Old 08-19-2003, 09:49 PM   #3856
JDM_DOHC_SiR's Avatar
Trader Rating: 31 (100%+)
Originally posted by Randman
Dave, just make a new instruction manual for us... in english is possible
that could be done for the right ammount of $$ sicne I have done one before.. just need to find it and make copies ....
-Dave
Ȼ4.5 Centro+α ◊ TRF 501ӽ ◊ TRF 502ӽs ◊ TRF 503 ◊ TRF 511 ◊ TRF 201ӽr ◊ TRF 211ӽ
B5m ◊ T5m ◊SC5m ◊ B64deez nutz
Speedway PAL ◊ SDRC ◊ Shop UFO ◊ SMC
JDM_DOHC_SiR is offline   Reply With Quote
Old 08-19-2003, 09:50 PM   #3857
Randy Caster's Avatar
Trader Rating: 46 (100%+)
Just save all the files of how-to's you post for people, and put em all together one day
Old 08-19-2003, 11:57 PM   #3858
Good Idea... I think that I`ll do that and send then out to Steve to update the ALEX Racing USA site..
-Dave
Old 08-20-2003, 08:55 AM   #3859
Sounds good
Old 08-20-2003, 03:07 PM   #3860
Herminator's Avatar
Send a message via ICQ to Herminator
OK, I need some advice for Sunday. I'll be racing at Stonehaven, a very big track.
19t's will be using all of the track in the first picture then cutting away from the main straight to go along the darker sections of tarmac in the right hand picture and back onto the main track at the bottom of the second picture.
The large corner before the straight is banked, how do you SoCal guys deal with your banked corner? keep it tight all the way around? does it upset setups a little?
I'm pretty sure I'm going to have to reduce he front end grip I'm getting, thats easily solved by moving the front upper shock mounts back in towards the standard hole. I think I may still suffer from a rear end thats not totaly stable unless I'm on the throttle atleast a third. I have the option to put the kit rear hubs on to get another 1 degree toe in but I don't want to be scrubing speed on this track, it's about as big as they come
The rear diff doesn't seem that tight but I can easily do donuts from a standstill. I'll probably note down my setup on a sheet tomorrow. Basics off the top of my head are-
1 degree front toe out
2.8 rear toe in
camber 1-1.5 all round, probably more at rear than front.
standard turnbuckle links
rear shocks on furthest out usable holes top and bottom and using kit springs.
front shocks inner holes at bottom, one out from kit at top and using Lab Pink's which are roughly the same as one step up in Alex Racing springs.
using CS27's and CS22's with supplied insirts.
Herminator is offline   Reply With Quote
Old 08-20-2003, 03:37 PM   #3861
Looks like a big track, the main thing you gotta worry about is not scrubbing too much speed in those hairpins. Start off with Dave's standard SoCal setup and go from there. You'll get used to the bank, I dont even notice the transition on the bank at SoCal anymore...
Old 08-20-2003, 03:59 PM   #3862
rtypec's Avatar
Hey Herm...here's a tip from the competition...Dial in some negative expo into your steering. It'll help you keep a tighter line around the sweeper and helps you make minute adjustments while you corner. Of course, there are those of us who have lightning finger agility so if you've got mad skills like that, then forget what I said hehe.
That'd be a sweet track if they mowed the lawn like a putting green on a golf course, widen the lanes a lot a bit (or build more options), resurface it, and spray a crap load of vht haha.
rtypec is offline   Reply With Quote
Old 08-20-2003, 04:08 PM   #3863
Herminator's Avatar
I take it you need a wide track so you manage to stay on it and very short grass for when you make one of your mistakes you can get back on easily
Not a fan of expo steering, my thinking says it should react to all finger inputs the same, if you know what I mean. May try it though, if I'm not spending the day concentrating on other things to do with setup, or staying awake
Old 08-20-2003, 04:11 PM   #3864
You dont win the Reedy race by running off the track Rod is one of the best drivers around...
Old 08-20-2003, 04:22 PM   #3865
Gazza_D's Avatar
Send a message via Yahoo to Gazza_D
Herm,
Stonehaven is a med to low grip track.....right??? So -1 deg camber front and back would be a good starting point, not so sure why you need 1 degree of toe out on the front, always run parallel on big tracks and as little toe in on the rear as i can get away with through the infield without swopping ends too often
Big track= fast top speed and carry as much of it as you can through the slower corners.....easy aint it?!?!?
Am running Cuda at Aldershot on Friday, its a big track with a banked sweeper, will let you know what I find out on Friday night if you like.
Gaz
Gazza_D is offline   Reply With Quote
Old 08-20-2003, 05:17 PM   #3866
I'm tryin to get some decals made for the Barracuda, but I want them to be the same text as the Barracuda logo on the box. Does anyone have a large image of that logo that I can have?
Old 08-20-2003, 08:21 PM   #3867
RedBullFiXX's Avatar
Trader Rating: 34 (100%+)
Wink Decisions Decisions
As you can see it is never a question of making a choice of which CUDA to buy,wether it be the Standard Blue R2, or a one-of-a-kinda Silver/Black Speedway Pal Edition R2...The discerning Barracuda enthusiast always acquires both
--> 12th scale Information Source <--
"Men do not quit playing because they grow old; they grow old because they quit playing."
― Oliver Wendell Holmes Jr.
Old 08-20-2003, 08:26 PM   #3868
Nice Dave!
I think the girls from your redbull pic are a bit hotter though
Old 08-20-2003, 08:28 PM   #3869
You guys be the judge
(this was another one of RBF's pics in a different thread)
Old 08-20-2003, 08:36 PM   #3870
Is it just me, or are there alot of Hotties at the track lately
WTB Alex Racing Barracuda R2 & R3 Funkymojo R/C Items: Wanted to Buy 3 02-03-2007 01:00 PM
alex racing barracuda con81 Electric On-Road 1 12-14-2005 03:36 AM
WTT: Alex Racing Barracuda R2 for PS2 AZ_Ron Other Items: For Sale/Trade or Wanted to Buy 0 02-13-2005 07:30 PM
Alex Racing Barracuda R3-New. rcracing1973 R/C Items: For Sale/Trade 9 04-11-2004 08:29 AM
Alex Racing Barracuda Bugs Bunny Singapore R/C Racers 6 01-22-2003 11:47 PM
