Barracuda from Alex racing >
Like Tree1Likes
Old 08-17-2003, 04:48 PM
  #3811
JDM_DOHC_SiR's Avatar
Trader Rating: 31 (100%+)
Originally posted by Ko Racer
yo bro thanks . have you tried the different rayspeed bladders?
Hit Redbull..up he has done more testing with them I think.
-Dave
JDM_DOHC_SiR is offline
Old 08-17-2003, 04:49 PM
  #3812
BTW KO...did you sell the CE-4 yet..??
Old 08-17-2003, 04:51 PM
  #3813
Followed a bit of thsi thread as I find the Cuda R2 a very intriguing car and am considering getting one. I saw some posts with regards to a "web special" with regards to the Cuda and I am curious what exactly this kit is and where it can be obtained? Curious from any that run the Cuda on tight Ozite indoor tracks with rubber what they think of the cars handling.
Fasttrak is offline
Old 08-17-2003, 04:55 PM
  #3814
Regional Moderator
I still have it!
Ko Racer is offline
Old 08-17-2003, 04:56 PM
  #3815
Regional Moderator
speedtech R/C has the barracuda . and i have ran my on carpet but with foams and it handle really well.
Ko Racer is offline
Old 08-17-2003, 11:20 PM
  #3816
R/C Tech Elite Member
Randy Caster's Avatar
Trader Rating: 47 (100%+)
Well if you had noticed .. the shock body is rather long and when you compress the shockall the way..it hits all the way when the chassis is touching also....so running the shorter bodies will allow the rear to have more travel when the chassis is lower... hence the car doesn`t get crudy handleing when the cshock is compressed..
I have this done to all my R2`s
a must do if your serious...
-Dave
Glad to learn that trick, I'll have to change the cars over..
Randy Caster is offline
Old 08-17-2003, 11:21 PM
  #3817
hmmm
Randmans R2 Pinky now has a full RS Pision set with a few mods hehehe
there are 2 models of RS pistions now too hehehe
-Dave
The HPI pistons have a little bit of up/down play, so hopefully the RS pistons will be a tight fit...
Old 08-17-2003, 11:23 PM
  #3818
Sorry, the Web Special is extinct now, only 100 kits were made... It is basically a regular R2 with a flipped chassis, and a bundle of hopups, anodized orange.
Old 08-18-2003, 02:36 AM
  #3819
You can now say no more Web SPecials and No more web Special PAL drive systems too ...
-Dave
I wounder where the last one went....hmmmmm
Old 08-18-2003, 02:45 AM
  #3820
TC3
TC3's Avatar
up/down play
why didnt anybody tell me that, before i orderd them
TC3 is offline
Old 08-18-2003, 02:59 AM
  #3821
Originally posted by TC3
up/down play
which HPI pistons did you order...if you ordered the All gray ones then yes you will have a "slight" bit of plat....I don`t use these....
but the Other Hpi Piston set that comes with the white and black pistons are the ones you want...they fit perfect..
HPI parts #72210..... thats the one you need and you`ll need 2 sets of them.
-Dave
Old 08-18-2003, 03:46 AM
  #3822
TC3
TC3's Avatar
-Dave
i orderd the grey ones #6818
TC3 is offline
Old 08-18-2003, 03:50 AM
  #3823
TC3
TC3's Avatar
argh, i cant finde the #72210 in the hpi list
what size are the piston holes of this set?
TC3 is offline
Old 08-18-2003, 04:25 AM
  #3824
TC3
TC3's Avatar
found a pic...
which one do u use?
TC3 is offline
Old 08-18-2003, 05:04 AM
  #3825
found a pic...
which one do u use?
the Black ones
1.1mm
-Dave
Copyright İ 2018 MH Sub I, LLC dba Internet Brands. All rights reserved. Use of this site indicates your consent to the Terms of Use.
