Barracuda from Alex racing >
Like Tree1Likes
Old 09-11-2003, 01:27 AM
  #4456
R/C Tech Elite Member
Randy Caster's Avatar
Trader Rating: 47 (100%+)
Originally posted by Ko Racer
Whats flex
I'm kinda expecting the Xenon car to have a little bit still...
Randy Caster is offline
Old 09-11-2003, 01:40 AM
  #4457
JDM_DOHC_SiR's Avatar
Trader Rating: 31 (100%+)
Originally posted by Randman
How is the flex between the PAL and Xenon cars?
[email protected] answer is none and even less
-Dave
JDM_DOHC_SiR is offline
Old 09-11-2003, 01:42 AM
  #4458
-Dave
Damn, sounds nice, can't wait to see it in person
Old 09-11-2003, 01:54 AM
  #4459
don`t know might be a long time..
Old 09-11-2003, 02:18 AM
  #4460
Regional Moderator
ImGoinRCn's Avatar
Originally posted by Fasttrak
Thanks a ton guys, from now on when I get crap for being anal with regards to my car, I can now send them here and prove I am only picky
Shouldn't use the words, anal and crap in the same sentence on here. Someone may give you ahard time about that...lol...can you tell I'm still tired...lol...
ImGoinRCn is offline
Old 09-11-2003, 09:26 AM
  #4461
cHckbOY5's Avatar
are there any good cudas at the jmrca race?
cHckbOY5 is offline
Old 09-11-2003, 12:37 PM
  #4462
Well I figured since I got the Evo 3 Surikarn to compare to the R2, I'll let you guys know what I think.
So far, I have only run a stock motor in the Evo 3, with a bone stock setup for the first day, trying to see how the car handles. The car definately has less roll in stock form, but when I lengthened the rear camber links to get more roll, the car just got extremely loose, undriviable actually.
I ran into the front ring gear problem, stripped 2 of them, although I was told of a possible way to solve the problem, which I will try this next week, with a BL motor.
First impressions is it's a very nice car, with very similar handling to the R2, some things are very easy to work on, but others are hard (the upper deck has 14 screws!) I put Acer ceramic bearings in the car, so the drivetrain was definately more free than the R2, it spun for 16 seconds before I even broke it in... Besides the ring gear problem, the car is very durable, didn't break any other parts than that, but I did get hit pretty hard one time, and it sent the car out of tweak to where I could barely drive it (actually pulled out of the main it was so undriviable)
I'll see how it goes next week, from what I've been told, it reacts to changes very similar to how the R2 does, so I should be able to find a setup pretty quickly for it.
Old 09-11-2003, 01:24 PM
  #4463
Herm - You're gonna kill me, but my comp got wiped out (for a second time) by that XP worm, and I need the link to the gear ratio calculator again...
Old 09-11-2003, 01:28 PM
  #4464
rc-zombies's Avatar
try this:
http://www.rcracing.com/Gear_Ratio_Program_1100.cfm
rc-zombies is offline
Old 09-11-2003, 01:30 PM
  #4465
Originally posted by rc-zombies
try this:
Nice, that's the same program as on the other site, thanks Ramon
Old 09-11-2003, 01:35 PM
  #4466
Herminator's Avatar
Try updating windows it has an automatic fix to stop that worm getting in
plenty of RC sites use that ratio calculator, I found it originaly on the RC Lab site, there they have it modified with RC Lab ratio's only in the drop down menu though. Arroyc make it and on their websitethey have put the Barracuda in but it's wrong, 2.43 I think they have it as
Herminator is offline
Old 09-11-2003, 01:38 PM
  #4467
rc-zombies's Avatar
On Arroyc's.... you can costomize it and type in and final drive ratio you need...
I know the guy he's a programmer ... he's one of the local racers at Speedworld.
Old 09-11-2003, 02:18 PM
  #4468
Regional Moderator
ImGoinRCn's Avatar
Maybe pinky came back for a little revenge on you...j/k
Old 09-11-2003, 02:22 PM
  #4469
Regional Moderator
ImGoinRCn's Avatar
Default 9-11-01
I know this isn't R/C related but thought I'd share this.
http://home.comcast.net/~sept11/
Old 09-11-2003, 03:01 PM
  #4470
I'm running a one of a kind internal drive ratio right now, so I had to custom make my ratio chart. Came out good though
