Barracuda from Alex racing >
Like Tree1Likes
Old 03-07-2003, 02:42 PM
  #1201
JDM_DOHC_SiR's Avatar
Trader Rating: 31 (100%+)
Default Re: Re: Jive???
Originally posted by fReShJiVe
and also i will only part with something similar value as you can see i have spent quite an amount of money on this kit easily over US$500
You have a PM...
-Dave
JDM_DOHC_SiR is offline
Old 03-07-2003, 02:47 PM
  #1202
Talking TC-3 Rocket
i still have a pink one.....and my friend gonna go Japan again in April so the PAL version gonna soon be in my hand....why i want a TC3???ok the TC3 gonna be a SpeedDemon running 7cells with 5300/58ce brushless system ...this will only be used on a 1/8th scale track
Sound's like you want a Rocket there Jive'
-Dave
Old 03-07-2003, 02:49 PM
  #1203
JDM PM back to u
fReShJiVe is offline
Old 03-07-2003, 02:52 PM
  #1204
Default Re: TC-3 Rocket
-Dave
yah! i want a rocket my esc/motor allows me a 10cell limit if any kit would be able to fit more cells without need to piggyback cells i'll get the kit....thinking of xray...but nah!! never like the car....if there's a 10cell shaft driven car...that would be my next purchase
Old 03-07-2003, 03:16 PM
  #1205
Default Re: Re: TC-3 Rocket
The new R2 chassis will hold 8 cells
-Dave
Old 03-07-2003, 03:22 PM
  #1206
yah i know that with the chassis if you put 8 cells your esc would need to be mounted on the upperdeck
Old 03-07-2003, 03:40 PM
  #1207
Thumbs up
THen you should keep your Barracuda.. and just buy the 2 Speed chassis upgrade... and they you would pretty much have a Car that would be 90% R2 and would kick some serious but and would carry some speed with the 2 speed =)
BTW I now know where to get different Ratio's for the 2 speed now..
Ratios from 4.75~8.0
-Dave
Just a thought
Old 03-07-2003, 03:44 PM
  #1208
Sigearhead's Avatar
Trader Rating: 72 (100%+)
Jive:
That car is freaking sweet!
Sigearhead is offline
Old 03-07-2003, 03:53 PM
  #1209
Lightbulb Jives' Car
It is Rather nice isn't it
-Dave
Old 03-07-2003, 04:08 PM
  #1210
-Dave
Just a thought
NOW!! this is news if you can help me get a 2speed kit with the gear ratio from 7.0-8.0...i'll give the purple motor mount to you as a thank you gift just pay me the shipping
Old 03-07-2003, 04:18 PM
  #1211
or you could tell me where to get it locally in Japan as i have a friend going there end of april...i'll give a 50% discount on the motor mount....but if you can get it for me earlier than that...the mount is yours
Old 03-07-2003, 04:22 PM
  #1212
Lightbulb Sure..
But it might be a little while due to the fact that I'm still out at sea. ....It might be summer time before I get back to Japan..
But if you can get the Chassis upgrade on your own... I can get the gears and clutch stuff when I get back.... I think that it costs less than 3000 Yen for the Gear upgrade.... the companys name is Seyo~Tune.. Kind of a Local guy at my track... makes all sorts of One-off parts and such 7.0~8.0 in 48p should be easy..
-Dave
Old 03-07-2003, 04:27 PM
  #1213
ok will do! i'll get the conversion for my other NIB Cuda and wait for the gear option....does it have anything higher than 8.0??maybe up to 9.0??now 2 speed on brushless will make the 1/8th scale sweat
EDIT: i'll wait till you can get me the gear option as i wouldn't want to be stuck with a 2speed coversion with only stock gearing....i dont run stock...even local races dont have a stock class unless it's a Tamiya race....other are just plain open modified and open outlaw class(brush / brushless anything goes only rules are Touring 4wd/6cells/1500g minimum weight)
Old 03-07-2003, 04:38 PM
  #1214
JDM - by using the conversion kit will i be able to use the One Flag motor mount as it has a different position for it
Old 03-07-2003, 04:47 PM
  #1215
Yes and no....
I have seen the Mount work.. but only after someone made a alloy sleeve to go over the shaft where the bearing goes.... sould be a easy mod' you just have to get the sleeve made with a set screw and a notch on the carbon shaft.....also it only works with the one flag mount and not the square one
-Dave
