Old 04-19-2011, 07:54 PM   #1
dennisnielsen's Avatar
Default Newbie battery tech question
So I am interested in 3cell top fuel electric.
I have a drag race concepts rail on the way
a novak BALLISTIC 3.5T/10500KV motor
13mm SINTERED TUNNING ROTOR swap
Mamba Max speed pro
My question......
What 3cell LiPo should I go with??????
Also....Charger.
Looking at the TP610C AC/DC
Thoughts?
I was thinking a Thunder Power G6 "Pro Race" 3S Hard Case Li-Poly Battery w/Deans Connector 65C (11.1V/5300mAh)
[THP5300-3SPR65D]
Or
Thunder Power G4 Pro Race 50C Series LiPo TP5200-3SPR50 5200mAh 3-Cell/3S 11.1V
Any thoughts?????
dennisnielsen is offline   Reply With Quote
Old 04-20-2011, 06:23 AM   #2
StarrRacing's Avatar
In my opinion....
1. The charger looks good, charges up to 10 amps, should work good.
2. I would think that for Drag Racing, short runs, and wanting to get
power to the ground.... A.S.A.P.
You could use a battery with a lower Mah (run time), but as much PUNCH
(meaning "C" Rating) as you can get. So you could most likely save on
some cost by going for a lower Mah, But, get the largest C Rating you
can find.
I could be wrong on the battery theory.... so, wait for some other guys
to chime in....
Jeff Starr
U.S. Coast Guard (Retired)
Traxxas 4x4 (x2), Associated SC10,
XRay T3 '009 (VTA), XRay T3 '10 (USGT), Tamiya M05 (Mini),
Tekin, Spektrum.
StarrRacing is offline   Reply With Quote
Old 04-20-2011, 06:32 AM   #3
Thank you!
Old 04-20-2011, 06:55 AM   #4
I don't think it will work.
10500rev/V and 11.1V equals more than 100'000revs/min. You will immediatly destroy the bearings and the rotor.
7.4V is more than enough for a 3.5 motor.
Der Dicke is offline   Reply With Quote
Old 04-20-2011, 07:23 AM   #5
WHAT???
Old 04-20-2011, 11:48 AM   #6
Talked to Jim Skinner of Thunder Power
he said go with the THP4300 3S 65C
11.1 Volt
Not ava until late May at Horizon Hobby
Back order everywhere
Thunder Power is building it as I type this
ETA...a few days shipped UPS
The charger too.
why are we still running sub-c cells?? trackpower Electric On-Road 310 12-27-2007 09:48 PM
Lipos vs NiMH......Nicads....Alkalines Ducati-Rider Electric On-Road 38 04-12-2006 07:55 AM
