Barracuda from Alex racing
#691
Re: Re: Re: Re: Re: spool
Originally posted by driftmaster
If its a mold it will have a injection spot some where, kinda
like a belly button.
#694
NIce pics. JDM!
#696
Re: Here's some R2 Pic's that I found ...
Originally posted by JDM_DOHC_SiR
[B]
[B]
#698
Re: Re: Here's some R2 Pic's that I found ...
Originally posted by Tsubasa Sakai
What is the advantage of mounting the shocks in that way??
#699
Re: Re: Re: Here's some R2 Pic's that I found ...
Originally posted by fReShJiVe
that is because the roll bar is mounted reverse on the R2....the plastic spacer between the shock tower is the plastic that holds the swaybar in place(on the old cuda swaybar are mounted on the top) ....as you can see the plastic ball end on the arms where you mount the ballcups for swaybar is of opposite side of the old a-arms.....so for the R2 it's more cumbersome to change your swaybar as you will need to take off the shock towers.....do i make sense??
-Dave
#700
here are some pics
front swaybar
rear swaybar
front swaybar
rear swaybar
#702
hailo all
welps here is the race report and it isnt kind first of all the alex car isnt friendly to foam tires ...... i killed 3 diff halves and like 4 spindles someone must have moved the 2x4s because i never wreck of course lol ......the spools will have to be machined from something very tuff i killed them as well ...... if you dont run on faoms or carpet you have no clue there is a ton of force when you crash on carpet especially in mod class ......next gen spools will be aluminium for sure maybe part alum and steel ..... if anyone is running an alex car on carpet plz message me for info i have found a few things that work very well and would love to find out other set ups .......on a good note the car was always turning either the fastest laps or within 1 10th of the fastest laps of any car on the track and that is good when you are the only one running a single car against the finest cars available here in the US ... have a good one and stay tuned for more info lol
#703
hmmm
Sound's like good and bad news congrats on the fast laps..but kind of sh!tty on the broken stuff
Keep up the good test work and let us know more info when you get it ..I still want to get the spools when you guys get the bugs worked out... Because I will be running on Foams here with my R1.5 here soon....and if you want to pass along any good stet ups ' please do so
thanks
-Dave
thanks
-Dave
#704
#705
Originally posted by fai
TS: Maybe in this way, the user can un-screw the dampers and change different damper positions on damper plate more easily... As now the screwdriver can be placed in front instead of at the middle... Hope you know what I mean!
Since it is blocked by the a-arm.
