aligning brush hoods >
Old 09-15-2004, 08:38 AM
  #16
Trader Rating: 82 (100%+)
do i still have to align the brush hoods even if there's a "dimple" on the endbell? i was looking at a couple of trinity endbells and theres a "notch" or "dimple" that seems to lock the brush hoods in place, therefore preventing misalignment
marvi is offline
Old 09-15-2004, 09:30 AM
  #17
dr_hfuhuhurr's Avatar
Trader Rating: 93 (100%+)
Originally posted by fatdoggy
BJ forum - www.rccars.com/forums
How true that is....LMAO!
dr_hfuhuhurr is offline
Old 09-15-2004, 01:46 PM
  #18
jag88's Avatar
IMO you want the brushes aligned to the comm not to each other.
Use the same make brush to align the hood as you plan to run in the motor. All the little tweaks add up and DO make a difference.
The new motors seem to have a better alignment then the old but should still be checked.
My $0.02.
jag88 is offline
Old 09-15-2004, 03:41 PM
  #19
mafiaracers's Avatar
Trader Rating: 22 (100%+)
An easy way to see where you're sitting in your alignment is to run your motor for about 6 or 7 runs. Then take out your brushes and look parallel to the face. If the "smile" is crooked, then align to compensate.
mafiaracers is offline
Old 09-15-2004, 04:43 PM
  #20
azenis's Avatar
Are you talking about the lug that fixes the timing on a stock motor?
azenis is offline
Old 09-15-2004, 04:55 PM
  #21
No, look on an epic endbell....to the right and left of the brush housing, you'll see two indents on the hood. They make the two plates fit together like a puzzle.
Old 09-15-2004, 06:57 PM
  #22
azenis: mafiracers is correct, i was talking about the indents on the metal
marvi is offline
Old 09-16-2004, 04:39 AM
  #23
Brandon Rohde's Avatar
Here is a link to the instructions for the Team Paradigm "Big Jim Series" Alignment Bar.
http://www.team-paradigm.com/documen...s-PDMBJ001.pdf
That should help explain it a little bit with diagrams. One of the main keys to aligning the brush hoods is clamping the hoods tight to the brushes. The hoods on EPIC motors are slightly too big because the cheapo brushes that come on the brushes are made in Japan, versus race compound brushes we always use such as the 767 and 4499 are made in the US or to US specs. The difference is small, but its enough to make noticable power difference. Without risizing or clamping the hoods, the brushes are constantly shifting back and forth when you hit the throttle.
Brandon Rohde is offline
