Old 09-16-2004, 12:49 PM   #1
pheyhoe's Avatar
R/C Tech Charter Subscriber
Default Best way to mark out body posts
my body is already painted and i need to find a good way of marking the inside of the shell where the body posts are, ready to be drilled....
[SIZE=1][COLOR=navy]Paul Heyhoe[/COLOR][/SIZE]
pheyhoe is offline   Reply With Quote
Old 09-16-2004, 12:51 PM   #2
Tempest2000's Avatar
Trader Rating: 21 (100%+)
trinity makes some body post markers that you put over your body posts that will indent your body where you need to put the holes.
Tempest2000 is offline   Reply With Quote
Old 09-16-2004, 02:13 PM   #3
seaball's Avatar
Send a message via Yahoo to seaball
i just use a paint marker and touch the tip of your body posts one end at a time (f/r). it's the same idea as the trinity product, but much less costly and takes less effort.
obviously you can't do this with this body, but punching the holes while it is clear is the best way to go. then you can clip it on and cut the wheelwells based on the true wheelbase, not the default molded in lines. once painted the molded lines disappear.
*** The Gate II - Home of Mike Wise ***
seaball is offline   Reply With Quote
Old 09-16-2004, 02:19 PM   #4
Send a message via AIM to rcguy2477
Or you can also hold the car up to the light and mark where the posts are.
1989 Mazda Rx7
greddy t04b, megasquirt ecu, PlX wideband, 12x28x3 fmic, 50mm hks clone wg, ssqv bov, Safc, ss oil lines, walbro fuel pump, tubo intake manifolds, ssac exhaust manifold, 3" dp, 550cc primary/720cc secondary injectors, etc.
rcguy2477 is offline   Reply With Quote
Old 09-16-2004, 02:33 PM   #5
fatdoggy's Avatar
Space out the wheels on your car so that they lightly press against the body and center it. Then use the drop of paint on the body post trick.
fatdoggy is offline   Reply With Quote
Old 09-16-2004, 03:07 PM   #6
Randy Caster's Avatar
Trader Rating: 46 (100%+)
Those are what I use, only 10 bucks for a set of 4.
WTB: TT-01 body posts Dorigecko Australia Wanted to Buy 0 11-19-2007 12:31 PM
TT-01 BODY POSTS! Mooshu Beef R/C Items: Wanted to Buy 4 10-13-2007 06:15 AM
TT-01 Body posts Mooshu Beef R/C Items: Wanted to Buy 1 09-08-2007 06:10 PM
tc4 body posts fit tc3? Valentin.H Electric On-Road 0 03-21-2007 07:18 PM
TT-01 body posts? MK_Arbiter R/C Items: Wanted to Buy 0 09-04-2006 11:32 AM
