04-27-2011, 03:40 AM   #1
wollow86's Avatar
Default mi1 question
So I've seen a conversion of a Schumacher Mi1 on CS Junkies, where a user has modified his mi1 to use a twin lay shaft pulley system instead of the stock single lay shaft, twin 36t rear diff gears, with a belt from the lay shaft to diff, then diff to front, to now use two lay shaft pulleys and a custom belt to the front diff pulley.
He's done so to be able to play with diff gear ratios to achieve a 76% counter steer ratio. My question, is that would such a conversion have any benefit to on road TC if the ratio was left to 50/50? Would there be any gain in the drive train efficiency or reliability? Or would this conversion only be helpful for CS drifting?
Supporting Aussie hobby shops:
- www.MRJRacing.com.au - - www.feralbatteries.com.au - - www.actionrc.com.au -
wollow86 is offline   Reply With Quote
Old 04-27-2011, 10:09 AM   #2
Trader Rating: 24 (100%+)
Not likely. CS and variable diff ratios are 2 different things. CS is a stering function. Drifters need more throw on the steering to counter the drift angle.
Varying the diff ratios by way of altering diff gear tooth counts refers to underdrive or overdrive. I've tried it on my XXXS and found it to be little help and at my skill level and the classes I run.... hardly worth it. The pros may use it as a tool but I can't imagine you or I would get much out of it.
Evoracer is offline   Reply With Quote
Old 04-28-2011, 06:52 AM   #3
wollow86's Avatar
Thanks for the clarification. Wouldnt be using it for any underdrive or overdrive during on road tc, was more thinking from a drive train load perspective, that perhaps it would be more efficient then the current stock setup.
Schumacher Mi1 colmo Electric On-Road 349 11-20-2017 06:26 PM
Motor Question? WRXTC Electric On-Road 45 08-06-2005 02:01 PM
