servo help!!!!
Old 09-13-2004, 02:59 PM
ALBERTO's Avatar
Trader Rating: 23 (96%+)
Default servo help!!!!
Ok this is the deal I spoke to a tech at lrp/Asscioated and told him i had glitching problems between the ESC and my stearing servo. I have a xray evo 2 quantom competition 2 and a hitec ultra speed hs-925mg servo. He said that the esc 's programing is too complexed for the servo..... Weather he is pulling my leg I cant tell you. But I will say when I switch the servo to a crap plastic one the problem goes away..... has anyone else had this problem? are hitch servo's crap? and which high speed servo's Do you recomend ? Keep in mind I want to stay out of the digital stage , or should I...... please give me ya thoughts and what combo's you preferr..... THANKS!!!!
ALBERTO is offline
Old 09-13-2004, 03:23 PM
Speedie's Avatar
I use novak speedos gt7's. I tried a couple of hitech servos in my tc3 and my 12th scale and both had glitching problems. I never figured out what the problem is I just switched servos and the problem has never returned.
Speedie is offline
Old 09-13-2004, 07:02 PM
Trader Rating: 28 (100%+)
I had a problem with my Airtronics digital causing a glitch in my FTTC3. I use a Novak speedo with Airtronics radio gear. Switched to an analog Airtronics servo, and no more glitch. I sent the servo in to have it checked, and they replaced a pot but also said it worked fine. I was also told to call them and they would tell my why sometimes digital servos can cause glitches. I tried once, but they close early.
Bottom line is there might be some truth to what they are telling you. I have a 5925 and I have not had glitching probs with it as of yet.
Scott Fisher is offline
Old 09-13-2004, 07:10 PM
ALBERTO's Avatar
so what do you guys think for a real good and quick servo
ALBERTO is offline
Old 09-13-2004, 07:12 PM
If you want analog, then get an airtronics 94357 or a used 94257. Both are lightning fast, and plenty strong enough to handle anything.
Old 09-14-2004, 12:47 AM
Wency_TA03R-PRO's Avatar
Exclamation
I don't encounter glitching problem with my FT TC3 using a futaba S9550 servo.. Have you tried using futaba servos?..
Wency_TA03R-PRO is offline
Old 09-14-2004, 01:16 AM
Cole Trickle's Avatar
Personally, I have had great success with my KO PDS 2123. But as long as you stay with good brands like Airtronics, KO Propo, Futaba etc., I dont think it can go really wrong.
Once I had a similar problem with a not so well-known servo - the LHS turned out with great service, and took the servo back and sold me a KO, where he only charged me for the difference between these two servos. I also got 10% discount on the KO. Bottum line: In your case, I would definately use an LHS instead of an on-line shop.
Cole Trickle is offline
Old 09-14-2004, 05:40 AM
lastplace's Avatar
check out the JR Z590M, quick, metal geared and cheap, $40
lastplace is offline
Old 09-14-2004, 06:59 AM
ALBERTO's Avatar
Cool
Thats the one i'm running in my car now with no problems, in fact thats the one that came with the radio when i bought it. just looking for a bit faster then that. thanks thought. Think i'm going to try what the guy's say and look at the big names. guess hitec aint 1 or them!!!!
ALBERTO is offline
Old 09-14-2004, 07:07 AM
Some people have great luck with Hitec servos. But in these forums, there's also contantly people crying over them...
Old 09-14-2004, 07:09 AM
JDXray's Avatar
hey alberto, now you know why i didnt want that hitec you wanted to sell me, lol. Goodluck with the glitching problem, i cant remember you glithing on saturday if you were. I think my next servo is gonna be Ko Propo servo and ESC. Want to try something different. Hope it goes well.
-Jon
JDXray is offline
Old 09-14-2004, 07:42 AM
Company Representative
Tres's Avatar
Trader Rating: 14 (100%+)
I have been using a LRP Comp for a couple years now with Hitec servos..
HS-5925
HS-5945
HS-925
HS-245
HS-5245
with no issues.....
However, I have seen a few guy have problems with the BEC circuit of the LRP Comp.(several brands of servos)
There have been several of the local guys have issues with PT's counting & the LRP Comp.
They added a CAP to the Rx and it helped..(stutter stopper)
Not saying this is your issue 100%, but just a thought......
Tres is offline
Old 09-14-2004, 10:25 AM
ALBERTO's Avatar
-Jon
jon that because i'm using the jr servo now...... now ya sure ya dont want the hitec real cheap almost free 99
tres: thanks for the input. there are the things i tried to do to get the stutter to stop 1 add a cap helped but not much 2 which helped a lot shorting the fricking long a$$ servo wires. this was like night and day, but still not perfect. 3 Which was the best move swooped servo"s lol
ALBERTO is offline
Old 09-14-2004, 10:28 AM
What type of radio are you useing. If it is "am" then that is your main problem right there.
Chris
mtc3od is offline
Old 09-14-2004, 10:35 AM
ALBERTO's Avatar
JR XS3 SYNTHESIZED!!!!!! ALL FM BABY THANKS FOR THE HELP THOUGH
ALBERTO is offline
