Old 03-11-2003, 02:15 AM   #1261
fai
Regional Moderator
fai's Avatar
Default About springs...
I think Alex's springs come out in the brand name of Xenon, in hardness: 1.4mmx5.25turns/5.50/5.75/6.00/6.25 and also a set in 1.5mm!
fai is offline   Reply With Quote
Old 03-11-2003, 02:37 AM   #1262
Originally posted by Evoracer
Hey freshjive,
Thanks for the help....funny you mentioned shims. This, which is used but I just bought it, has a shim mounted behind each diff where the hex balls are. Do not know there size. It appears they were made from some excess carbon material. I believe this car was used on carpet so I'm assuming this is a typical carpet roll mod setup. I only run asphalt. Should I remove the shims??
shims are place under hexballs for kickup and anti squat...so it will depend on how you setup the car...as for me i'm using 1.5mm spacer under all 4 hexball...so basically there's no kickup and antisquat...by the way i'm no expert in setting up cars so i hope others could help you.
fReShJiVe is offline   Reply With Quote
Old 03-11-2003, 12:26 PM   #1263
SpeedTech's Avatar
Hi Guys,
We've been working on a new website dedicated to the Alex Racing Design Barracuda R2, and here's the web address:
www.alexracingusa.com
It might take about 1-2 more weeks before it opens, but start bookmarking it now Also, it will be a simple website (nothing flashy) but hopefully we can provide a lot of information for the Barracuda Racers
Thanks for reading,
Steve Wang
Speed Tech R/C
www.speedtechrc.com
SpeedTech is offline   Reply With Quote
Old 03-11-2003, 12:39 PM   #1264
JDM_DOHC_SiR's Avatar
Trader Rating: 31 (100%+)
Default Re: About springs...
Xenon's are the same as Alex (Comet)
-Dave
Ȼ4.5 Centro+α ◊ TRF 501ӽ ◊ TRF 502ӽs ◊ TRF 503 ◊ TRF 511 ◊ TRF 201ӽr ◊ TRF 211ӽ
B5m ◊ T5m ◊SC5m ◊ B64deez nutz
Speedway PAL ◊ SDRC ◊ Shop UFO ◊ SMC
JDM_DOHC_SiR is offline   Reply With Quote
Old 03-11-2003, 12:53 PM   #1265
Exclamation Outstanding!!
Originally posted by SpeedTech
Hi Guys,
Thanks for reading,
Steve Wang
Speed Tech R/C
www.speedtechrc.com
Really GOOD NEWS!!!!!!!!!!!!
Finally [color= deep red]Alex Racing USA[/color]
-Dave
Old 03-11-2003, 02:28 PM   #1266
Talking Good info
Cuda's need a little TLC on the 16T & 39T gears to make the drive train smooth and spin for a long time...
For starters..... you'll need some 400~600 grit wet dry sand paper and you'll need to spend about 3 hours just removing all of the peaks on the bevel and diff gears and buy doing this you'll be able to tell just by the gear mesh and that there is less noise too!! especially if you have a Motor/shaft mount holder ( which usually makes the drive train noisy )
But with the 400( 320 is what I use less time )
start to remove a liberal ammount of material ...say about 1mm on the 39T Diff gear ....
This should take a whole Sh!t [email protected] of resistance out of the Barracudas' drive train
also a little bearing prep doesn't hurt either
Try this and let me know
BTW my cuda's on aveage can spin for about 10~14 seconds without tires !! but before all of the prep work they only spun for about 5~6 tops
-Dave
Old 03-11-2003, 02:36 PM   #1267
Default Re: Re: EXCEL short arm conversion
Originally posted by Tsubasa Sakai
21800yen..........
If I add 8000yen more,I can get a R2 kit.
Yea I know
But I just try to show all you guys the newest stuff
-Dave
Old 03-11-2003, 02:45 PM   #1268
racer's Avatar
is there any difference in performance if you change the suspension arms to shorter ones?
racer is offline   Reply With Quote
Old 03-11-2003, 03:00 PM   #1269
Exclamation On the R1
The R1 Needed it more so than the new R2..the Shorter arms replaced the R1's weak flexable ones that Alex has now fixed on the R2 ....The short arm setup make the car respond better and makes the R1 feel sharp and responsive
-Dave
Old 03-11-2003, 05:05 PM   #1270
Herminator's Avatar
Send a message via ICQ to Herminator
thats a nice picture should be even nicer when we can get in to the main site
I really need my cuda to chear me up now nothing better than retail therapy.
3hours sanding?
could probably create whole teeth in a blank plastic gear in that time
Herminator is offline   Reply With Quote
Old 03-11-2003, 05:28 PM   #1271
Default Re: On the R1
-Dave
got no problems with the R1 graphite arms...stock arms is flexible but not the graphite ones....or do what i did R2 arms on R1
Old 03-11-2003, 05:38 PM   #1272
3hours sanding?
3 hours is what I took... but then again I like to get it right the 1st time ...
-Dave
Old 03-11-2003, 05:52 PM   #1273
Default Re: Re: On the R1
Good idea also
-Dave
Old 03-11-2003, 06:20 PM   #1274
Herminator's Avatar
how about some very close up pics of the gears before and after, 1mm sounds quite a lot. Just want to make sure I get it right first time
Old 03-11-2003, 07:06 PM   #1275
SpeedTech's Avatar
Hi Guys,
I did the sanding thing in 10 minutes...i was very greedy and used a rougher sand paper...hehehee Seriously speaking, you might not even have to sand anything. I tried the sanding before I try different shimming of the diff, so you might not even have to sand.
Steve Wang
Speed Tech R/C
www.speedtechrc.com
WTB Alex Racing Barracuda R2 & R3 Funkymojo R/C Items: Wanted to Buy 3 02-03-2007 01:00 PM
alex racing barracuda con81 Electric On-Road 1 12-14-2005 03:36 AM
WTT: Alex Racing Barracuda R2 for PS2 AZ_Ron Other Items: For Sale/Trade or Wanted to Buy 0 02-13-2005 07:30 PM
Alex Racing Barracuda R3-New. rcracing1973 R/C Items: For Sale/Trade 9 04-11-2004 08:29 AM
Alex Racing Barracuda Bugs Bunny Singapore R/C Racers 6 01-22-2003 11:47 PM
