Official Team Paradigm Racing Thread
#106
Gear Ranges
I ordered an Epic Roar Stock and an Epic Chameleon2 for my TC3. I am running a 72 spur. I race on Medium to large asphalt tracks in California. Can you recommend spur gear ranges that would be the most efficient and effective, while keeping the heat to an acceptable level. Also what are the acceptable heat levels on these motors based on 5 minute races.
#107
Originally posted by HPZ
so that would mean that the postive brush will wear out faster than the negative side am i right? Also why isn't this used on modified motors?
Occasioanlly we do use this in modified racing, but it isnt as crucial. In modified you generally spring much stiffer to prevent the brushes from bouncing. In most cases, we run a stiff purple spring on both sides.
#108
Hobbyman and John,
Thanks for the complements...
#109
Re: Gear Ranges
#110
also, 48 or 64 pitch? i would assume 48.
#111
if you feel like switching out your spur, you can gear: 96 spur with a 38 pinion, or right in that range, up or down a tooth. thats with a stock motor, i dont know about 19t
#113
ok, if you are running the 72 spur, with a stock motor, you should gear
72/28
with the 19 turn, you should gear 72/26
this is according to associateds website. these are ballpark numbers, your motors might run better being geared up or down one tooth. hope this helps
72/28
#117
Re: BLACK MAGIC & TRIBO
Originally posted by Fuzzy
Brandon,
I've heard that your "black magic" brushes have Tribo baked into them. If this is true, should I not be using the Tribo drops along with these brushes? Could that much Tribo actually hurt my motors performance? Too much of a good thing?
Brandon,
At the stock nats, I tried baking the brushes I had there in some Dextron III mixed with some other oils. It was nothing more than messing around... thats how you find out what works and what doesn't. A lot of people thought it was Tribo because it was red, however thats just rumor. If you bake Tribo, it becomes really goey and doesnt work very well at all. So to answer the question, no, there is no Tribo in the brushes. There is however 1 of the same ingredients in a concentrated form that was molded into the brush during manufacturing, however that is my little secret. I cant reveal everything we do on our new products
#118
Brandon,
One more question. Will I harm the chemical make-up of the black magics if I spray out my motor without removing the brushes? I don't like to unseat them unless i'm cutting the comm.
Brandon,
#119
Just to let everyone know, we will be closed next week on Oct. 13-15 (Wed. through Fri.) for the Chicago Hobby Show. If any of you are in the atending, stop by our booth and say hi!
#120
19 turns armature
i received my 19 t armature (top one) put it at in a v2 element and try it out ,but it only makes 26000 rpm not more
after that i try other springs,brushes, then i try it in other motors and other endbels nothing change still aboud same performence
when i try on the track my stock element armature was even beter ,so please give me some advice
i hope you can help me
Ronald Bestman
Ronald Bestman
