Old 04-18-2011, 04:45 PM   #1
theatriks's Avatar
Default Motor seized!! Off LHS advice
Hey guys so the guys at the local hobby shop told me to spray my silver can with hpi motor cleaner and then oil the stone shaped piece in the motor and it will help the motor last longer and i would notice an improvement in performance....so i did that and now the motor is seized ... wtf!! was there advice wrong ...did i do something wrong?
theatriks is offline   Reply With Quote
Old 04-18-2011, 04:52 PM   #2
AUSSIE BOB's Avatar
Default right
I would say you received the correct advice, however,....maybe your application of that advice was not carried out correctly. After the spray of the motor which should be OUT of the car, wipe over with a cloth and then the brass bearings (Stone thingos) are oiled with one drop of oil each, maybe you used a gallon, seek help with someone at the track.
AUSSIE BOB
AUSSIE BOB is offline   Reply With Quote
Old 04-18-2011, 05:01 PM   #3
theatriks's Avatar
Thats exactly what i did and i dont think i over oiled them it was a drop i put.....if u do over oil it that causes the motor too seize?
Old 04-18-2011, 05:17 PM   #4
peter george's Avatar
Trader Rating: 355 (100%+)
did it really seize or did it suck up some kind if a metal that lodged itself between magnets and armature.?
Team Underdog - Team UPURZ -
peter george is offline   Reply With Quote
Old 04-18-2011, 05:25 PM   #5
theatriks's Avatar
well i cant turn it over at all at all so im assuming its seized .....i mean i could have sucked up a piece of metal just how will i know ....crack it open?
Old 04-18-2011, 06:37 PM   #6
CSaddict's Avatar
Its a silver can. They are disposable. Buy another one.
TLR 22
Losi SCTE
Blitz Open
Xray T3 RCGT
www.rcmadness.freeforums.org
CSaddict is offline   Reply With Quote
Old 04-18-2011, 06:48 PM   #7
theatriks's Avatar
ya im already stocked up on silver cans im just making sure thats the proper advice and also to try to figure out what went wrong
Old 04-18-2011, 06:56 PM   #8
Make sure you break them in first. They will last longer and perform better.
Stregone is offline   Reply With Quote
Old 04-18-2011, 08:21 PM   #9
Trader Rating: 33 (100%+)
You most likely have something lodged between the magnets and armature. Maybe a screw or washer? Cleaning and oiling your motor will make it last longer and have better performance.
Chris Lockhart
**TEAM RCAMERICA**XRAY**HUDY**PROLEVEL RC**
chensleyrc1 is offline   Reply With Quote
Old 04-19-2011, 11:59 AM   #10
theatriks's Avatar
ya guys its turning over again thanks for our help i guess theres was something caught in it .....im a newbie what do u want from me lol
Old 04-19-2011, 01:41 PM   #11
PitNamedGordie's Avatar
Send a message via AIM to PitNamedGordie Send a message via Yahoo to PitNamedGordie
Keep asking questions...that's the only way you'll learn some of this stuff.
☆ The Track @ Harbor Hobbies ☆ www.harbor-hobby.net ☆
PitNamedGordie is offline   Reply With Quote
Old 04-19-2011, 02:05 PM   #12
trerc's Avatar
Trader Rating: 89 (100%+)
Yep, and as mentioned, best way to maintain silver can motors is to remove them from the car after racing for the day, hose them out good with motor spray and put a drop of oil in both the top and bottom bushing, reinstall and it's ready for the next day of use.
If it smells burnt up.. it's more than likely hot.. you don't have to touch it..
trerc is offline   Reply With Quote
Old 04-19-2011, 02:28 PM   #13
snoopyrc's Avatar
I don"t know what its called but there used to be these cans of motor cleaner that you would dip the motor into while it was running. It would churn that stuff black and gurgle it around. Then we would pull them out and after it dried we would use "Comm drops". God only knows what that stuff was or what it did. Soften the brushes, Lube them, both.
www.battlefieldraceway.com Racing videos at http://www.youtube.com/snoopyrc
snoopyrc is offline   Reply With Quote
Old 04-19-2011, 02:34 PM   #14
infokiz's Avatar
CRP used to make a product like that and I believe you can still get it on ebay.
infokiz is offline   Reply With Quote
Old 04-19-2011, 03:45 PM   #15
Trader Rating: 217 (100%+)
Great! Now the question is, whatever was caught in there, did it fall out or is it still in there floating around waiting to get caught again??? Could be something as a small stone pebble. Be preparred for it to happen again. Like about 15 seconds to go while leading the "A" and it locks up dead!!!
Andy Koback is offline   Reply With Quote
