pulsar comp ?'s
Old 09-12-2004, 09:26 AM
dado11g's Avatar
Default pulsar comp ?'s
ok i just got a pulsar comp and i am wondering how i should set the charger to get the most out of my gp 3300's. i want the edge when i race and i know lots of people got thier own little tricks. im lookin for amps, mV, and any other tips.
thanks, i really apreciate any suggestions,
Marshal V.
dado11g is offline
Old 09-12-2004, 09:40 AM
JDXray's Avatar
Well for charging most people use 6.0A and Discharge at 30Amps, but i dont think you can discharge at 30amps on that charger. For the .mv everyone has different opinions i set it at 50mv.
But after everytime you charge and run, and get off you should discharge and then tray them. Should only used them 2-3 times in one day (thats for one pack)
hope it helps
-Jon
JDXray is offline
Old 09-12-2004, 09:41 AM
dado11g's Avatar
thanks jon! thats what im lookin for.
dado11g is offline
Old 09-12-2004, 09:45 AM
JDXray's Avatar
No problem, but there is definitly more options out there. Keep asking and looking.
-Jon
JDXray is offline
Old 09-12-2004, 10:53 AM
Registered User
I set mine 6A at 30mv.
Aku-Man is offline
Old 09-12-2004, 02:26 PM
Company Representative
Tres's Avatar
Trader Rating: 14 (100%+)
I'm with Aku-Man
6A @ 30mV
Tres is offline
Old 09-12-2004, 02:31 PM
lastplace's Avatar
30 here, they got too hot at 50.
lastplace is offline
Old 09-12-2004, 02:33 PM
DOMOisCOOL's Avatar
5.5a @ 25mv
DOMOisCOOL is offline
Old 09-12-2004, 04:49 PM
stumper1's Avatar
I charge at 6 amps. I adjust the mv based on temperature. I aim for 120-130 degrees (f) right when it peaks. Right now it is set at 30 but I have had to go as high as 50.
stumper1 is offline
Old 09-12-2004, 07:22 PM
Default Question?
May i ask what the MV Does? Milivolts right?
Dik Yarx is offline
Old 09-12-2004, 07:29 PM
Tres's Avatar
Dik Yarx: yes...
It should be mV, but some state it as MV...
M=Mega
m=Milli
But, anyway, yes...
Tres is offline
Old 09-12-2004, 08:40 PM
dado11g's Avatar
Default great
thanks alot all of you guys
dado11g is offline
Old 09-12-2004, 09:43 PM
Originally posted by Tres
Dik Yarx: yes...
M=Mega
m=Milli
But, anyway, yes...
And what does it actually do?
Higher = more voltage or soemthing????????
Dik Yarx is offline
Old 09-13-2004, 10:19 AM
Hi,
Its a voltage drop measurement used to determine the peak, i.e. once the battery drops 30mV (while charging) the charger considers it a peak and shuts off.
The higher the # the longer the charger will go before shutting off so the pack will be hotter.
For me & 6 cells 30mV works good on new packs, 40-50mV for older packs. Safest bet is 30-40 and if your older pack is cool when the charge is done just repeak and keep checking it till it warms up a little. Its better than toasting the new packs with too high of a mV setting.
Traying your cells before charging is rather important, if you dont chances are you'll end up with various temps on the cells, some extremely hot and some cool. Some of the cells stay good and some go down hill quickly.
Brian
XCrash is offline
