Barracuda from Alex racing >
Old 03-05-2003, 12:54 PM
  #1141
JDM_DOHC_SiR's Avatar
Trader Rating: 31 (100%+)
Originally posted by TC3
how can the rear toe in be adjusted on the r2?
and the front caster (not kick up)?
The reartoe can be adjusted by using off set 6.8mm A-arm balls they are an optional part.. form Alex they look like these (picture at bottom )
As far as caster..?? the only way it can be done is by shimming the A-arm balls...ALex also sells a shim set that comes in .5mm/.75mm/1mm.
-Dave
JDM_DOHC_SiR is offline
Old 03-05-2003, 01:08 PM
  #1142
Originally posted by fai
JDM: I got it, thanks!
Your welcome
-Dave
Old 03-05-2003, 02:10 PM
  #1143
Originally posted by Herminator
Argh, a week early, I better sell my soul then. Ok who'll give me the first bid? One little used soul, just 20years old. I'll throw in my consionce too.
-Dave
Old 03-05-2003, 02:43 PM
  #1144
Arrow R2 Pic's
are there any pics of the r2?
Here you go
-Dave
Old 03-05-2003, 03:40 PM
  #1145
Herminator's Avatar
DROOL!!!
Just a couple weeks away now it looks
Better start thinking of a nice new shell for it
and what I'm gunna say to the guys I race when I give them the shaft
could have nice new cells sorted by then too
Herminator is offline
Old 03-05-2003, 04:18 PM
  #1146
Default 6,8 balls and A-arms tips
Any tip installing the optional 6,8 balls on the new (grafite) A-arms?? I thing that the new a-ars are stronger than the standard ones.
martinm is offline
Old 03-05-2003, 04:34 PM
  #1147
Default Re: 6,8 balls and A-arms tips
2 words that will be come you best friend
Heat Gun or Hair Dryer
makes it a sinch' putting them in....or you can do i the old' fashon way...... Kung Fu Grip with a set of plyer's
-Dave
Old 03-05-2003, 04:45 PM
  #1148
Thank you JDM
. I will try tomorrow.
Also do you think if its possible to install the sway bars from the HPI pro 3 (the rear one)?.
martinm is offline
Old 03-05-2003, 04:54 PM
  #1149
Hi Dave,
Can you provide some build tips for the car for us newbies who will soon have R2's ?
I know about the sanding of the gears but are there any other building advice you might know of?
Are there any issues (minor or major) we should know about?
Any hop-up recommendations that will improve performance (although there probably won't be many) ?
itchynads is offline
Old 03-05-2003, 05:17 PM
  #1150
MikeR's Avatar
Trader Rating: 15 (100%+)
Ooooh- Very nice Dave! Can't wait to get mine next week.
I haven't seen pics with roll bars yet- do they not exist and have you played with the roll center for the lower inner arms yet?
Best,
MIke
MikeR is offline
Old 03-05-2003, 05:20 PM
  #1151
SpeedTech's Avatar
Hi Guys,
We'll also be bringing in the Purple color as well. So the two colors available right now are the Blue and Purple. Estimated date of arrival: March 14th!
Steve Wang
Speed Tech R/C
www.speedtechrc.com
SpeedTech is offline
Old 03-05-2003, 05:34 PM
  #1152
Dave,
Is there a way you can make a carpet setup for the R2? I am interested in the car, but I don't have the kind of skill to set up a car right now. I just copy someone's setup and concentrate on driving. Thanks.
BTW. I just got an ITR powered EH/EG. It's quite insane.
-Leon
Leon is offline
Old 03-05-2003, 05:35 PM
  #1153
Thank you JDM
The HPI sway bars wont work.... but the Kyosho KX-one's will and the Yokomo MR-4 ones will..
Look in this pic...
Old 03-05-2003, 05:42 PM
  #1154
Jeff Werner's Avatar
How does the Cuda R2 deal with the grim that we get from racing on some less then perfect surfaces...tires dust and just the track itself can get all over the insides of our sedans...I know of the enclosed box that helps...but is the car able to handle a less than perfect racing surface for very long?
Great info on the 14th! Man better get my tools all layed out in wait to build a new kit!
Jeff
Jeff Werner is offline
Old 03-05-2003, 05:44 PM
  #1155
Originally posted by Leon
Dave,
-Leon
I have about 2 setups for Carpet right now... but there at home in Japan... I can ask around.... give me a day or too and I'll see what I can come up with for you
BTW congrats' on the Civic!! ... Feels nice to have a car that weights 2150 and has about 195hp..
Just think of the car that I have with the amount of power I put to the ground!!
-Dave
