Old 11-23-2004, 09:00 PM   #286
Tim Stamper's Avatar
Originally posted by Adam Hartzell
Tim--How did testing go. Are you happy with the discs instead of the tubes?
The dampener disc worked great. I used a Hammer 12 top pod plate because it is a lot stiffer and cut out to make it actually slightly lighter.
Tim
This space for rent
Tim Stamper is offline   Reply With Quote
Old 11-23-2004, 09:01 PM   #287
Originally posted by Tony Szep
Hey Tim
wats goin down at clevland? Well tomarrows the big day im hittin the big 14 say hi to the whole crew oh yea and bobby
Hey tony, what's up. Happy birthday in about an hour.
Tim
This space for rent
Old 11-24-2004, 05:46 AM   #288
Tim
thank you tim and good luck at clevland!
Tony Szep is offline   Reply With Quote
Old 11-24-2004, 11:07 AM   #289
Send a message via AIM to Adam Hartzell
Tim just ran his first round and the car is looking good. Hector will be running in a little while and I still have an hour or so til I can run my 1/12.
Adam Hartzell is offline   Reply With Quote
Old 11-29-2004, 03:37 PM   #290
I have just got my conversion kit and have built up the car at the weekend. I will be wanting to give it its first race next Friday.
Can any of you recommend a setup for low grip carpet racing with 19t spec motors.
reynard55 is offline   Reply With Quote
Old 11-30-2004, 10:52 AM   #291
Here's what I would start at for a low bite situation.
Front:
-new front end 10 deg blocks .018 springs
-I always start with the upper arms in the middle and then tune from there.
-Purple ot magenta front tires.
Rear:
-.063 t-bar or medium silva spring steel. .010 shim under front pivot
-trinity red in the tubes or if you use
the dampener disc setup, use 100wt shock oil.
-gray tires or white if spinning out.
-asc blue spring with 25wt oil.
-Harder the spring, the more off power
steering through corners due to weight transfer.
Body:
Parma speed 8 or if you want a lot of downforce, use the cefx body.
In 19T, I usually roll the car out at 1.85"/rev
Hope this helps,
Tim
This space for rent
Old 11-30-2004, 02:27 PM   #292
Thanks for the info Tim.
The only thing that suprised me a bit was the blue shock spring.
That is quite a bit heavier than the green I run on my L3.
Are you using the middle fixing on the T bar?
Old 12-01-2004, 03:07 AM   #293
RCsilly's Avatar
Location: Redford Mi. Trying to keep up with Tim Stamper
We run the blue spring on smooth tracks , adds steering , if some bumps , soften it up . Roll out by how tight the layout is , 1.8 is a good starting point for 19 t.
Doug , It was cool to meet you this weekend , my car was good enough to go third in my main with some clean driving , still mad about missing it !!!!!!
Bob
Hector , you guys make it home OK ?
RCsilly is offline   Reply With Quote
Old 12-01-2004, 11:25 AM   #294
speedxl's Avatar
R/C Tech Charter Subscriber
Bob we made it ok! Long haul though.
Tim thanks for the help.
James also thanks.
Adam also thanks. if it werent for you I wouldnt have been able to attend!
Doug I thank you for all your help.
I am somewhat down not having done better. I had a rough week. I had fun with the group, just wish I would have been feeling better.
I make it up to the team at the snow birds.
Pemberton / R1 / All out motorsports / Team Power Push
speedxl is offline   Reply With Quote
Old 12-01-2004, 10:00 PM   #295
stumper1's Avatar
Has anyone here run springs in/on their damper tubes with a Q12? Pros? Cons?
stumper1 is offline   Reply With Quote
Old 12-01-2004, 11:24 PM   #296
reilly's Avatar
Hector,
I had a good time, and it was a pleasure to meet you. Maybe I get to go the Snowbird's I'll keep you up to date on that. Thanks for your help also.
James
CEFX, Express Motorsports, Parma, Reilly Paint
reilly is offline   Reply With Quote
Old 12-02-2004, 07:33 AM   #297
DPowell's Avatar
I haven't tried springs on the tubes but I have tested a chassis brace/bottom plate combo that uses springs and adjusters. Works great!
D.P.
www.powellracingcomponents.com
**Record setting carbon fiber**
Speedmerchant and TOP USA dealer.
DPowell is offline   Reply With Quote
Old 12-02-2004, 09:20 AM   #298
James also thanks.
It was a blast, that's all that I can say. I had more fun mingling than racing this year. It was cool meeting all of you and finally putting a face to a name.
Thanks for the cold also. I've been sniffling and coughing for days now. Ugh. Talk to ya later brotha!
Tim
This space for rent
Old 12-02-2004, 02:48 PM   #299
Thumbs up
James, YGM.....
Currently taking a break from R/C, running 1/1 scale cars, they are cheaper then running Modified TC!!!
retired from RC in 2007, running 1:1 scale now
[email protected]
Greg Anthony is offline   Reply With Quote
Old 12-04-2004, 06:29 PM   #300
speedxl's Avatar
I think everyone is on vacation!
I think Doug is mad at us!
Tim sorry about the cold!
PRP Quad12 for sale ARR Mr. Shookie R/C Items: For Sale/Trade 8 11-24-2006 06:20 AM
BMI, AH12, OR QUAD12?? odawg315 Electric On-Road 3 01-04-2006 10:51 AM
PRC Quad12 NOTFASTENOUGH R/C Items: For Sale/Trade 8 08-07-2005 08:06 PM
F/S: Quad12 12th Scale Roller che R/C Items: For Sale/Trade 5 04-05-2004 09:37 AM
