Barracuda from Alex racing >
Like Tree1Likes
Old 08-27-2003, 12:44 AM
  #4006
cHckbOY5's Avatar
hey proudwinner, plannin on joining the alex crew?
cHckbOY5 is offline
Old 08-27-2003, 12:45 AM
  #4007
RedBullFiXX's Avatar
Trader Rating: 34 (100%+)
Default PINKY does SoCal
RandMan broke her in good tonite, few little bumps to sort out but it was fun runnin with him & Pinky
RedBullFiXX is offline
Old 08-27-2003, 12:48 AM
  #4008
Neil Rabara's Avatar
Not the best picture of pinky, and the car too.
Neil Rabara is offline
  #4009
cHckbOY5's Avatar
its more a pic of randman
cHckbOY5 is offline
Old 08-27-2003, 12:54 AM
  #4010
Chucky, the short arms make the car nimble which I like.. I've seen this car carve corners like a pear knife on a avacado-really, no doubt Alex racing has their head in the right direction and will always like their design. I would grab one but I cannot afford it right now.
ZER01 is offline
Old 08-27-2003, 12:55 AM
  #4011
JDM_DOHC_SiR's Avatar
Trader Rating: 31 (100%+)
Default Re: PINKY does SoCal
Hmmm Nice Pic`
So what did you guys have to sort out.??
-Dave
JDM_DOHC_SiR is offline
Old 08-27-2003, 01:29 AM
  #4012
Fatboy Joe's Avatar
Originally posted by JDM_DOHC_SiR
why do you runt the transponder in the rear buy the motor..?? if anything this car needs it up front by the servo...PAL makes a nice mount so does Xenon Racing..
-Dave
Yep, I know, I'm still waiting for my stuff from Xenon and Speedway PAL to arrive. That pic was taken the night before a race and I didn't have time to drill out a hole for the Yok transponder mount up front beside the servo Will post again soon after I equipe my ride with PAL stuff
Fatboy Joe is offline
Old 08-27-2003, 01:35 AM
  #4013
Sweet let us know what parts you get in..
-Dave
Old 08-27-2003, 05:00 AM
  #4014
Regional Moderator
Originally posted by ImGoinRCn
KO, I sent you an email like you asked just in case you didn't see it.
Gotcha bro you will have some back at you today.
Ko Racer is offline
Old 08-27-2003, 05:01 AM
  #4015
Regional Moderator
Originally posted by proudwinner
I'd run it in the middle of the chass and go from there where it would be best.
proudwinner.............nice to see you here on the cuda forums
Ko Racer is offline
Old 08-27-2003, 07:18 AM
  #4016
Thanks Ko. There's alot of great information in here.
ZER01 is offline
Old 08-27-2003, 07:29 AM
  #4017
paulc's Avatar
It really is a nice fish FBJ, but mine is a tad quiet.
Had a bad finish, but i did let the guy i bumped go ahead on the last lap...finished third...the MVP sucked. Should've gotten a monster...anyways...
My fish, though its not a web special or anything but this thing helped me alot specially running against the big guns in our local track
paulc is offline
Old 08-27-2003, 08:57 AM
  #4018
R/C Tech Elite Member
Randy Caster's Avatar
Trader Rating: 47 (100%+)
Originally posted by rocketron
The std bit will work but go very slowly and do not make it deeper than you need. All you want to do is use the countersink as a centering method. So if the head isn't totally flush it really is only cosmetic. I did mine nearly flush because of the stress here I wanted as much material as possible to be left there.
Ron, sounds like you are the lifesaver today
Where were you yesterday??
Randy Caster is offline
Old 08-27-2003, 09:00 AM
  #4019
Originally posted by Herminator
Looks like you guys are crashing in style then
well I suppose if you're going to do something, you might aswell do it properly
I've actually found a slight bit of tweak in the car by brushing a corner dot... Because everything mounts off 4 bulkheads, it can tweak a bit. I'm running the titanium screws, never ran the big 2.5mm screws, do they help?
Old 08-27-2003, 09:02 AM
  #4020
Looks good, you should think about one of the aluminum servo mount/transponder mounts, they are very strong, and holds the transponder pretty low as well...
