Siezed Xray bearings >
Old 09-17-2004, 11:31 PM
Default Siezed Xray bearings
Is anyone having problems with their layshaft bearings.
I had one seize up on me last week while racing, Replaced it with a new one from Xray, took the car out to test this morning and the other one seized up , i have also replaced the layshaft. Any help regarding this matter would be most welcome
myk505 is offline
Old 09-17-2004, 11:55 PM
Are you running a spool or oneway?
NismoSkyline17 is offline
Old 09-18-2004, 12:01 AM
Oasis's Avatar
Trader Rating: 38 (100%+)
You do have to stay on top of the maintaince of the layshaft bearings,Alot of RPM's and the bearings are small and they do have a load on them.I have burned up a few..
Oasis is offline
Old 09-18-2004, 12:03 AM
And I have found the spool for some reason is hard on them too.
Old 09-18-2004, 01:38 AM
I am running a stock spool that came with the kit, the new bearing i put with the new lay shaft, did not last 2 mins run time.
myk505 is offline
Old 09-18-2004, 05:26 AM
JDXray's Avatar
That little bearing takes a beating. Mine have probably gone bad already jsut havent really cared. If the car is still running good then i will leave it in, but i have noticed is that the bearing seal (blue thing that goes aroudn the bearing) likes to come off.
-JD
JDXray is offline
