Old 10-03-2004, 04:10 PM   #121
akrcracer's Avatar
happy B-day Doug!!
akrcracer is offline   Reply With Quote
Old 10-03-2004, 04:12 PM   #122
II Fast's Avatar
Trader Rating: 95 (100%+)
Thumbs up
Happy Birthday Doug,
-Tony
Youth and Skill
is no match for
Age and Treachery.
II Fast is offline   Reply With Quote
Old 10-05-2004, 10:55 AM   #123
clinttredway's Avatar
R/C Tech Charter Subscriber
Trader Rating: 4 (83%+)
Send a message via MSN to clinttredway
Default Setup Sheet
I am working on a new setup sheet and I should be done with it soon...
just an FYI - oh, it will be editable and saveable...
Do or Do Not, There Is No Try
clinttredway is offline   Reply With Quote
Old 10-05-2004, 02:18 PM   #124
So how did the PRC drivers do this past weekend?
Tony here in Dallas won... whoelse did well?
Old 10-05-2004, 02:59 PM   #125
Send a message via AIM to Adam Hartzell
I'm still waiting for a new servo so I can start running 1/12 again.
Adam Hartzell is offline   Reply With Quote
Old 10-05-2004, 03:00 PM   #126
What kind do you use?
Old 10-05-2004, 03:08 PM   #127
I was using Airtronics but am changing everything over to KO.
Old 10-05-2004, 03:42 PM   #128
I am using a KO radio and a JR servo, but I too am going all KO..
Old 10-05-2004, 03:46 PM   #129
Default Question
Clint,
I was wondeing if you could give me your setup for your 12th scale. Since you are going to Snowbirds you must have your car dialed to the track. I need some real help on setup when it comes to the 12th scale and the way it sounds on here you are an amazing driver and very knowledgable with the setup for the 12th scale cars.
bspost is offline   Reply With Quote
Old 10-05-2004, 04:19 PM   #130
Default Re: Question
Originally posted by bspost
Clint,
I am starting with Adam's setup
new front end
2 degrees of caster, 1.5 camber
.020 springs
Jaco double pink tires with 1/3 inside sauced
.074 t-plate (no thicker than .075)
Losi med. hydra fluid in the tubes
Jaco pink rears with full sauce
3.25mm ride height
parma speed 8 body
Old 10-05-2004, 04:47 PM   #131
JJ187RC's Avatar
Come on Clint, the way you hit the boards it don't matter what setup you have on the car, It is tweaked the 1st time you hit the throttle.
I thought that was a Nissian P35 body you had this weekend that you were cutting out.
JJ187RC is offline   Reply With Quote
Old 10-05-2004, 04:57 PM   #132
ah.. yes it was a Nissan body... and your point being?
Old 10-05-2004, 04:57 PM   #133
II Fast's Avatar
LOL, Don't ask him to put any dampner tubes together for you either.
Youth and Skill
is no match for
Age and Treachery.
Old 10-05-2004, 04:58 PM   #134
at least I don't break my car every run
Old 10-05-2004, 04:58 PM   #135
what, is it piss on Clint day?
PRP Quad12 for sale ARR Mr. Shookie R/C Items: For Sale/Trade 8 11-24-2006 06:20 AM
BMI, AH12, OR QUAD12?? odawg315 Electric On-Road 3 01-04-2006 10:51 AM
PRC Quad12 NOTFASTENOUGH R/C Items: For Sale/Trade 8 08-07-2005 08:06 PM
F/S: Quad12 12th Scale Roller che R/C Items: For Sale/Trade 5 04-05-2004 09:37 AM
