Old 04-25-2011, 08:18 AM   #1
XXX8ight's Avatar
Trader Rating: 47 (98%+)
Default Trinity Motor issues....
I am having issues advancing the timing on my D3. This is the second motor i have tried to do this on and have been unsucessful both times. I loosen the 3 screws that are on the endbell (where the solder tabs are) and i cant get the endbell to turn. I tried to rotate the center (where the screws are) and the outside (where the ticks are) and it seems they just wont move.
I even tried loosening all the screws.
Apparently i am doing something wrong. Please help.
Tekno, Proline, and REX Novarossi Team Driver
XXX8ight is offline   Reply With Quote
Old 04-25-2011, 09:26 AM   #2
Fuzzy's Avatar
I purchased one of the very first D3's that came out and I had the same issue. I had to remove the three screws and the timing cover completely. Now being able to see what was happening, I placed my hex wrench through the screw hole in the timing ring and with some firm force got the ring to move. Once I had it where I wanted it, I replaced the cover and screws. It's a pain in the a** and I hope that the newer versions have been corrected.
Fuzzy is offline   Reply With Quote
Old 04-25-2011, 09:36 AM   #3
Team EAM
EAMotorsports's Avatar
Trader Rating: 79 (100%+)
Send a message via AIM to EAMotorsports
Its from a little to much anodizing on the ring or from over tightening the three long screws that hold the motor together. You may have to loosen those three screws along with the timing plate screws. I usually will leave the wrench in the timing screw and use that to turn it. It will turn but takes a little effort. If you have the plate all the way off you can also lightly sand it on the edge and it will spin freely then.
EA
Contact Us
Team EAM, Our Facebook
Team EAM | Xray | RCAmerica | Hudy | APEX Raceway and Hobbies | RC Mission | Killer Concepts | AVID | Hobbywing.
EAMotorsports is offline   Reply With Quote
Old 04-25-2011, 09:41 AM   #4
XXX8ight's Avatar
so its the ring that turns? or the center?
Old 04-25-2011, 09:45 AM   #5
303slowdown's Avatar
Trader Rating: 24 (100%+)
its the center that turns
Ryan Borgheiinck
303slowdown is offline   Reply With Quote
Old 09-21-2011, 03:58 AM   #6
CFR
CFR's Avatar
mine was the same
remind me which way the timing insert moves for more revs please, left or right when looking at the zero
CFR is offline   Reply With Quote
Old 11-10-2011, 01:14 PM   #7
Dog Bone's Avatar
Just thought I would chime in and offer a solution - I recently purchased a 13.5t D3, and had the same issue - the only way to adjust the timing was to take off the end bell and make the adjustment. The center ring would not turn at all. A real PITA.
I took the motor apart, and used 600 w/d sandpaper on the edge of the center plate to take it down just a hair until it would rotate freely in the motor end plate. Did that, put it back together, and *poof*, I can adjust timing now without any issues.
The amount I took off was *very* small, and it only took a few minutes. If you do this, just make sure you do it evenly. I held on to the plate, and dragged/rotated it across the sandpaper. Rotate the plate, and do it again. Went around the plate about 3-4 times, checking the fit. You'll know when you get there, as it will turn smoothly once you remove enough material.
Ken Miller
T4 2015
CRC Twenty5
Dog Bone is offline   Reply With Quote
Old 11-10-2011, 04:18 PM   #8
TeamWTF's Avatar
Originally Posted by CFR View Post
mine was the same
anti-clockwise for more timing
T.O.P. Racing Australia www.topracing.net.au
TeamWTF is offline   Reply With Quote
Trinity EXTECH .21 Fierle03 Offroad Nitro Engine Forum 2130 06-09-2011 08:01 AM
2 - ESC motor combos for slae. Sensored and non!! TRAXXAS Velineon and LRP marooko R/C Items: For Sale/Trade 22 01-25-2011 09:21 AM
Brushless Myths from Trinity Coxy Electric On-Road 96 09-04-2006 01:38 PM
