Old 09-26-2003, 07:40 PM   #4711
highwayman's Avatar
Originally posted by JDM_DOHC_SiR
well in stock for with PAL hubs and a PAL drive system it did quite well at the Last JMRCA Race.. "with a Mod motor"
-Dave
we noticed the pal hubs are quite shorter than the original hubs... how does it affect handling?
also, randman mentioned in the losi forum that you figured out how to make the R2 run quieter... pls do share... thanks.
- jason
highwayman is offline   Reply With Quote
Old 09-26-2003, 07:50 PM   #4712
Regional Moderator
R/C Tech Charter Subscriber
Originally posted by highwayman
what new chassis if i may ask?
here is the pal new chassis kit
Ko Racer is offline   Reply With Quote
Old 09-26-2003, 08:54 PM   #4713
JDM_DOHC_SiR's Avatar
Trader Rating: 31 (100%+)
- jason
Well it has to do with the shimming of the bevel gear and using a new front one way gear and rear diff gear.. .... I posted it a few pages back on the R2 thread
-Dave
Ȼ4.5 Centro+α ◊ TRF 501ӽ ◊ TRF 502ӽs ◊ TRF 503 ◊ TRF 511 ◊ TRF 201ӽr ◊ TRF 211ӽ
B5m ◊ T5m ◊SC5m ◊ B64deez nutz
Speedway PAL ◊ SDRC ◊ Shop UFO ◊ SMC
JDM_DOHC_SiR is offline   Reply With Quote
Old 09-26-2003, 09:03 PM   #4714
Regional Moderator
ImGoinRCn's Avatar
Send a message via Yahoo to ImGoinRCn
Are the pals hubs better than the xenon ones that steve sells at speedtech?
When all else fails, aim for the quarter panel.
Several oval and off road vehicles
and a legend car nicknamed Kidney Stone.
X Factory R/C SCX-60CF
X Factory R/C X-6
ImGoinRCn is offline   Reply With Quote
Old 09-26-2003, 09:07 PM   #4715
there not better or worse.... it just depends on what type of racing you do and what type of layout..... the PAL hubs are more set up for MOD/carpet or High bite tracks.... the Xenon ones are also good beacuse the are 7 deg vice the normal or square ones that are 5 deg..
just depends on what type of racing you do... for me I have one with the Square / Xenon hubs and all of the rest have the PAL hubs
-Dave
Old 09-26-2003, 09:15 PM   #4716
Regional Moderator
ImGoinRCn's Avatar
-Dave
It will be with foams, on carpet, w/ those new 19 turn hand wound motors...does that help? I was going to switch over to the midspan arms...should I keep the front one way? The car handled pretty well with stock setup, 80 wt oil, #2 pistons, stock springs...I had the rear c hubs that takes some rear toe out of it...Can you use any of those hubs on pavement? Thanks Dave.
X Factory R/C X-6
Old 09-26-2003, 09:20 PM   #4717
lets just put it this way... the springs that come with the kit and the rear hubs that have the tons of toe with the long span a-arms you can make this car rock..... trust me it works..( on almost any track.....but So Cal it seems )
-Dave
Old 09-26-2003, 09:54 PM   #4718
Regional Moderator
ImGoinRCn's Avatar
-Dave
even with the stock rear hubs? my car is about stock besides the rear hubs...I only raced it once on carpet, 5 times, if that on pavement...I want some carpet...make them eat their yokes, choke on their tc3s and loose with their losis...you know what I mean brotha??
X Factory R/C X-6
Old 09-27-2003, 03:06 AM   #4719
Can anyone suggest good gearing for a Matrix V10R 27x1 and a 19 Turn Spec. I run on carpet and a polished wood spors hall floor.
Dude-San is offline   Reply With Quote
Old 09-27-2003, 08:53 AM   #4720
John_S's Avatar
well with my mvp on wood i run a 70/23 and it seems to keep up quite well with the other guys
John_S is offline   Reply With Quote
Old 09-27-2003, 09:01 AM   #4721
Regional Moderator
ImGoinRCn's Avatar
we gear our 19 turns more than our stocks.
X Factory R/C X-6
Old 09-27-2003, 10:01 AM   #4722
Herminator's Avatar
Send a message via ICQ to Herminator
A lot depends on the size of your hall and the layout.
I've used the Matrix V10R indoors on a basketball court sized wooden floor with 70/22 and it seems quite good. Recently I've been using my old Green Machine 3 which is also a revy motor but it seems the MAtrix always likes more revs as I find a 23tooth pinion is heaps better than one either side of it for the GM3.
The Matrix 19turn I've only really used outdoors on tarmac, on a huge track I'd gear it around 5.0, on a normal sized track I'd gear it around 6.0. Indoors on carpet I'd start with a larger pinion than the 27turn, it has a heap of torque compared to the high rpm stocks (that includes both matrix stocks, one may be classed as the torque version but it still is a high rpm motor)
Herminator is offline   Reply With Quote
Old 09-27-2003, 10:10 AM   #4723
Randy Caster's Avatar
Trader Rating: 46 (100%+)
Originally posted by rc-zombies
let me know what you've got for a set-up...
carpet season is about to start next month....
we have
stock with Rubber tires...
spec 19 w/foams.
& Mod w/foams.
Who runs carpet in Cali? I didn't even know there was a carpet track left...
Old 09-27-2003, 10:15 AM   #4724
Have you guys heard of TD design?
http://www.team-td.net/
looks like they do some very nice paint jobs...
They do look good... I wonder if that is actually Pavidis' body, seeing as how it's a Losi Alfa, I'm guessing not. He was running his protoform bodies last Tuesday.
Old 09-27-2003, 10:17 AM   #4725
-Dave
They are propably 30 pages back by now, did Steve ever add them to the Alex USA site?
WTB Alex Racing Barracuda R2 & R3 Funkymojo R/C Items: Wanted to Buy 3 02-03-2007 01:00 PM
alex racing barracuda con81 Electric On-Road 1 12-14-2005 03:36 AM
WTT: Alex Racing Barracuda R2 for PS2 AZ_Ron Other Items: For Sale/Trade or Wanted to Buy 0 02-13-2005 07:30 PM
Alex Racing Barracuda R3-New. rcracing1973 R/C Items: For Sale/Trade 9 04-11-2004 08:29 AM
Alex Racing Barracuda Bugs Bunny Singapore R/C Racers 6 01-22-2003 11:47 PM
