Barracuda from Alex racing >
Like Tree1Likes
Old 08-17-2003, 08:08 AM
  #3781
Regional Moderator
Originally posted by JDM_DOHC_SiR
Sorry Joseph..
I`ve been a little busy... I`ll get back to you soon..
-Dave
just wondering your choice of springs rayspeed red and white
will take care of the cuda needs?
Ko Racer is offline
Old 08-17-2003, 08:13 AM
  #3782
JDM_DOHC_SiR's Avatar
Trader Rating: 31 (100%+)
Red`s up front and whites in the rear...and they work with long~short arms very well all you have to do is mess around with the oil..
-Dave
JDM_DOHC_SiR is offline
Old 08-17-2003, 08:15 AM
  #3783
Regional Moderator
-Dave
thanks bro that is what i needed to know have you ran the same all around?
Ko Racer is offline
Old 08-17-2003, 08:22 AM
  #3784
Yes I have run the Reds all the way around...but the rear was a little to loose for m liking ..but that was with a 300M and a Dodge 2.0....you might want to try the ALFA 2.0 or the new ALex bodys....also I wouldn`t go thicker than 40 weight with a 1.2mm pistion..
-Dave
Old 08-17-2003, 08:42 AM
  #3785
Regional Moderator
-Dave
thanks for the info
Ko Racer is offline
Old 08-17-2003, 09:18 AM
  #3786
R/C Tech Elite Member
Randy Caster's Avatar
Trader Rating: 47 (100%+)
Are the Rayspeed spring tensions anywhere close to the alex tensions?
Randy Caster is offline
Old 08-17-2003, 10:30 AM
  #3787
RedBullFiXX's Avatar
Trader Rating: 34 (100%+)
dave ........ do you like one over the other? and have you used the rayspeed springs on your speedway pal? so if a person goes with rayspeed you say red (soft) white(hard) and that should take care of it for the cuda? have you tried there bladders ?
thanks for the info you have a PM also
Hey KOR, I've trie the Rayspeed bladders, I think they're just too thin on the sealing lip, the std Yokomo is a better fit.
RedBullFiXX is offline
Old 08-17-2003, 10:48 AM
  #3788
Could the bladders be done with the standard cap? You could make a tighter seal, and run whatever bladder you wanted...
Old 08-17-2003, 10:57 AM
  #3789
Never thought of that, so I just took at a look, and nope, wrong shape inside the cap, the std plastic cap relies on an o-ring seal on the shock body, the top of the cap is is a tapered chamber, no surface to seal against.
Old 08-17-2003, 11:01 AM
  #3790
Herminator's Avatar
I don't think the standard cap would work very well as along with the blader there is the foam pad that needs to sit flat between the bladder and cap, the standard caps would give the right seating or spacing for the foam.
Dave- are the Rayspeed springs the same size as Alex Racing springs? or are they slightly longer meaning low ride height is tricky to get?
Do you ever run on rough tarmac or low grip surfaces? or can you get away with the red and white because most places are nice high grip and smooth tarmac/ carpet?
don't suppose you have a chart of their springs with rates in GF/mm
Herminator is offline
Old 08-17-2003, 11:11 AM
  #3791
If you really want to test with the rayspeed bladders, all you have to do is take the part of the cap that threads onto the body to a belt sander, take maybe .3mm off the bottom of it, and you should be able to get a tight seal...
Old 08-17-2003, 11:15 AM
  #3792
Of course that is an option, I thought of that too, but honestly there doesn't seem to be as much tuning in that area as I thought there would be. It would be interesting tho try the Rayspeed pistons though
Old 08-17-2003, 11:33 AM
  #3793
I'll be trying the rayspeed pistons in about a week and a half
Old 08-17-2003, 12:41 PM
  #3794
The Rayspeed pistons won't fit on the R2 shafts. The RS piston are thicker by ~.4mm and the diameter it longer by ~.1mm. If you still want to try the RS pistons, you can try putting them on Yok shafts.
Headbanger is offline
Old 08-17-2003, 12:44 PM
  #3795
Thanks for the Heads up, HeadB
