Old 11-12-2002, 03:45 PM   #361
According to Alex racing site, beginning to middle of Dec.
Conversion kit will be out middle of this month.
17800 yen.
Major difference between Pal and Alex version is position of
battery and motor. It is opposite, Pal version is like TC3. Also design of main and upper deck is different. upper deck does not connected with steering linkage so that when upper deck is flexing, it does not affect steering. Other hop ups, aluminum battery holder spelled "PAL", aluminum
center shaft holder, double front one way(heavy duty), adjustable dumper units.
Hope these helps.
DoCoMo is offline   Reply With Quote
Old 11-12-2002, 05:18 PM   #362
jayhaya- thanks for your reply....do u have any idea where i could order the barracuda online for a good price??so far i have only check with a Japanese store and was quoted 39800yen about US$330 for the normal barracuda not the R2 which i think is kind of a high price for the kit
thanks again
fReShJiVe is offline   Reply With Quote
Old 11-12-2002, 06:00 PM   #363
I think people in this forum has mentioned Hong Kong outlet in the past.
http://controlcentre.rctech.net
http://shopping.rcmodel.com.hk/eshopping/default.htm
Usually shipping is around $20-30 to US.
I think Rainbow Ten is a only outlet that I know in Japan.
Usually they are retail price.
Good luck.
Old 11-21-2002, 01:28 PM   #364
I am selling my Barracuda PAL version.
www.rctech.net/forum/showthread.php?s=&threadid=9839
Thanks,
J
Old 11-21-2002, 01:45 PM   #365
JDM_DOHC_SiR's Avatar
Trader Rating: 31 (100%+)
Talking 1 more PM
Ȼ4.5 Centro+α ◊ TRF 501ӽ ◊ TRF 502ӽs ◊ TRF 503 ◊ TRF 511 ◊ TRF 201ӽr ◊ TRF 211ӽ
B5m ◊ T5m ◊SC5m ◊ B64deez nutz
Speedway PAL ◊ SDRC ◊ Shop UFO ◊ SMC
JDM_DOHC_SiR is offline   Reply With Quote
Old 11-22-2002, 01:07 PM   #366
types of SUSPENSION ARM
Wich is the diferrence betwen the two types of suspension arms from Comet:
6505 BARACCUDA HARD SUSPENSION ARM
6110 BARACCUDA SUSPENSION ARM
The last one is the same that comes with the car, the other one is nore strong??? dois it come like the original ones (1 fron 1 rear)???
Do you think that the stabilizer is a must?? wich one soft, medium or strong.
Which are the bests inserts for the sores 28???
Thank a lot.
martinm is offline   Reply With Quote
Old 11-22-2002, 01:46 PM   #367
Wink Sorex 28's
I use Hpi Red inserts with Sorex 28's really good in the winter..
As far as the sus arms go.... . the 6505's must be new..?? But I would get those if they are Harder.. the arms that come stock with the Barracuda ...are to flexable.. ...I never did use them... I use the Square front and rear arms that are pretty "BEEFY" but they also cost a grip ... But now Speedway PAL has a short arm coversion that uses the Graphite CE-4 sus Arms that are next to indistructable which is about the same price as the Sqaure Nylon arms....
And for the stabilizers...
it might be a Track by Track thing but I use 1.4mm ones up front and 1.2 in the rear... with 40W oil up fron and 35W oil in the rear...But then again I have a local track with a Sh!t load or switch backs..
Good luck
-Dave
Old 11-24-2002, 06:53 PM   #368
Is there a conversion kit out there for the Barracuda where the A arms are mounted with pins instead of the original ball studs?
mandy is offline   Reply With Quote
Old 11-24-2002, 07:35 PM   #369
Diva's Avatar
Send a message via Yahoo to Diva
Wink
Sure.
Diva is offline   Reply With Quote
Old 11-25-2002, 02:10 AM   #370
Talking These Short arms
These are the PAL Short arms.... (or CE-4 arms hehe )
Old 11-25-2002, 06:17 AM   #371
Diva how much are those arms? Who is the manufacturer? What are the handlings like compared to ball studs?
JDM_DOHC_SiR do these arms have droop screws holes?
Old 11-25-2002, 06:49 AM   #372
Diva's Avatar
send me a pm and I'll give you a quote.
Old 11-25-2002, 07:11 AM   #373
Talking These arms are tough!!
Much improved over the arms that come with the Barracuda kit.. ..THey came of the ALex CE-4 Peace Ark..but they are the carbon ones which are tough as "SH!T". Good buy if you own a Barracuda.. But they don't have droop screw holes ....small price to pay for durability
Old 11-25-2002, 05:42 PM   #374
Thanks Diva. I think I'll take it that the kit costs around US$85 as quoted by Ko Racer.
Thanks JDM_DOHC_SiR. I didn't like the original Barracuda soft A arms. The droop screws warp the A arms. I tried the carbon A arms then the movement became gritty even with used ball studs. Damn. I thought the solution could be this kit where pins are used instead of ball studs. But now you tell me there are no droop screw holes. Can we drill droop screw holes? Just a thought.
Old 11-26-2002, 04:55 AM   #375
Talking Droop screws on Speedway PAL arms
It should be no problem to drill holes for the droop screws.. but it will be a tight fit but should work
WTB Alex Racing Barracuda R2 & R3 Funkymojo R/C Items: Wanted to Buy 3 02-03-2007 01:00 PM
alex racing barracuda con81 Electric On-Road 1 12-14-2005 03:36 AM
WTT: Alex Racing Barracuda R2 for PS2 AZ_Ron Other Items: For Sale/Trade or Wanted to Buy 0 02-13-2005 07:30 PM
Alex Racing Barracuda R3-New. rcracing1973 R/C Items: For Sale/Trade 9 04-11-2004 08:29 AM
Alex Racing Barracuda Bugs Bunny Singapore R/C Racers 6 01-22-2003 11:47 PM
