Old 09-14-2004, 05:02 PM   #1
ovalnator's Avatar
Trader Rating: 43 (100%+)
Send a message via AIM to ovalnator
Default best way to cut plexiglass
I recently aquired some 1/4" and some 3/8" plexiglass, and was curious as to how the best way to cut it is. I have access to a table saw, jig saw, band saw, etc. Any help is appreciated.
ovalnator is offline   Reply With Quote
Old 09-14-2004, 05:11 PM   #2
You should use a special cutter and contrary to glass cutting go over the line enough times so that you have cut a fairly deep groove. The best way is to use equipment such as the Fletcher-Terry but you can purchase special hand held knives for this
purpose. If you don't have a Fletcher, clamp a guide to the plexiglass so that you can go over the line several times. [I had summer job once doing this]
Once the line is deep enough, use the edge of a table and snap.
You will have a very unpleasent experience if you use a table saw!
A better solution is to find a glass place that will cut it for you. In the past I have been lucky to find places that have charged no more then a few bucks or if its a simple square cut, one guy did it for me for free. Took only a few minutes and I gave him $5 for his trouble.
meche is offline   Reply With Quote
Old 09-14-2004, 05:20 PM   #3
ovalnator's Avatar
Thanks!
Old 09-14-2004, 05:22 PM   #4
i use my table saw with a fine tooth blade, you go nice and slow and it gives you a really really nice cut! before you cut though tape the line you gonna cut down with some masking tape and then re-draw your line so you can see it, that tape will just prevent rough edges
kh15 is offline   Reply With Quote
Old 09-14-2004, 05:29 PM   #5
DOMOisCOOL's Avatar
R/C Tech Charter Subscriber
Send a message via ICQ to DOMOisCOOL Send a message via AIM to DOMOisCOOL Send a message via Yahoo to DOMOisCOOL
I had some 3/8 plexiglass and what I did to cut it was, I used a very sharp box cutter knife, and scored the line where I wanted to cut. Keep scoring the line till you get a nice groove but not too deep. Then place the plexiglass on the edge of a flat surface (flat table with flat edges), and make sure the line you scored is on top of the table edge. Then carefully bend/snap the plexiglass. It should come out clean (mine did, did 2 of them using same method). I know this is NOT the best way, but I found it to be good when you don't have the proper equipment.
My dad said to avoid using power tools, because sometimes if the blade is moving too fast, the plastic will be messed up.
DOMOisCOOL is offline   Reply With Quote
Old 09-14-2004, 05:48 PM   #6
moveitorloseit's Avatar
It depends on the type of plexiglas. When use a polycarbonate type of plexiglas at work. (does not shatter like true plexiglas) We use a table saw for straight cuts and a band saw for curves and specialty cuts. But like was mentioned on a table saw be careful because the piece will kickback very quickly. Good luck
moveitorloseit is offline   Reply With Quote
Old 09-14-2004, 06:07 PM   #7
Nova F1 Racer's Avatar
Since I just cut 40 + pieces of 1/4 plex-glass I can help you here...
Spend he $3.95 at Lowes/Home Depot and get a plex-glass cuter...
Score it like it said above with 1 minor point..
DO NOT I REPEAT DO NOT go back and forth scoring it. ALWAYS go the same way. I shattered a couple of pieces when I went back and forth.
OK another tip, use a piece of metal as your straight edge.. and clamp it down... After scoring it at least 10 times, put the scored edge over a table ( about 1/16 of an inch ) Use the meta straight to clamp it down ( about 1/2 inch ) back from the score.
Pull down on the piece that is hanging over the edge, not to fast and not to slow... It will sound like a small fire cracker when it breaks.... Use very fine sandpaper to go over the cut edge...
This is DICK!!! And you're NOT!
RC Tech member #11
Aussie Rules Footy, Brisbane LIONS!!
[url]http://www.pitter-pat.com/[/url] for pet care needs in Northern Virginia
Nova F1 Racer is offline   Reply With Quote
Old 09-14-2004, 06:18 PM   #8
theisgroup's Avatar
you can also use a router to cut it. us a straight edge and a bit with a guide.
yang lai
Team Tamale | Team Tekin | RCAmerica | Speedmerchant | Speedzone RC | EA Motorsports | Ko Propo USA | eXpress Motorsports | Parma/PSE
theisgroup is offline   Reply With Quote
Old 09-14-2004, 06:48 PM   #9
gee-dub's Avatar
i used to work at a hardware store that sold plexi-glass... score it a few times, then snap it off seemed to work well, but does that really work for something as thick as 3/8"? i would think a real fine bandsaw blade (in the 18-20TPI range) would be the way to go.
out of curiousity, making anything rc related?
gee-dub is offline   Reply With Quote
Old 09-14-2004, 07:47 PM   #10
I work in a sign shop and cut plexiglass everyday on a table saw. You need a special blade to get a really good cut and its best to use a miter gauge. But if you have to ask the best way to cut plexi then Im sure the above suggestions on scoring it(which this is the first time i've heard of that) because it seems alot safer for you.
But since your asking, the best way to cut it is on a laser or computer router !(which i run both at work). The laser is only a 100watt laser so its only good up to 1/2.
stumper is offline   Reply With Quote
Old 09-14-2004, 10:06 PM   #11
Tek Nickal's Avatar
Get a table saw and a plexi glass blade, the blade is around $20 or more, depending on what brand. Its convienient if you already have a table saw.
Tek Nickal is offline   Reply With Quote
WTB: HUDY 1/8 OFF-ROAD SET UP (plexiglass) FREELANCE_RCer R/C Items: Wanted to Buy 7 03-14-2008 01:45 PM
Hudy Setup Gauge Plexiglass skengines R/C Items: For Sale/Trade 12 03-01-2008 09:34 AM
Hudy plexiglass 1/10 setup station ? gurumods Electric On-Road 9 01-02-2008 10:47 PM
