Old TC Cars - Still Racing Competitively
#1036
I ran the(my) HPI Pro 4 and Tamiya Evolution 5 with Ni-MH and Li-Po batteries installed at my Fastest-Lap Challenge.
Pro 4 Fastest-Lap with Li-Po 5800mah 110c: 30.05
- - - - - - - - - - - - - - - - - - - with Ni-MH 3600mah: 31.53 (charged with a 4.3amp rate for 15-minutes; later with a regular charge)
Evolution 5 Fastest-Lap with Li-Po 5800mah 110c: 31.91
- - - - - - - - - - - - - - - - - - - - -with Ni-MH 3600mah: 32.56 (charged with a 4.3amp rate for 15-minutes; later with a regular charge)
I had to add some weight on the battery side on both chassis.
(I like the Ni-MH Batteries!)
#1037
For 48 pitch, either 55/35 or 60/38. Robinson for the spurs, pinions will be aluminum above 35T.
#1038
The lowest I've gone in FDR in my TC3 was 3.2 using 52/41 (48p)
#1040
You can go 49t spur with 41t pinion for 2.98fdr in a tc3, but there will not be much gearing flexibility and not much infield punch either.....
#1041
Hey bertrandsv87.
The Ni-MH battery I run/use is the Duratrax 3600mah (they run strong with a higher charge rate. . . . . . .so-far).
(I charge my Ni-MH batteries with the Graupner EX1400. . . . . . .my son charged my Li-Po batteries with the HiTec X1 Pro)
I added weight (11 grams - front and rear) to the chassis when the Li-Po batteries were installed until I had the ride height (6mm); compared to when Ni-MH batteries are installed.
I haven't weighed the Tamiya Evolution 5 or HPI Pro 4; with all electronics.
#1042
The duratrax 3600mah are perfect for nitro starter box, but can't come close to competing with Smc 4600mah Energ cells with side by side configuration and charged/discharged individually.....Too bad they don't make them anymore....
#1045
Here you go, a 2010 Sakura with cheap electronics winning against a fully loaded BD8.
Porsha driving a cheap 8 year old Sakura Zero (2010) wins and beats Yokomo BD8 2018, Xray 2018, Awesomatix 2018 and Team Magic. She is driving the white Protoform LTCR that has been in use since 2011. She ran cheap motor (surpass 17.5 @ $30) cheap esc (Tsky @ $15), and cheap servo (bluebird @ $20).
#1047
Nice video, but what would happen if you instead had the best electronics/motor/battery in a cheap chassis ???
#1049
No point running a cheap chassis if the servo alone is more expensive than the chassis. Upgrade! hahaha
#1050
The gap will lessen, but will not really equal a modern car that is much lighter (and can put weights where needed for better balance) and stiffer parts. Xray diff is 17grms, no old cheap car can overcome that.
