Old 12-07-2002, 08:41 AM   #466
JDM_DOHC_SiR's Avatar
Trader Rating: 31 (100%+)
JDM-just wondering if the offset ball head that is on yur bud's car iwas install the correct way....shouldnt the hex shaped thng be on the chassis???os is it installed the way it is for ease of adjustment??
No they put them on that way for 2 reasons
1) If hit really hard the ball wont pop off.
2) you can adjust the hex head easier when it's on top
Hope this helps
-Dave
Ȼ4.5 Centro+α ◊ TRF 501ӽ ◊ TRF 502ӽs ◊ TRF 503 ◊ TRF 511 ◊ TRF 201ӽr ◊ TRF 211ӽ
B5m ◊ T5m ◊SC5m ◊ B64deez nutz
Speedway PAL ◊ SDRC ◊ Shop UFO ◊ SMC
JDM_DOHC_SiR is offline   Reply With Quote
Old 12-07-2002, 08:56 AM   #467
LeoChan's Avatar
Send a message via ICQ to LeoChan
sorry is mid JAN onsale !
LeoChan is offline   Reply With Quote
Old 12-07-2002, 09:23 AM   #468
Thumbs up
I thought so....hehe
-Dave
Old 12-07-2002, 10:21 AM   #469
Hope this helps
-Dave
JDM-if installed that way do i need to put some spacers under the ball head coz the arms will hit the chassis...not sure though will try it later...but i think surely u need to put spacer on it coz difference of arm height when installing the ball head that way
fReShJiVe is offline   Reply With Quote
Old 12-07-2002, 10:30 AM   #470
Talking .5mm or .75mm spacer
Yes you should use a .5mm~.75mm spacer....but you can use larger if you want a lower roll center..
-Dave
Old 12-07-2002, 10:39 AM   #471
thanks for the reply jdm!!
Old 12-07-2002, 10:57 AM   #472
Wink No problem
-Dave
Old 12-08-2002, 10:42 AM   #473
hi all,
should there be a freeplay when assembling the shaft...what i meant of freeplay is forward and backward movement of the shaft....or should it be tight fit??
thanks
Old 12-08-2002, 11:13 AM   #474
Cool 1/8 inch or 2mm play is best
it should have about this much play in the shaft..just in case you get into a "SMALL" crash
-Dave
Old 12-08-2002, 11:49 AM   #475
jdm- thanks ...u seems to be a walking Alex Racing Barracuda dictionary
Old 12-08-2002, 12:07 PM   #476
Talking No problem
Glad to be of service
-Dave
Old 12-08-2002, 12:48 PM   #477
jdm- i will need more of this service once i get this car running....
Old 12-08-2002, 12:56 PM   #478
Thumbs up
Sure. I have some good set up's for different type's of track's so just hit me up when you need them
-Dave
Old 12-08-2002, 09:24 PM   #479
Diva's Avatar
Send a message via Yahoo to Diva
There is one important reason for inverting the ball heads - you can lower your roll-centre by mounting the hex on top since the arms will be lowered. I saw one driver (expert) installed this way at his front arms. I haven't tried myself but his car is really rocket!!!!
This car has tons of setting parameters. Hence lots of fun (or troublesome).
Diva is offline   Reply With Quote
Old 12-08-2002, 10:04 PM   #480
fai
Regional Moderator
fai's Avatar
Originally posted by Diva
There is one important reason for inverting the ball heads - you can raise your roll-centre by mounting the hex on top since the arms will be lowered. I saw one driver (expert) installed this way at his front arms. He said that will improve the cornering speed. I haven't tried myself but his car is really rocket!!!!
I read through the setting sheet of the champion of JMRCA 23T: he inverted all eight hex balls upside-down, and then placed 0.5mm shims under the front balls of front A-arms and front balls of rear A-arms!
Diva, does the expert set it in this way??
fai is offline   Reply With Quote
WTB Alex Racing Barracuda R2 & R3 Funkymojo R/C Items: Wanted to Buy 3 02-03-2007 01:00 PM
alex racing barracuda con81 Electric On-Road 1 12-14-2005 03:36 AM
WTT: Alex Racing Barracuda R2 for PS2 AZ_Ron Other Items: For Sale/Trade or Wanted to Buy 0 02-13-2005 07:30 PM
Alex Racing Barracuda R3-New. rcracing1973 R/C Items: For Sale/Trade 9 04-11-2004 08:29 AM
Alex Racing Barracuda Bugs Bunny Singapore R/C Racers 6 01-22-2003 11:47 PM
