Barracuda from Alex racing >
Like Tree1Likes
Old 12-10-2002, 01:33 AM
  #496
fai
Regional Moderator
fai's Avatar
Originally posted by fReShJiVe
fai-thank you for the detail explaanation...i will try that when i rebuilt the shock
i ran the car today and stripped spur gear as if im changing battery packs....why is that so???should i get the one piece motor mount???does anyone use the motor mount set from "Square"??
verdict:-
stock setting desperately need more off power steering will do some setup changes when i solve the spur problems.....noticable torque steer...will add weight on motor side...
by the way any recommendation on one piece motor mount??one flag seems to be way on the high side of pricing
The one piece motor mount seems to be a "must" for Barracuda... although I insisted in not getting one for some time...
I now run with the one flag, I got it from 2nd hand and it hadn't be run before, just lucky! I doesn't see racers nearby run with a square one...
fai is offline
Old 12-10-2002, 02:21 AM
  #497
JDM_DOHC_SiR's Avatar
Trader Rating: 31 (100%+)
YES!!!
here's one shot
-Dave
JDM_DOHC_SiR is offline
Old 12-10-2002, 05:24 AM
  #498
by the way do u guys run 64 or 48 pitch spurs??
ok for the one piece motor mount it seems that flag and square come with the shaft...just wondering if the stock shaft would be able to be used on the mount or will it be deemed as junk once i get the 1pc mount
fReShJiVe is offline
Old 12-10-2002, 07:15 AM
  #499
Talking 48 pitch .now..but
I have the both the square and the one flag mount for my 'Cuda's ..with the One Flag you can use the carbon shaft still.. or the optional front one way drive shaft. But with the square you are stuck with the drive shaft they supply ....but I'm working out something with that right now
-Dave
Old 12-10-2002, 07:20 AM
  #500
Default YES!!!
the walking Alex Dictionary to the rescue again...i think i'm better off with one flag mount...at least i would have a spare shaft as a backup
thank again JDM
leochan- how much is product D motor mount???does it have colour option...would like it if it has purple
Old 12-10-2002, 07:41 AM
  #501
Thumbs up Product D
The only colors that they have right now is Blue and Black....and it costs 7000 Yen..
-Dave
Old 12-10-2002, 01:46 PM
  #502
Wink thanks I'll try that
JDM: I always run with 1.2mm sway bar front/rear! For camber, I used 0.5 degree front/rear as this gives more even tire wear!
thanks
-Dave
Old 12-10-2002, 08:01 PM
  #503
do they sell the Barracuda or any alex racing stuff in the states? I have seen the diffrent colors and the one with a 2 speed and really liked how they look. Do they handle like a tc3? oh Freshjive you have a pm.
thanks
teamAE is offline
Old 12-10-2002, 09:18 PM
  #504
Matt Howard's Avatar
Yeah, I would of thought by now that someone would import the car into the states.
Matt Howard is offline
Old 12-11-2002, 03:50 AM
  #505
I belive that 1 or 2 shops in the states can get them ..but there not an Official Importer though..
Sure do very similar. but for the Barracuda ..it's much easier to work on, very simple design that works well..
Red
Blue
Pink
Purple
Silver(Speedway PAL version)
Only weak points on the Barracuda is the A-arms & motor mount..(best to upgrade to the One Flag or the Square one...or Product D)
-Dave
Old 12-11-2002, 09:36 AM
  #506
Default Hi JDM
YGPM
DoCoMo is offline
Old 12-11-2002, 10:12 AM
  #507
Cool Back to ya'
YGPM
Check yours
-Dave
Old 12-11-2002, 11:48 AM
  #508
LeoChan's Avatar
Default Fai
Fai :
You want time go to PYC play Barracuda ?
I'm also SAT in PYC test new product from barracuda .
LeoChan is offline
Old 12-11-2002, 03:00 PM
  #509
Thanks Dave do you have a web site for the car? I would wanna get the puprle one to look like I had a pro4
thansk
teamAE is offline
Old 12-11-2002, 10:13 PM
  #510
fai
Regional Moderator
fai's Avatar
Default Re: Fai
Originally posted by LeoChan
Fai :
I frequently run at Kai Tak (Friday night, after work) instead of going to PYC!! You know, I lived in HK side and it's really a long way to go to Fan Ling!
I missed my days at PYC also... Wish to meet you so!
fai is offline
