Futaba 3PJS Radio Help >
Old 09-18-2004, 07:23 PM
JDXray's Avatar
Default Futaba 3PJS Radio Help
Need alittle help with my new Futaba 3PJS. I want to change the sensitivity on my steering, its very sensitive right now, and i want to change that, i got use to it but would like to change it. Would someone please help me.
-Jon
JDXray is offline
Old 09-18-2004, 08:01 PM
Joel Lagace's Avatar
Try adjusting the exponetial into the negative.
EXP+-
What this will do is soften the responce at the near neutral points.
Joel Lagace is offline
Old 09-18-2004, 08:09 PM
JDXray's Avatar
Okay i will give it a try, thanks.
JDXray is offline
Old 09-18-2004, 10:02 PM
Trader Rating: 14 (100%+)
Hi,
you might want to try slowing down the servo speed also.
TimXLB is offline
Old 09-19-2004, 07:03 AM
JDXray's Avatar
But why slow down the speed of the servo when you need speed to make those turns. i am confused
JDXray is offline
Old 09-19-2004, 07:42 AM
Brandon Melton's Avatar
Joel is right, use the EXP. It won't slow your overall speed, but will make it less reactive when you first turn the wheel if you are using to much of a speratic input. If you feel the car is too "sharp" for your control, you can decrease the "dual rate" which is noted by DR on the front screen.
Brandon Melton is offline
Old 09-19-2004, 07:48 AM
JDXray's Avatar
Thanks Brandon, so all i do is change that dual rate with the scroller thats right at my thumb, thanks.
-Jon
JDXray is offline
Old 09-19-2004, 07:58 AM
The EXP will only change the resoponce os the servo, the speed stays the same, Picture a diagnal line on a 45degree angle. Then make it curve up or down, that is what is happening to the steering responce. The 3PK actually shows this as a graph when u make the EXP adjustments
The DUAL RATE on the thumb wheel is only going to limit your steering throw. It simultaniously reduce max through of left and right at the same time. So from 100% steering throw down to 0% as you adjust the wheel. IT will not likely take the twitchy ness out of your steering but it will take out some steering if your over cranking the wheel in the corners and find your oversteering. ITs handy if you can control your wrist!
