Old 02-16-2003, 11:57 AM   #841
JDM_DOHC_SiR's Avatar
Trader Rating: 31 (100%+)
Originally posted by elnitro
I want to try something different, would you recommend a Speedway Pal Cuda or an R2? I know the Pal is more $, but is it worth it? Thanks.
Get the R2.... It's a little bit more refined' and has about 75% of what the PAL version does... also.. Better Chassis balance
-Dave
Ȼ4.5 Centro+α ◊ TRF 501ӽ ◊ TRF 502ӽs ◊ TRF 503 ◊ TRF 511 ◊ TRF 201ӽr ◊ TRF 211ӽ
B5m ◊ T5m ◊SC5m ◊ B64deez nutz
Speedway PAL ◊ SDRC ◊ Shop UFO ◊ SMC
JDM_DOHC_SiR is offline   Reply With Quote
Old 02-16-2003, 12:13 PM   #842
JDM, so the R2 has the same layout as the TB Evo II and the Pal is similar to the Evo III/TC3 , right? What parts should I stock up on? Also, does the R2 come w/ front one-way?
elnitro is offline   Reply With Quote
Old 02-16-2003, 01:46 PM   #843
The parts that I would stock up on would be A-arms and DOg bones.. Thats about it for the R2... But I would get the optional aluminum front and rear shaft supports to replace the Plastic ones
-Dave
Old 02-16-2003, 06:56 PM   #844
Send a message via ICQ to Tsubasa Sakai
Originally posted by JDM_DOHC_SiR
BTW is that a Square front body post mount/support on your CE-4.. ... I see I'm not the only one who uses it to
-Dave
But it fits.
Tsubasa Sakai is offline   Reply With Quote
Old 02-17-2003, 04:38 AM   #845
Originally posted by Tsubasa Sakai
But it fits.
It sure does.... Also a few other things fit over to the Barracuda that speed way PAL makes for the CE-4..
If you have the short span A-arm conersion... you can use the Ti Hinge pin set that is made for the CE-4... it's a good way to drop 14grams
-Dave
Old 02-17-2003, 04:45 AM   #846
-Dave
The Ti hinge pin that you memtioned is it gold in colour?I also saw it in Pal homepage.But not it says only lighter 8g?
If drop 14g,I am very interested.
Old 02-17-2003, 05:41 AM   #847
Yes they are the Gold colored ones ... I wish I had my CD with my R/C pic's on it.. Because I had the Ti CE-4 Shafts spun down in the Center to loose a tad bit more weight
your right about the weight difference.. but I think that it was more than 8 grams when I checked them together..more like 10 grams... anyways it's a good buy if you want to loose some weight after adding the PAL arm conversion.. ....
I have my PAL "Cuda" weighing in at 1505grams with with body and 3300 GP's/GT-7/Futaba 9550 and Ko 301 receiver
-Dave
Old 02-17-2003, 05:45 AM   #848
JDM_DOHC_SiR: Do you see any graphite composite parts for CE4,like A-arm,C-hub?
Now no shops in HK sell CE4 parts.
Old 02-17-2003, 07:01 AM   #849
Default CE-4 Parts
I know whenI was in HKG .. I must have went to about 7~9shops looking for some parts!! ...but nothing...Control Center was the only place that had anything .. and most of it was in a Bag ...
But CE-4 parts are pretty easy to find here in Japan ..
I can get the Hard Graphite C-hubs and A-arms easy... they are pretty cheap now too... The LOCAL Track has a bunch of them in stock too..
BTW do you have the Lower A-arm mounts.??? the 4.5mm ones.?? works really well with the Lower motor mount set
-Dave
Old 02-17-2003, 12:58 PM   #850
Opps forgot that the R2 now comes with the new double bearing'd oneway too
-Dave
Old 02-17-2003, 01:57 PM   #851
Speedway Pal's website? Thanks.
Old 02-17-2003, 02:26 PM   #852
Wink PAL's Site
Here You Go
Speedway PAL
-Dave
Old 02-17-2003, 03:21 PM   #853
Exclamation R2 Barracuda Kai chassis Kits and R2 PAL Kai Kits!!!
You guys are going to go APE SH!T when you see this stuff.!!! Lots of new stuff from K-modles (KAI)
Enjoy... ...
-Dave
Old 02-17-2003, 03:40 PM   #854
Exclamation Also 3 types of A-arms for "Cudas" now
Alex Racing is also going to be releasing some MID Span A-Arms sometime here real soon from what my Japanese buddys just wrote to me.??
So that now gives us all the options....and it makes sence if you look at the new R2 chassis and wondered what the extra set of A-arm mount holes that were drilled in the chassis
Looks like some real good info from stuff to come from ALEX and Kai
-Dave
Old 02-18-2003, 03:49 AM   #855
fai
Regional Moderator
fai's Avatar
JDM: Cool! Good Info.! Keep coming!!
fai is offline   Reply With Quote
WTB Alex Racing Barracuda R2 & R3 Funkymojo R/C Items: Wanted to Buy 3 02-03-2007 01:00 PM
alex racing barracuda con81 Electric On-Road 1 12-14-2005 03:36 AM
WTT: Alex Racing Barracuda R2 for PS2 AZ_Ron Other Items: For Sale/Trade or Wanted to Buy 0 02-13-2005 07:30 PM
Alex Racing Barracuda R3-New. rcracing1973 R/C Items: For Sale/Trade 9 04-11-2004 08:29 AM
Alex Racing Barracuda Bugs Bunny Singapore R/C Racers 6 01-22-2003 11:47 PM
