Barracuda from Alex racing >
Like Tree1Likes
Old 08-07-2003, 09:48 AM
  #3631
rc-zombies's Avatar
Originally posted by Randman
In the mood to adopt a son? I could go for an SL55AMG
I ask first, last year on the HPI PRO3 forum...
On the SD axles... Yes they will fit the R2.
front axles... no mod is neccessary...
Rear axles... must change to same diameter bearings and thickness. The sd bearings are thinner...they can be used but you'll have to add about 1mm of shims on each side of the bearing.
MIP CVD's will not work on the front (I'll have to double check the fit )... on the rears yes. just have to fine 42mm dogbones.
rc-zombies is offline
Old 08-07-2003, 10:11 AM
  #3632
R/C Tech Elite Member
Randy Caster's Avatar
Trader Rating: 47 (100%+)
I was hoping the SD axles would fit. Now it's time to make an order with Square
Thank You RC Zombies!
Randy Caster is offline
Old 08-07-2003, 10:12 AM
  #3633
Herminator's Avatar
KO radios have been found to be really quite badly tuned from the factory. Since you're in the UK go to rcracechat.com and PM a guy called Marcus Goultier on there, he's a mod and he tuned my radio for me, he works at a tv/radio place so has all the frequency equipment. Will also check your crystals, found one of my pairs was useless.
Herminator is offline
  #3634
rc-zombies's Avatar
just make sure you change out the rear bearings...
Old 08-07-2003, 10:21 AM
  #3635
Definately
Old 08-07-2003, 10:39 AM
  #3636
Maj. Teeth's Avatar
Yeah, and the last time you came to visit Southern California, I had a gigantic Guests house with 2 master bedrooms all tidy up and my 2002 Escalade waiting for your arrival, plus three XRAY and all to needed pit items for your to use but you didn't show.
Even told my wife Ramon was coming and to take your wife shopping at Redeo Drive.
oh well, we'll do it one of these days.
Dan
Maj. Teeth is offline
Old 08-07-2003, 10:48 AM
  #3637
rc-zombies's Avatar
Dan
geeze... I knew I should've cancelled my Disney trip. Should have visited you instead.. Mickey Mouse will always be there for my son..
I'll go broke if you take my wife to Rodeo Drive. Take her to Ross..
Definately one of these day... for sure...
Old 08-07-2003, 10:52 AM
  #3638
Maj. Teeth's Avatar
Default Built!
Ok, the car is built and is in the break-in process. Speaking of the break-in process, the whole drivetrain is noisy. Now, I do understand that a shaft car is noisy and being an R2 is one of the noisiest of the group, but this thing is down right loud! I'm just curious if this is right or is it cause by the stock 72t spur? I already did the light sanding down process of the bevel and large gears.
I need to know that shimming process your all talking about so to quite it down a bit. Also, what size spur gears are ya'll running?
Daniel
Old 08-07-2003, 10:54 AM
  #3639
Maj. Teeth's Avatar
You've got the doors wide open senior! always.
Dan
  #3640
Maj. Teeth's Avatar
Default Built Picture
Ok, the car is built and here's my proud low resolution picture.
Old 08-07-2003, 10:56 AM
  #3641
Regional Moderator
looking at your picture you have your wheels hexes wrong if look at page 18 it shows the one with the groove in it on the front and the solid non groove on the back
Ko Racer is offline
Old 08-07-2003, 10:58 AM
  #3642
rc-zombies's Avatar
Default Re: Built!
Daniel
Very Nice Dan...
I'll probably be done with mine tonight... shocks are all that is left.
I just noticed the tick marks on your turnbuckles... they should all be facing the same direction. either left or right...makes adjustments alot easier...
  #3643
Maj. Teeth's Avatar
Thanks KO, thats an easy fix. Man! you got some sharp eyes!
Dan
Old 08-07-2003, 11:00 AM
  #3644
Regional Moderator
Dan
thats what us cuda drivers are here for
Ko Racer is offline
Old 08-07-2003, 11:16 AM
  #3645
John_S's Avatar
Thanx hermi i might just do that
John_S is offline
