Old 08-27-2003, 09:06 AM   #4021
Randy Caster's Avatar
Trader Rating: 46 (100%+)
Default Re: Re: PINKY does SoCal
Originally posted by JDM_DOHC_SiR
Hmmm Nice Pic`
So what did you guys have to sort out.??
-Dave
Basically I worked on spring combos all night, the car is good, but there is an understeer with the brushless motor that is impossible to get out. Dave got somewhat of a fix last night, but I'll be joining the tuning race too, and hopefully we can get this car dialed
Old 08-27-2003, 03:07 PM   #4022
JDM_DOHC_SiR's Avatar
Trader Rating: 31 (100%+)
Default Re: Re: Re: PINKY does SoCal
I don`t have a Novak BL system..but I do have a HACKER one..I hould give a spin to see if I can helo you all with this understeer problem..
-Dave
Ȼ4.5 Centro+α ◊ TRF 501ӽ ◊ TRF 502ӽs ◊ TRF 503 ◊ TRF 511 ◊ TRF 201ӽr ◊ TRF 211ӽ
B5m ◊ T5m ◊SC5m ◊ B64deez nutz
Speedway PAL ◊ SDRC ◊ Shop UFO ◊ SMC
JDM_DOHC_SiR is offline   Reply With Quote
Old 08-27-2003, 03:27 PM   #4023
I'm gonna make a bundle of changes to the car before next week, I'll post my progress and let you guys know what I do.
Old 08-27-2003, 03:40 PM   #4024
..OK did you use the shim under the rear A-arm balls yester day..??
-Dave
Old 08-27-2003, 03:48 PM   #4025
-Dave
I only have 1 set of shims, so I'm ordering another set right now, I want them to still be at the same height... Although the new setup may include some anti-squat...
Old 08-27-2003, 03:54 PM   #4026
Herminator's Avatar
Send a message via ICQ to Herminator
If you're having problems with the brushless letting the car freewheel into corners so much and causing understeer, have you tried the handy trick of braking?
On a more serious side, I have my speedo set up so there is practicly no drag brake when the throttle is at neutral, there is basicly a notch or two of throttle trim up. I do get understeer when off powere but put the power on and the front hooks up again, or if you going fast into a slow corner then use those magical brake thingy's then I use the on power steering to make it around the corner
Herminator is offline   Reply With Quote
Old 08-27-2003, 03:58 PM   #4027
I have been using the brakes... a lot, but I really dont like using them, I want to get the car setup so that I can go neutral into the corners, not hit the brakes.
Old 08-27-2003, 05:20 PM   #4028
Herminator's Avatar
The setup I liked so much on Monday, really good for powering around hairpins Droop settings need working on but I didn't have the time, possibly could be used to get rid of some off power understeer, initial turn in is nice but between that and mid corner it will drift wide if you try carrying too much speed off power. CS22's will have helped but mine are knackered and have unbalanced the car in the past making the rear step out.
Old 08-27-2003, 06:05 PM   #4029
That setup is fairly close to what I was running yesterday. You might want to try 5mm ride height all around. You're running high in the front, and low in the back, if the car is pushing, you're transfering too much weight to the rear tires, reduce that by changing the ride height.
I wish we had more caster blocks to chose from, a 8-10 degree block might solve our understeer problem...
Old 08-27-2003, 06:12 PM   #4030
Herminator's Avatar
The front is heigh because I'm using RC Lab pinks springs up front, they are a little too long, and 5.5 is the lowest I can get
Got Alex Racing springs on the way now from Steve
The rear is low because, well I didn't have a ride height gauge with me and I kept lowering it tiny amount to gain stability at Stonehaven
Old 08-27-2003, 06:39 PM   #4031
I just ordered a few more sets of springs from Steve as well, I'm close to the whole connection You might want to try some rear anti-squat, and front kickup as well to help that understeer. I'll be testing all of that next week.
Old 08-27-2003, 06:47 PM   #4032
Herminator's Avatar
you must have stolen the second pair of 6.50x1.4mm springs I wanted then I should have plenty to play with for now though...
moving indoors now so not much chance to play with that setup, time to see how it goes on the wooden floor again....
Old 08-27-2003, 07:12 PM   #4033
I ordered the 6.5x1.4 some time ago, so I'm guessing someone else stole that pair from ya
Old 08-27-2003, 09:36 PM   #4034
thats the same way that I drive....no Brakes ... anyways I"ll be working ona brushless set up here in about a week so I"l be able to see what you guys are talking about ....very little drag brake with the Brushless it seams...so I will have to work on a set up that works well under half power
-Dave
Old 08-27-2003, 09:41 PM   #4035
Very little drag brake is not the right phrase, more like no drag brake anywhere to be seen. Seriously, even with the motor in the car, when I spin the tires, they go for 3 secs...
On that note, I spun my tires yesterday, and Dave got a 16 count of the transmission, definately smoooooth
WTB Alex Racing Barracuda R2 & R3 Funkymojo R/C Items: Wanted to Buy 3 02-03-2007 01:00 PM
alex racing barracuda con81 Electric On-Road 1 12-14-2005 03:36 AM
WTT: Alex Racing Barracuda R2 for PS2 AZ_Ron Other Items: For Sale/Trade or Wanted to Buy 0 02-13-2005 07:30 PM
Alex Racing Barracuda R3-New. rcracing1973 R/C Items: For Sale/Trade 9 04-11-2004 08:29 AM
Alex Racing Barracuda Bugs Bunny Singapore R/C Racers 6 01-22-2003 11:47 PM
