Old 01-14-2003, 10:09 PM   #586
fai
Regional Moderator
fai's Avatar
Default Re: thx fai
Originally posted by dynoman007
that is a neat ride on there site .......does anyone have a cool setting sheet that is translated and they can e mail me i
would surely appreciate it ...what %of the guys over there are running the car with the pal hinge pin arm conversion ???
Oops... I think you can translate those Japanese phrases by Altavista's translate! It works great!! I just knew one racer in HK had the hinge pin version installed... Rumors claim it improves cornering ability!!!
fai is offline   Reply With Quote
Old 01-14-2003, 10:31 PM   #587
TFR
TFR's Avatar
Originally posted by JDM_DOHC_SiR
I'll take a pic for you tonight OK
-Dave
Thanks Dave...
TFR is offline   Reply With Quote
Old 01-14-2003, 10:39 PM   #588
dynoman007's Avatar
Send a message via MSN to dynoman007 Send a message via Skype™ to dynoman007
Default gimme e mail addy
i have a pic of my cuda with lots of mods including pal hinge pin conversion ,custom sway bars ,and torque rods
dynoman007 is offline   Reply With Quote
Old 01-14-2003, 10:42 PM   #589
JDM_DOHC_SiR's Avatar
Trader Rating: 31 (100%+)
Default Re: Re: thx fai
I use nothing but the Short arm conversion from PAL.. I used the Square Hard Nylon one's for about 3 weeks but there is sucha huge differance in handleing and resoponce it like night and day !!
Money well spent
-Dave
Ȼ4.5 Centro+α ◊ TRF 501ӽ ◊ TRF 502ӽs ◊ TRF 503 ◊ TRF 511 ◊ TRF 201ӽr ◊ TRF 211ӽ
B5m ◊ T5m ◊SC5m ◊ B64deez nutz
Speedway PAL ◊ SDRC ◊ Shop UFO ◊ SMC
JDM_DOHC_SiR is offline   Reply With Quote
Old 01-14-2003, 10:49 PM   #590
Default Re: gimme e mail addy
You still need torque rods with the PAL arm conversion?
I used to have torque rods for the front but I didn't need them after I switched to the PAL arms
-Dave
Old 01-14-2003, 11:04 PM   #591
Ran the Barracuda for the first time last weekend, only was able to stay for a couple of heats, but it seems to have great stability, a lot of speed, but lacks corner speed. I think it is just too stable. What do you suggest changing that would make the front end a lot more agressive? Any tricks with roll centers etc that generate more front end grip?
12th Scale - The premier class (if you can make runtime)
Besercoe is offline   Reply With Quote
Old 01-14-2003, 11:10 PM   #592
fai
Regional Moderator
fai's Avatar
Default Re: Re: Re: thx fai
Money well spent
-Dave
I see... But that conversion kit will cost 1HKD=100Yen (noramlly, 1HKD=6~7Yen) as they are really rare in HK!!
Big differences are also noticeable when changing to the 'hard' Alex A-arms!
Old 01-14-2003, 11:16 PM   #593
fai
Regional Moderator
fai's Avatar
Besercoe: In my little opinion, assume the dampers are set rightly, I suggest placing shims (0.5~1.0mm) under the front hex balls of front A-arms. This increases kick-up angle and will give an overall more agressive steering!!
For front roll centre, I will suggest to adjust the upper camber link as tilt as possible! A too level link will prohibit the car from steering into corner and greatly slow down cornering speed! Do try this at track!
Old 01-14-2003, 11:17 PM   #594
Talking SpeedWay PAL short arm coversion
The Speedway PAL Short arm coversion will fix about 70% of the problems that you are having.
I use 300 weight all the way around with a 1.4mm sway bar up front in front and 1.5 deg camber in front and 1 deg camber in the rear.
The PAL Cuda corners like it's on rails with that set up
-Dave
Old 01-14-2003, 11:24 PM   #595
Default Re: Re: Re: Re: thx fai
I Can get a few sets of the PAL arms if you'd like for about 8000 YEN each but thats the best price I can find in Japan on theses arms
When I was in HKG this past november I think I cleaned out JET and Control Center of Every PAL/Baracuda/One Flag parts that they had in Stock
-Dave
Old 01-15-2003, 01:54 AM   #596
fai
Regional Moderator
fai's Avatar
Default Re: SpeedWay PAL short arm coversion
-Dave
JDM: I'm sorry to ask you again: what front/rear springs are you using then??
Old 01-15-2003, 02:00 AM   #597
fai
Regional Moderator
fai's Avatar
Default Re: Re: Re: Re: Re: thx fai
-Dave
HaHa, thanks. I'll call you if I need the kit then!
Oh, you're devil! We HK Barracuda fans can't get any one flag parts anymore!!! Just kidding
Secretly, I also cleaned out those Alex parts of Futaba Workshop last December during my short vacation at Tokyo!!! Isn't it fair??!!
Old 01-15-2003, 02:15 AM   #598
Diva's Avatar
Send a message via Yahoo to Diva
You two must be very clean
Diva is offline   Reply With Quote
Old 01-15-2003, 06:00 AM   #599
Default Re: Re: SpeedWay PAL short arm coversion
HPI 27mm Pinks all the way around or if the track has serious traction issues I switch to HPI 27mm light blues
-Dave
Old 01-15-2003, 06:06 AM   #600
Talking My Speedway PAL pic's
Here's the 1st one
WTB Alex Racing Barracuda R2 & R3 Funkymojo R/C Items: Wanted to Buy 3 02-03-2007 01:00 PM
alex racing barracuda con81 Electric On-Road 1 12-14-2005 03:36 AM
WTT: Alex Racing Barracuda R2 for PS2 AZ_Ron Other Items: For Sale/Trade or Wanted to Buy 0 02-13-2005 07:30 PM
Alex Racing Barracuda R3-New. rcracing1973 R/C Items: For Sale/Trade 9 04-11-2004 08:29 AM
Alex Racing Barracuda Bugs Bunny Singapore R/C Racers 6 01-22-2003 11:47 PM
