Old 12-11-2002, 10:59 PM   #511
fai
Regional Moderator
fai's Avatar
Dear all, I just replaced those A-arms with harder one last night! I feel that the suspension is now harder than before. Maybe I need to use softer springs instead... Does anyone also feel this??
fai is offline   Reply With Quote
Old 12-14-2002, 06:32 PM   #512
anyone know what is the part number for the attached pic???it is the aluminium part that is on the end of the shaft
thanks
fReShJiVe is offline   Reply With Quote
Old 12-15-2002, 03:41 PM   #513
thanks
Good luck in finding the part (CO-6031 I think). Last I heard it was impossible to get as Alex Racing had not made any more apart from what was shipped with kits. Which is a bummer and forced me to get the center one way which is a replacement for it. I stripped the grub screw hole in mine
itchynads is offline   Reply With Quote
Old 12-15-2002, 07:26 PM   #514
itchynads - thanks for the part no. i just figured myself by matching the japanese words on the manual and the parts list
Old 12-16-2002, 05:52 AM   #515
by the way why didnt u just drill a bigger hole and use a 4mm taping tool to thread it...and just use a bigger grub screw....or even drill anothe hole opposite of the stripped hole
Old 12-16-2002, 07:30 AM   #516
do any of u guys put any thing like dry liquid teflon lube or anything along that line on the diff gears and 'counter' gears???
what setup changes do i need to do to get more steering off power???here is what i could think of:- shim up the rear of front suspension ball head , use lower hole on front hub so to lower roll center , lengthen front camber link......is ther anything else i could try to get more steering??
cheerz
Old 12-16-2002, 08:07 AM   #517
Diva's Avatar
Send a message via Yahoo to Diva
Wink
Putting lube will attract more dust. Want off-power steering? One possible way is centre one-way.
Diva is offline   Reply With Quote
Old 12-16-2002, 08:44 AM   #518
lube will attract dust....but the one i mentioned is dry liquid teflon....it's in liquid form but will dry in minutes ...instruction says will not attract dust....hehe...maybe just a minufacturer claim . i dont think center one way will affect any initial turn in .....it's just there making the drivetrain more efficient during corner and straight so that u can carry more speed. "Square" caster block could do the trick as they are 5deg...or is it 3deg
Old 12-16-2002, 08:53 PM   #519
Diva's Avatar
The setup book of XRAY might help you to understand the effect of centre one-way. You can get it here
Old 12-16-2002, 11:44 PM   #520
I did drill another hole but that stripped as well so i gave up and went with the center one way since it doesn't use grub screws
Old 12-17-2002, 02:04 AM   #521
just got a reply regarding the availability of the center shaft adapter(CO-6031)....let me know if u want to order it .... will pm u the details....selling at 600yen(US$4.97) not inclusive of shipping....
Old 12-17-2002, 03:01 PM   #522
JDM_DOHC_SiR's Avatar
Trader Rating: 31 (100%+)
Talking Just got back home
Hey guys ...sorry to be gone for a couple of days...but now I'm back home in japan and I'll be able to help you all out 100% better than being out to sea on a ship
Also I will try to post a couple of pic's today of my Cuda's for you all to look at
-Dave
Ȼ4.5 Centro+α ◊ TRF 501ӽ ◊ TRF 502ӽs ◊ TRF 503 ◊ TRF 511 ◊ TRF 201ӽr ◊ TRF 211ӽ
B5m ◊ T5m ◊SC5m ◊ B64deez nutz
Speedway PAL ◊ SDRC ◊ Shop UFO ◊ SMC
JDM_DOHC_SiR is offline   Reply With Quote
Old 12-17-2002, 06:34 PM   #523
Thanks. At the moment I'm busy with my Evo3 so the 'cudda has fell into a state of disrepair
Please pm the details anyway so I can get back to fixing the cudda when I get some time.
At the moment I need the parts that attach the shaft to the shaft holder ie. the plastic collars that secure the bevel gear and bearing to the holder. I'm sure these are stocked by Rainbow ten so that shouldn't be a problem, just need to find time to do it
Old 12-17-2002, 11:04 PM   #524
fai
Regional Moderator
fai's Avatar
Dear all, Jet Hobby of Hong Kong just released some optional parts for Barracuda:
- 5 degree caster block
- steering arm
- 1 degree rear hub
All are available in only black or aluminium (silver?), no other colors.
I just got a black rear hub last night, costs approx. USD14!!
Old 12-17-2002, 11:07 PM   #525
fai
Regional Moderator
fai's Avatar
cheerz
I think set-up the dampers properly may be a solution... Just my little comments...
WTB Alex Racing Barracuda R2 & R3 Funkymojo R/C Items: Wanted to Buy 3 02-03-2007 01:00 PM
alex racing barracuda con81 Electric On-Road 1 12-14-2005 03:36 AM
WTT: Alex Racing Barracuda R2 for PS2 AZ_Ron Other Items: For Sale/Trade or Wanted to Buy 0 02-13-2005 07:30 PM
Alex Racing Barracuda R3-New. rcracing1973 R/C Items: For Sale/Trade 9 04-11-2004 08:29 AM
Alex Racing Barracuda Bugs Bunny Singapore R/C Racers 6 01-22-2003 11:47 PM
