Barracuda from Alex racing >
Like Tree1Likes
Old 02-01-2003, 07:42 PM
  #751
Default Re: Re: Re: Re: Re: Re: Any shim??
Originally posted by JDM_DOHC_SiR
Tsubasa..
How much side to side play does the diff have when it is installed with out any shims..?? or if you do have to use a shim place it on the long side of the diff (left side if looking from the back) it might free up a little play on the shaft counter gear... .hmmm Have you tried that yet..??
-Dave
Yes,now I use a shim placed on the long side to solve the problem.There is not side to side play in this case too.
Tsubasa Sakai is offline
Old 02-02-2003, 03:41 AM
  #752
JDM_DOHC_SiR's Avatar
Trader Rating: 31 (100%+)
Wink Try another diff..
...Hmmm sounds to me like there is a part out of tolorance .. maybe a teflon diff half or a diff ring that might be to thick.?? ..Do you have another diff you can try ??
Good luck
-Dave
JDM_DOHC_SiR is offline
Old 02-02-2003, 07:57 AM
  #753
Default Re: Re: Re: Re: Re: Re: Re: Any shim??
Anyone else have any idea's
Lets try to help Tsubasa out
-Dave
Old 02-02-2003, 08:09 AM
  #754
Ian
i just shim on the shorter side only so as not to affect any gear mesh as diff can only move towards the bevel gear and not away from it
Ian is offline
Old 02-02-2003, 08:33 AM
  #755
Default Re: Re: Re: Re: Re: Re: Re: Re: Any shim??
I think he might have tried that..??? but what I think he is saying is that the diff is also tight without the shims
-Dave
Old 02-02-2003, 08:42 AM
  #756
Ian
Default Re: Re: Re: Re: Re: Re: Re: Re: Re: Any shim??
-Dave
then maybe it could be either the diff plate or ballbearings like you said earlier....but it's likely the diff plate
Ian is offline
Old 02-02-2003, 08:44 AM
  #757
Ian
and maybe try to re-install the bulkhead.there could be some tolerances with the screws and the countersunk holes on the chassis
Ian is offline
Old 02-02-2003, 09:01 AM
  #758
Exclamation good idea
I was thinking of that being a option too ..on my CE-4 I had some problems like that on the front motor mount ..so that might have a bit of a difference ...
-Dave
Old 02-02-2003, 01:36 PM
  #759
Thumbs up
Old 02-02-2003, 01:39 PM
  #760
dynoman007's Avatar
Default waddup
okie i hope everyone had a good weekend ..............
has anyone tried to use the rear shock bodies that are a lil longer on the front ?????????
dynoman007 is offline
Old 02-02-2003, 01:50 PM
  #761
Default Re: waddup
I have seen to Japanese Guys a Yatabe Arena that had this set up on there 'CUDA's" ..but They never ran their cars' Plus from what I could ask them ...( limited Japanese speaking skillz' ) they could only Use a 300M body... The Protoform 2.0 was oout of the question......
but for seeing them in action .. Thats a Big Fat Negative
-Dave
Old 02-02-2003, 03:18 PM
  #762
dynoman007's Avatar
Default cuda
i wasnt meaning the rear shock tower up front just the longer rear shock bodies try it i think you will like it if you are running the short arm car set up .......
Old 02-03-2003, 06:21 AM
  #763
Default Re: cuda
Ohh I see Sorry .... I havent tried that... But I do run the short shocks all the way around on My normal 'Cuda' ... not much of a difference though
What did you notice with the longer shocks up front..??
-Dave
Old 02-03-2003, 11:15 AM
  #764
Lightbulb Short shocks on rear
Here is a shot of the short ones on the rear...
BTW do you have any Pic's with the long shocks up front
-Dave
Old 02-03-2003, 01:40 PM
  #765
TC3
TC3's Avatar
help
i have a few questions about the cuda. the barracuda is made by alexracing, right?? the r2 is the new version?
but what the hell is an pal cuda? or a speedway barracuda? or a kai barracuda?
ther is a new car called X-PLOSION from triox (a german brand)
it looks like a alex barracuda r2 or not?
thx
sry for my bad english
TC3 is offline
