Old 10-25-2003, 01:04 AM   #5101
JDM_DOHC_SiR's Avatar
Trader Rating: 31 (100%+)
Originally posted by Randman
That's cool, I cant wait for the R3 either...
Trust me ... your going to love it... since it doesn"t have as many parst tat you need to get to make it Rock!!
-Dave
Ȼ4.5 Centro+α ◊ TRF 501ӽ ◊ TRF 502ӽs ◊ TRF 503 ◊ TRF 511 ◊ TRF 201ӽr ◊ TRF 211ӽµ
B5m ◊ T5m ◊SC5m ◊ B64deez nutz
Speedway PAL ◊ SDRC ◊ Shop UFO ◊ SMC
JDM_DOHC_SiR is offline   Reply With Quote
Old 10-25-2003, 10:28 AM   #5102
Randy Caster's Avatar
Trader Rating: 46 (100%+)
Exactly... I'm thinkin just some R1 aluminum gear mounts and I'll be set
Old 10-25-2003, 08:29 PM   #5103
just get one for the rear and get the Double bearing one for the front
besides the R1 mount is cheaper than the R2 one...3000 yen vice 3600 Yen
-Dave
Old 10-25-2003, 08:34 PM   #5104
Herminator's Avatar
Send a message via ICQ to Herminator
-Dave
Ah but Steve doesn't have the R1 versions is one bearing really that important? I rarely finish a race within 0.01seconds of another car
Herminator is offline   Reply With Quote
Old 10-25-2003, 10:14 PM   #5105
light weight and less drag( 2 bearings )
-Dave
Old 10-25-2003, 11:10 PM   #5106
-Dave
Sounds good, the price isnt really an issue, but it's nice to save cash
Old 10-26-2003, 05:17 AM   #5107
racer's Avatar
can you put the R1 gear mount on the front as well?
racer is offline   Reply With Quote
Old 10-26-2003, 07:11 AM   #5108
Regional Moderator
R/C Tech Charter Subscriber
The R1 had them front and back . I guess if you wanted too you can!
Ko Racer is offline   Reply With Quote
Old 10-30-2003, 03:19 PM   #5109
Regional Moderator
ImGoinRCn's Avatar
Send a message via Yahoo to ImGoinRCn
When all else fails, aim for the quarter panel.
Several oval and off road vehicles
and a legend car nicknamed Kidney Stone.
X Factory R/C SCX-60CF
X Factory R/C X-6˛
ImGoinRCn is offline   Reply With Quote
Old 02-27-2004, 02:47 PM   #5110
rtypec's Avatar
Default Re: Ok ok here ya go...Spliff aka rubber-diff
Okay guys, here it is...
Originally posted by RedBullFiXX
Anatomy of a Spliff aka (Rubber Diff)
Necessity is the mother of invention they say...For the Reedy Race of Champions One-Ways are not permitted, the options left are Ball-Diff, or Spool. A Ball-Diff should have better corner speed, while the Spool should have an advantage on corner exit. The One-way was developed to offer the best of both worlds, that’s where the Spliff comes into play, part spool, part diff it does it all.
Here is a simple way to make a diff feel almost like a spool, and it’s adjustable for just the right amount of drive off the corner while maintaining corner speed especially thru the high speed sweepers.
You will need 6 black o-rings.
1. Disassemble diff, reassemble using thick diff lube on diff balls.
2. Lube up 2 o-rings with a thick diff lube, like Losi purple, or Tamiya Anti-Wear grease, place 1 o-ring on each side of the diff
3. Do not use the thrust balls, place 1 thrust washer over each o-ring on each side.
4. Insert diff screw into diff, on the other side do not use diff spring, instead replace it with 4 o-rings (dry, clean).
5. Assemble with diff nut, torque as tight as you dare.
6. Adjust as necessary. Much like an off-road slipper, tighten until you can barely here it slip on hard acceleration. Check again after a few runs as the o-rings take an initial setting. After 5 runs it should hold this setting.
A properly built and adjusted Spliff should last quite some time in between rebuilds. I used the same Spliff throughout the entire Reedy Race weekend, and had some shakedown time on it the week before with little to no wear on the outdrives, and no adjustments needed.
Picture of a spliff...wanna get high :P ?
rtypec is offline   Reply With Quote
Old 02-27-2004, 03:01 PM   #5111
Wow Rod, this thread has had 4 months since its last post, and somehow you can come up with the post from Dave on how to do the spliff... good job man, lol.
WTB Alex Racing Barracuda R2 & R3 Funkymojo R/C Items: Wanted to Buy 3 02-03-2007 01:00 PM
alex racing barracuda con81 Electric On-Road 1 12-14-2005 03:36 AM
WTT: Alex Racing Barracuda R2 for PS2 AZ_Ron Other Items: For Sale/Trade or Wanted to Buy 0 02-13-2005 07:30 PM
Alex Racing Barracuda R3-New. rcracing1973 R/C Items: For Sale/Trade 9 04-11-2004 08:29 AM
Alex Racing Barracuda Bugs Bunny Singapore R/C Racers 6 01-22-2003 11:47 PM
