Old 12-02-2002, 04:49 PM   #421
LeoChan's Avatar
Send a message via ICQ to LeoChan
Tomorrow send to you !
LeoChan is offline   Reply With Quote
Old 12-02-2002, 08:56 PM   #422
purplepro3's Avatar
I am really interested in the Barracuda. These are my questions:
1. How does it compare to the TC3 and the Evo 1/2/3?
2. What are the "must have" hop ups for the car?
3. Why change to short arms? Isn't long arms better?
purplepro3 is offline   Reply With Quote
Old 12-03-2002, 04:56 AM   #423
JDM_DOHC_SiR's Avatar
Trader Rating: 31 (100%+)
Wink Barracuda..info
Well The TC3 is really a good shaft carfrom the start ..so is the EVO series...But in Japan.. the Barracuda does very well against the TC3... about the same following for shaft driver's over here ..as far as the EVO's.??? not to may in my neck of the woods here in Japan.. But the EVOIII might do quite well.?? Time will tell after the 15th of Dec..
For starters... the 2 Big ones are the SUS Arms by PAL or Square and Drive shaft motor mount kit buy One Flag or Square.. also it would be a good idea to get the Aluminum shaft holders for the front and rear bulk heads too
Well the Cuda' comes with some really flexable Sus Arms' so it needs some help in this area from the start.. ..But either set up will work just fine..the Speedway PAL arms or the Square Nylon ones.... Much better feeling car when you upgrade this item
But the thing that makes this Car a seller in my book is that its so damn easy to work on.. easy to get to every thing!!! unlike working on my Pro3 Hara Edition...!!
My 2 ₯en
-Dave
Ȼ4.5 Centro+α ◊ TRF 501ӽ ◊ TRF 502ӽs ◊ TRF 503 ◊ TRF 511 ◊ TRF 201ӽr ◊ TRF 211ӽ΅
B5m ◊ T5m ◊SC5m ◊ B64deez nutz
Speedway PAL ◊ SDRC ◊ Shop UFO ◊ SMC
JDM_DOHC_SiR is offline   Reply With Quote
Old 12-03-2002, 05:05 AM   #424
LeoChan's Avatar
After will have new Japan co. ( Product D ) ,this co. is by ALEX date & driver to test !
this co. will onsale new motor mount & alunium gear for Barracuda
Old 12-03-2002, 08:14 AM   #425
Talking Picture of rear PAL sus
Not the best picture in the world...but it gives you a general Idea were they go
Old 12-03-2002, 08:46 AM   #426
You got PM.
DoCoMo is offline   Reply With Quote
Old 12-03-2002, 09:46 AM   #427
Here's a shot of my buddys arms that have epoxy resin in the sus arm gaps to make them more rigid ..might be a good idea for some of you DIYr's out there
Old 12-03-2002, 09:51 AM   #428
dtm
dtm's Avatar
Send a message via ICQ to dtm
You need to ask Leo about his mod to the A arms to make it "really" stiff!!
dtm is offline   Reply With Quote
Old 12-03-2002, 11:52 AM   #429
LeoChan's Avatar
68ball.jpg can give you more turn ,
but need change shock about 62mm-62.5mm
Old 12-03-2002, 11:55 AM   #430
LeoChan's Avatar
this type is very soft arm
please use COMET #6505 700yen is hard type arm !
Old 12-03-2002, 12:02 PM   #431
LeoChan's Avatar
COMET , ALEX ,PAL ,XENON same is 1 boss
COMET , ALEX ,PAL ,XENON & after onsale ( PRODUCT D ) ,
same is 1 designer .!!
Old 12-03-2002, 12:10 PM   #432
Default Attn:JDM
Hey dude,
I think you need to clean your PM in box.
You got new PM.
Old 12-03-2002, 12:27 PM   #433
Talking Cleaned it out...
Try again..hehhe
-Dave
Old 12-03-2002, 03:42 PM   #434
purplepro3's Avatar
jdm_sohc_sir: thanks for the info. so if i ever buy one, i also need to get new suspension arms, motor mount, and al. shaft holders? why change the stock motor mount? what is its flaw?
also, how tough is the car on the track? i have a pro2 and hara pro3 which are quite indestructible...i would not want to have a tc3/yoke kind of breakage problem. thanks again.
Old 12-04-2002, 12:53 AM   #435
PizzaDude's Avatar
Hi All,
I'm trying not to go off topic here.
But....
I understood that the Alex CE-4 (a car which I really have a soft spot for, but because of no parts-supply never bought) was a force to be reckoned with in Japan.
How does it compare with all the Barracuda versions out there nowadays? (handling power strength of parts)
Also which of the Barracuda versions does have what kind of advantage over the other.
Please try not to explain the kit differences, but rather what these difference do on-track for you!
Do you notice the differences?!
pfew a lot of questions alltogether.
Pizza
PizzaDude is offline   Reply With Quote
WTB Alex Racing Barracuda R2 & R3 Funkymojo R/C Items: Wanted to Buy 3 02-03-2007 01:00 PM
alex racing barracuda con81 Electric On-Road 1 12-14-2005 03:36 AM
WTT: Alex Racing Barracuda R2 for PS2 AZ_Ron Other Items: For Sale/Trade or Wanted to Buy 0 02-13-2005 07:30 PM
Alex Racing Barracuda R3-New. rcracing1973 R/C Items: For Sale/Trade 9 04-11-2004 08:29 AM
Alex Racing Barracuda Bugs Bunny Singapore R/C Racers 6 01-22-2003 11:47 PM
