Oil Bottles
Old 09-14-2004, 11:21 PM
Brandon R's Avatar
Default Oil Bottles
Brandon R is offline
Old 09-15-2004, 12:11 AM
j240z's Avatar
Try Tap Plastics or any other plastics supply store in your area. They have alot of small contianers made out of plastic. http://www.tapplastics.com/
j240z is offline
Old 09-16-2004, 06:40 AM
Brandon Rohde's Avatar
Brandon R,
Nice initials
Are these the bottles you are looking for?
http://www.team-paradigm.com/cgi-bin...logno=PDM23001
We order about 5,000 at a time, so we get a pretty good price break on them. Otherwise if you order only a couple hundred they will run you about $0.75 each. Let me know if these are what you need and we could sell you some from our stock pretty cheap.
Brandon Rohde is offline
Old 09-16-2004, 06:50 AM
jaysimpson's Avatar
While we are talking about bottles.... Does anyone know where you could find the bottles like Red Dot,or Death Grip traction compound come in? It is the kind with the applicator so you can rub the compound on the tires. Anyone have an idea?
jaysimpson is offline
Old 09-16-2004, 06:59 AM
promatchrc,
Try searching on www.ThomasRegister.com. They list thousands of companies that specialize in selling packaging and industrial supplies and the search results are really accurate. That's where we always find our stuff at.
Old 09-16-2004, 07:24 AM
Regional Moderator
Mark Mixon's Avatar
Default Bottles
When I need them, a local beauty supply store has them, usually about .75 apiece retail, I guess it depends on your needs and quantity. Wholesalers often have a minimum of 500, or more. Hope it helps.
Mark Mixon is offline
Old 09-16-2004, 07:33 AM
promatrcr,
I did some searching. Here are some of the standard compound applicators:
http://www.andonbrush.com/popup.asp?ID=35
For more info, go to http://www.andonbrush.com/products.asp and scroll down to NEW PRODUCTS and click on Utility Cans.
I couldn't find anything like the Red Dot, but I only looked for about 2 minutes. Best bet is to search for some kind of pharmaceutical dispensor, I think a lot of acne meds come in bottles like that. Otherwise I have seen them used in art for some paint dispensing, but that would probably be too course of a tip and liquid would flow through too fast.
Old 09-16-2004, 09:26 AM
GundamWZero's Avatar
Get those liquid roll-on applicators!!!!
GundamWZero is offline
