Old 09-29-2003, 03:17 PM   #4756
highwayman's Avatar
Thanks dave...
im building my R2 now and was thinking of putting in the pal hubs, anyway, will just stick to the stock set-up first...
any building tips? for today, i was just able to prep my chassis, upper deck, and shock towers, and build the drive shafts... tom, hopefully, the rest of the car...
what shock oils do you use? do you always have the same oil in front and rear? any suggestions with regards the springs, if im running on a bumpy track, with low traction?
highwayman is offline   Reply With Quote
Old 09-29-2003, 03:50 PM   #4757
Randy Caster's Avatar
Trader Rating: 46 (100%+)
Originally posted by JDM_DOHC_SiR
dry type- little to no grease( hence the word dry in the name)
Standard...a higher grade normal bearing..but without the normal bearing grease..squats special grease)
-Dave
The Squat dry bearings actually had more oil in them than my Acer bearings did, I didn't know why they had the "dry" name...
Old 09-29-2003, 03:50 PM   #4758
JDM_DOHC_SiR's Avatar
Trader Rating: 31 (100%+)
The stock kit springs will work just fine for your set up...also try 35w all the way around with a HPI#2 pistion or drill the stock ones out to 1.2mm and make sure you keep the long arm set up since it`s a bumpy/dusty low tracking track
-Dave
Ȼ4.5 Centro+α ◊ TRF 501ӽ ◊ TRF 502ӽs ◊ TRF 503 ◊ TRF 511 ◊ TRF 201ӽr ◊ TRF 211ӽ
B5m ◊ T5m ◊SC5m ◊ B64deez nutz
Speedway PAL ◊ SDRC ◊ Shop UFO ◊ SMC
JDM_DOHC_SiR is offline   Reply With Quote
Old 09-29-2003, 03:51 PM   #4759
Thanks dave...
For setups, check out the Alex USA site, and take a look at the SoCal no swaybar setup, works pretty well on all of the tracks I've driven it on, definately a good starting point.
Old 09-29-2003, 03:55 PM   #4760
Regional Moderator
R/C Tech Charter Subscriber
The reedy set up is good also
Ko Racer is offline   Reply With Quote
Old 09-29-2003, 03:56 PM   #4761
Reedy setup works on lower grip tracks..
Old 09-29-2003, 04:07 PM   #4762
Herminator's Avatar
Send a message via ICQ to Herminator
I'd start with kit setup, it's pretty good. And go with JDM's shock suggestions, he should know
Been at the club again tonight, a nice 3rd on the grid and a safe 3rd at the end of the A final, quite an uneventful night, but atleast my mini pins are getting worn in so getting grip finaly.
Herminator is offline   Reply With Quote
Old 09-29-2003, 04:07 PM   #4763
Regional Moderator
Im just saying it was a GOOD set-upand he said he is running lower traction track
Old 09-29-2003, 04:11 PM   #4764
Herminator's Avatar
Dave hows that postie going?
Whats the time there BTW?
Old 09-29-2003, 09:47 PM   #4765
it's going.... no news yet
-Dave
Old 09-30-2003, 10:21 AM   #4766
TC3
TC3's Avatar
-Dave
i wanted to drill out the pistons to 1,2mm, but mine are allready 1,2mm
i could just put the 1,2mm drill into the hole without removing any material
maybe u mean the smaller stock pistons, because the kit comes with 2 different
TC3 is offline   Reply With Quote
Old 09-30-2003, 10:48 AM   #4767
I actually found the HPI pistons closer to 1.15, that's what I've been drilling all of my pistons out to. I also just ran 40wt front and back, never switched. Guess I've been running heavier dampening with my setup.
Old 09-30-2003, 05:28 PM   #4768
Really your Triox came with the 1.2mm pistons..?
-Dave
Old 09-30-2003, 05:30 PM   #4769
Dave - What size are the teflon pistons from Alex?
Old 09-30-2003, 05:33 PM   #4770
Herminator's Avatar
Hmm, maybe thats where the 80 difference goes, on an extra set of pistons
WTB Alex Racing Barracuda R2 & R3 Funkymojo R/C Items: Wanted to Buy 3 02-03-2007 01:00 PM
alex racing barracuda con81 Electric On-Road 1 12-14-2005 03:36 AM
WTT: Alex Racing Barracuda R2 for PS2 AZ_Ron Other Items: For Sale/Trade or Wanted to Buy 0 02-13-2005 07:30 PM
Alex Racing Barracuda R3-New. rcracing1973 R/C Items: For Sale/Trade 9 04-11-2004 08:29 AM
Alex Racing Barracuda Bugs Bunny Singapore R/C Racers 6 01-22-2003 11:47 PM
