Old 09-22-2004, 05:34 AM   #46
RCsilly's Avatar
Location: Redford Mi. Trying to keep up with Tim Stamper
Originally posted by DPowell
Bob,
With the Team chassis, old style front end and CEFX body, my car weighs 28.4 oz. This is without any extra effort to remove weight like beveling the chassis. Just sanded and sealed. I'm also carrying a little extra weight with the side spring set up that I'm currently testing.
D.P.
Thanks Doug , thats what I wanted to know .
Bob
RCsilly is offline   Reply With Quote
Old 09-22-2004, 05:58 AM   #47
Trader Rating: 45 (100%+)
Default PRC Setup
What are some of your setup's for the PRC car in mod?
Apex is offline   Reply With Quote
Old 09-22-2004, 10:34 AM   #48
speedxl's Avatar
R/C Tech Charter Subscriber
Originally posted by dr_hfuhuhurr
What's the blue stuff on your damper tubes?
those are just blue RPM ball cups!
Pemberton / R1 / All out motorsports / Team Power Push
speedxl is offline   Reply With Quote
Old 09-22-2004, 10:39 AM   #49
speedxl's Avatar
thanks ray!
As far as my cars whieght with the reciver pack it tips the scale at 30.2 ounces with a regular speed body. Pluss on asphalt we run taller tires( 185 fronts and 190 rears)
I know I ran 175 and 185 rears with a lite wheight body it would be close to 28 ounces and may even have to add some.
Old 09-22-2004, 12:44 PM   #50
Default Setup?
I just ordered a Q12, and had some questions on the setup. I will be running 1/12 Mod 4Cell on a small tight track(80x40) Questions I have are:
Front end new or old?
What weight shock oil and spring?
What weight oil in the dampening tubes?
I am very excited to get my Q12 cant wait to race it in our up coming NW Champion Ship Series. Any tips or tricks you can let me know that will help me out I would appreciate it.
Thanks,
Mike Street
Street_Racer is offline   Reply With Quote
Old 09-22-2004, 05:17 PM   #51
Send a message via AIM to Adam Hartzell
Street_Racer ,are you running on carpet or asphalt?
Adam Hartzell is offline   Reply With Quote
Old 09-22-2004, 09:38 PM   #52
Doh! I am racing on Carpet
Thanks,
Mike
Old 09-22-2004, 09:47 PM   #53
Here is my base set up for mod.
new front end
2 degrees of caster, 1.5 camber
.020 springs
Jaco double pink tires with 1/3 inside sauced
.074 t-plate (no thicker than .075)
Losi med. hydra fluid in the tubes
Jaco pink rears with full sauce
3.25mm ride height
parma speed 8 body
The real set up is in the small details, but this should get you started.
Old 09-23-2004, 09:15 AM   #54
clinttredway's Avatar
Trader Rating: 4 (83%+)
Send a message via MSN to clinttredway
Thanks for that setup Adam!
Can someone post a 'base' setup for stock?
Do or Do Not, There Is No Try
clinttredway is offline   Reply With Quote
Old 09-23-2004, 10:23 PM   #55
That set up should be good for stock too. I would just switch to purple and grey tires.
speedxl--can you post you tire saucing rutine for me. I still had some grip issues and couldn't fully remember what you had told me today.
Old 09-24-2004, 11:40 AM   #56
speedxl's Avatar
Aplly the spf45 lotion on the tires 20 minutes before. At 10 before without wiping lotion off add tire additive of your choice. then wipe off before running !
set it and forget it!
Old 09-24-2004, 04:05 PM   #57
Thanks!! I'll try that when I go back on Tuseday.
Old 09-24-2004, 05:44 PM   #58
speedxl's Avatar
How did the indoor asphalt racing go?
I did contact Fernando and relayed the message lets see what happens!
Old 09-26-2004, 05:11 PM   #59
II Fast's Avatar
Trader Rating: 95 (100%+)
Thumbs up Quad12
Congratulations Hector on the State ChampionShip. I would like to add that with the Quad12 you had an advantage It truely is an "Awesome" car. I am very happy with mine (Pic included).
Tony
II Fast is offline   Reply With Quote
Old 09-27-2004, 12:26 PM   #60
speedxl's Avatar
Thanks too fast hopefully more people will catch on and see the light that the quad 12 is more then a tranformer but a well though and designed race car!
PRP Quad12 for sale ARR Mr. Shookie R/C Items: For Sale/Trade 8 11-24-2006 06:20 AM
BMI, AH12, OR QUAD12?? odawg315 Electric On-Road 3 01-04-2006 10:51 AM
PRC Quad12 NOTFASTENOUGH R/C Items: For Sale/Trade 8 08-07-2005 08:06 PM
F/S: Quad12 12th Scale Roller che R/C Items: For Sale/Trade 5 04-05-2004 09:37 AM
