Novak Atom Case...Falls Apart! >
Old 09-14-2004, 04:35 PM
Jeel's Avatar
Trader Rating: 16 (100%+)
Default Novak Atom Case...Falls Apart!
Novak Atom Case...Falls Apart! Any good tips for keeping these cases together? This is a new unit (had it in my pitbox forever) and I'll throwing it in a 1\12 scale.
Super glue, tape, etc?
Jeel is offline
Old 09-14-2004, 04:36 PM
R/C Tech Elite Member
Randy Caster's Avatar
Trader Rating: 47 (100%+)
Just run a thin bead of CA glue around the case, then it'll never come apart. I used to do that and then use the tape over it that it came with. Just picked up a coupld GTX's though and they are even smaller than the Atom.
Randy Caster is offline
Old 09-14-2004, 04:54 PM
Tape it, if you want to take it apart for some odd reason.
Tony Szep is offline
Old 09-14-2004, 05:13 PM
I used Tamiya blue battery strapping tape on mine. That works great and I can still open it for service if I have to
meche is offline
Old 09-14-2004, 05:42 PM
sweetpea's Avatar
I used black electrical tape or orange vinyl..........once you tape it, it should stay together in onroad........offroad I would use shoo goo to glue so that dirt doesn't get inside.
sweetpea is offline
Old 09-14-2004, 06:48 PM
and the shoe goo would be easyer than ca to take off but holds better than electrical tape.
Old 09-14-2004, 07:48 PM
Rick Worth's Avatar
Novak recommends never use crazy glue on a speed control. The glue & fumes can corrode & ruin the circuits.
Rick Worth is offline
Old 09-15-2004, 12:11 AM
crimson eagle's Avatar
mini tie wraps.
crimson eagle is offline
