Japan 1/12th Nationals >
Old 09-19-2004, 04:36 AM
  #16
corallyman's Avatar
Trader Rating: 101 (100%+)
Default Hara's car
Oscar,
Is there any chance of you posting a picture of Hara's car. I was able to talk to him in Portland at the roar nats and look at his previous car. I would really like to see the difference between the two versions. Can you share any differences in the Orion v2 motors between a touring car setup and a 1/12 motor setup? Are you using a different arm styles?
Thanks,
Steve
corallyman is offline
Old 09-19-2004, 05:00 AM
  #17
kentech's Avatar
Default Japan 1/12th Nationals coverage
http://www.kimihiko-yano.net/
http://www.jmrca.com/2004all_japan/1...cing_main.html
kentech is offline
Old 09-19-2004, 05:19 AM
  #18
Anders Myrberg's Avatar
Kenneth Södergård Aka Kentech; Without doubt, King of links!
Anders Myrberg is offline
Old 09-19-2004, 09:56 AM
  #19
PizzaDude's Avatar
Originally posted by Oscar Jansen
Masami is testing and using here the new small KO Propo speedcontroller, this in preperation for the Worlds. Lets see what he will choose there.
Oscar
Oscar dude,
Isn't Masami running GM speedos any more?
Regards,
Pizza
PizzaDude is offline
Old 09-19-2004, 12:09 PM
  #20
kentech's Avatar
What?
Glad if I can help.
kentech is offline
Old 09-19-2004, 12:56 PM
  #21
MarkA's Avatar
Trader Rating: 21 (100%+)
The suntan lotion has created quit an astonishment to some I read. Will explain a bit more how it is used here: First FX2 is soaked on the tires, for about 10 minutes. Than lots of suntan lotion, which is rubbed in for a few minutes. About 30 minutes before the start the tires are very carefully dried with a towel, to have them sticky dry before the run. I questioned here drivers why it gives more traction, but they say they do not really know. They are only sure that it gives more traction.
Functionally speaking, the suntan lotion is being used to seal the first coating of sauce in, thus making it last longer and act like more of it was applied - very useful in a 8 minute race.
Suntan lotion by itself actually produces less bite than most conventional tire sauces. I personally use it if I ever need to free up/loosen up my car.
Originally posted by jkerr0043
Interesting. Not that we ever see pan cars here in Southern Cali ever.
Hey...
MarkA is offline
Old 09-19-2004, 02:21 PM
  #22
OVA
OVA's Avatar
Trader Rating: 86 (100%+)
Originally posted by Sushi Boy
Yeah, suntan lotion is a common thing with pan cars on asphalt. Weird huh?
-Korey
I remenber three ago .canadian racer were useing the suntan lotion on foam tires in F-1 class
OVA is offline
Old 09-19-2004, 03:31 PM
  #23
TRF_SPAIN's Avatar
I always heard about using sun tan lotion for foams in outdoor...i think that was Josh Cyrul who posted it on his thread...but i always asked myself if any sun tan lotion its ok...or must be an especific brand because of his chemical components....
TRF_SPAIN is offline
Old 09-19-2004, 05:43 PM
  #24
MarkA's Avatar
I think any brand will “work” but I’ve found Coppertone specifically to be the most consistent from bottle to bottle.
Of course, it tends to cost the most also.
MarkA is offline
Old 09-19-2004, 06:10 PM
  #25
Suntan lotion actually helps keep the tires clean. If you were to use just Paragon the tires would pick up every dust partical on the track and the car would be impossible to drive. The lotion allow the dust to fly off while the compound stays in.
Adam Hartzell is offline
Old 09-19-2004, 06:22 PM
  #26
Registered User
Pyramid's Avatar
Originally posted by PizzaDude
Oscar dude,
Regards,
Pizza
Looks like KO paid him more
BTW, those small KO spedos has been out (named VFS1, I believe it is not prototype).
Pyramid is offline
Old 09-19-2004, 08:10 PM
  #27
Ohio Gozaimades from Japan.
First final just done. Masami, Kimura, Hara. Hara led Masami for 7.30, but used too much juice.
More later....
Oscar Jansen is offline
Old 09-19-2004, 08:26 PM
  #28
Okay, questions and answers first:
@ Anders: Thanks for helping me with my report. Like mentioned Masami is far far far away. Yoshioka is not racing.
@ Corallyman: I have no pics of Hara`s car, but I advice to look at some Japanese sites. Have seen many of them making pics here.
In regards to motors settings:
1/12th
9 or 10 turn double modified type, softest springs, edge sprint brush. Timing 3-4 mm. Around 37mm/rev for 9, 41mm/rev for 10 turn.
TC
7 or 8 single modified type, extra hard springs, edge sprint brush, timing 1-2mm. About 9.5 ratio for 7, 9.0 for 8 turn.
I advice now to choose for Modified type armature-motor in case of no motor limits. Touring car type motor-armature in case of 10 or 12 turn motor limit. This advice due to the latest increase of battery power.
@ Pizza: Dude, I know now here he is using KO speedo, no idea what happened with the GM one.
@Pyramid: Masami will and has never change for money.... just a note in addition. If else he would have been driving Monster stuff already for ages
Old 09-19-2004, 08:54 PM
  #29
fatdoggy's Avatar
Just a note, Calafornia baby spf 30+ sunblock sticks work great on foams if the asphult is clean. They are expencive though...
fatdoggy is offline
Old 09-19-2004, 08:56 PM
  #30
More news:
Cars in A final:
6 Associated 12L4, 1 Hara, 1 Kawada, 1 Tech, 1 Xenon.
5 of 6 Associated drivers are sponsored by Yokomo, 1 privateer.
Car is almost standard, some L3 Yokomo parts are used.
Drivers
Kimura is driving first time 1/12th, but was off road regular A finalist at Japan nationals. 3 more new driver in a final compared to last year. Itoh, one of Japan super talents, did not make this year, he ended up in the B. He mentioned he could not find a good balance in the car.
Batteries
All A finalists use Sanyo 3600.
Manufacturers on site for assistance: Echo, Futaba, Hot Bodies,[email protected], Kawada, Ko Propo, Peak, Sanwa, Team Luna, Team Orion, TN Racing, Xenon, Yokomo.
