Old 09-01-2003, 02:27 PM   #4141
Randy Caster's Avatar
Trader Rating: 46 (100%+)
Just so you guys know, I own one of Ko's old cars, and it is just as described by him.
Rocketron's stuff is awesome too, he definately knows what he's doing, been in the hobby a long time, and is a great guy.
Old 09-01-2003, 03:44 PM   #4142
JDM_DOHC_SiR's Avatar
Trader Rating: 31 (100%+)
???sheesh...while were at it I have 2 Cudas for sale too ...
One Purple R2 with EVERY THING...and a BLUE R2 with every thing...
Both have drive systems and full ti and alloy...I mean every thing!!..Oh yea brand new Squat dry bearings in both cars to boot
PM me if any of you might want one... I give it a week before they go on sale on Yahoo Japan..
I`ll have Pic`s later today..
-Dave
Ȼ4.5 Centro+α ◊ TRF 501ӽ ◊ TRF 502ӽs ◊ TRF 503 ◊ TRF 511 ◊ TRF 201ӽr ◊ TRF 211ӽ
B5m ◊ T5m ◊SC5m ◊ B64deez nutz
Speedway PAL ◊ SDRC ◊ Shop UFO ◊ SMC
JDM_DOHC_SiR is offline   Reply With Quote
Old 09-01-2003, 04:03 PM   #4143
Herminator's Avatar
Send a message via ICQ to Herminator
Stop this guys, you're confusing my poor little mind what to do....?
new car, new second hand car, just upgrade mine to the eyeballs...... ARGH! If only one of them was red, I'd be even more tempted
Herminator is offline   Reply With Quote
Old 09-01-2003, 04:07 PM   #4144
Gazza_D's Avatar
Send a message via Yahoo to Gazza_D
So Pete,
how was racing tonight???? and how was that new track marking sytem thingy they were going to use????
Be interesting to know if it was any good, or whether cars were launched as predicted.
Gazza_D is offline   Reply With Quote
Old 09-01-2003, 04:19 PM   #4145
Maj. Teeth's Avatar
-Dave
I don't think a pic will do it's justice. We all know how well you've kept your cars. Ill PM you since I'm looking for another one. Not trying to follow Randy's footstep by all means.
Dan
Maj. Teeth is offline   Reply With Quote
Old 09-01-2003, 04:23 PM   #4146
Herminator's Avatar
The track system arrived at 5pm so we didn't get to use it because it needs a bit of prep work, like sticking the velcro pads to it so it locks together. Should be all singing and dancing by next week though
Racing was ok for the first week back to it, although the lower heats were messier than ever. I spent most of the night wondering why my car was so slow out of corners, going down so far on the pinion that I could barely mesh the gears I ended up with 21/70, which seems about right as any bigger on the pinion and the motor gets too hot, and the Matrix V10R doesn't like getting hot, it's a revvy little sucker. I think the motor must be very dirty inside after running at Falkirk, since I still couldn't keep up with the top three guys at all.
I ended up going one spring rate softer all round to get some corner grip, moved the rear mounting positions in one hole top and bottom, thank god I bought the quick change upper shock mounts I can get them off with just undoing one nut, just takes moving the suspension to the right spot. Car is pretty nicely balanced but I may go another step softer all round again, see if I can get even more grip and corner speed. Nice to have a proper range of springs that all fit perfectly, counting coils isn't too tricky either.
Qualified 4th in the A final and finished 2nd as two ahead of me had problems where they lost a couple laps. Hopefully I'll give them more of a challenge next week with a clean motor, some more decent voltage batteries will help too instead of just the two I have now.
Old 09-01-2003, 05:44 PM   #4147
Herminator's Avatar
-Dave
you got PM
Old 09-01-2003, 06:28 PM   #4148
I finally got to see pictures of Ko's Web Special, all I can say is "Oh my god!". That car is almost too damn pretty to even think of setting down on a carpet track, it would be very hard for me to even think of setting that car down on pavement. His car almost looks like an engineering one off model stored in some designers showcase, Smithsonian maybe.
Fasttrak is offline   Reply With Quote
Old 09-01-2003, 07:27 PM   #4149
Herminator's Avatar
After going to further in shock mounting positions on the rear I noticed how big a problem the long shock bodies are, at one point I has about a milimeter of up travel on the shock until it hit the bottom, not good. It certainly looks like shorter bodies are next on my list. Just wondering if you guys still use the inner spacer on the rear shocks, like the manual has, to limit down travel, when using shorter bodies on the rear.
It's such a silly problem, it owuld be much easier if Alex Racing just used the shorter bodies all round, makes no sense really. Would be a good idea if Steve asked them to change the spec for his kits wink wink Steve
Old 09-01-2003, 07:28 PM   #4150
Regional Moderator
R/C Tech Charter Subscriber
Thank you very much and im glad you enjoyed the pic's
Ko Racer is offline   Reply With Quote
Old 09-01-2003, 08:16 PM   #4151
Dan
Back at cha'
Old 09-01-2003, 08:34 PM   #4152
Don't worry Hermi' the Japanese have allready made the comment to ALEX Racing about it.. haahaaha ... I think that the newer kits will have the shorter bodies..?? not 100% sure thought
.. and for hte shocks.... I have never used the "STUPID" spacers in the instructions... thats why they make droop screws for..
save your self the hastle and 86 them
-Dave
Old 09-01-2003, 08:36 PM   #4153
Regional Moderator
ImGoinRCn's Avatar
Send a message via Yahoo to ImGoinRCn
-Dave
When all else fails, aim for the quarter panel.
Several oval and off road vehicles
and a legend car nicknamed Kidney Stone.
X Factory R/C SCX-60CF
X Factory R/C X-6
ImGoinRCn is offline   Reply With Quote
Old 09-01-2003, 08:38 PM   #4154
thay could be made and color for the right ammount of $$
-Dave
Old 09-01-2003, 08:39 PM   #4155
Originally posted by Randman
Ya gotta think fast Dan, you werent late when you got your Web Special, so I know ya got it in ya
hahhaha
Super Shoppers...
-Dave
WTB Alex Racing Barracuda R2 & R3 Funkymojo R/C Items: Wanted to Buy 3 02-03-2007 01:00 PM
alex racing barracuda con81 Electric On-Road 1 12-14-2005 03:36 AM
WTT: Alex Racing Barracuda R2 for PS2 AZ_Ron Other Items: For Sale/Trade or Wanted to Buy 0 02-13-2005 07:30 PM
Alex Racing Barracuda R3-New. rcracing1973 R/C Items: For Sale/Trade 9 04-11-2004 08:29 AM
Alex Racing Barracuda Bugs Bunny Singapore R/C Racers 6 01-22-2003 11:47 PM
