Barracuda from Alex racing >
Like Tree1Likes
Old 08-03-2003, 06:59 PM
  #3436
R/C Tech Elite Member
Randy Caster's Avatar
Trader Rating: 47 (100%+)
Default Re: Center One way or not?
Originally posted by Maj. Teeth
Ok, a quick question for you guys. My kit came with the center one way as well as the stock shaft. My question is, should I install the center one way as oppose to the stock? what are the benefits of this?
Dan
The center 1 way is something I havent tried yet, havent found a need for any more steering on the car. It's another thing to test with though..
Randy Caster is offline
Old 08-03-2003, 08:11 PM
  #3437
Maj. Teeth's Avatar
Wow! if thats the case, I'd definately want to install and try it.
I just built the diff with the ceramic balls and thrust balls that came along with it and it is soooooooooooooooo smooth. Now all I got to do is go down to Speedtech RC and buy another input gear because I broke one trying to clamp it with my needlenose like the instruction said. Question is, how the heck do you insert that through the second bearing? since there aren't really room to clamp it to begin with. The picture looks like the needlenose clamps after the 1st bearing but in reality, there aren't any room so I had to clamp it from behind the 1st bearing. The first one went in ok, but the second one snapped. Sucks!
Dan
Maj. Teeth is offline
Old 08-03-2003, 08:26 PM
  #3438
I used really long thin pliers to do the second bearing. Check your PM though.
Old 08-03-2003, 08:35 PM
  #3439
btw, where the heck did everyone go, ko and jdm havent posted today..
Old 08-03-2003, 09:06 PM
  #3440
Maj. Teeth's Avatar
Thanks. Got it.
Dan
Old 08-03-2003, 09:17 PM
  #3441
racer's Avatar
is there any need to add ball diff grease if you are using ceramic bearings?
racer is offline
Old 08-03-2003, 09:26 PM
  #3442
Yes, they still need lubrication to make the rings last.
Old 08-03-2003, 10:12 PM
  #3443
I also have a brand new bearing set for the R2. Came with my web special, PM if interested...
Old 08-03-2003, 10:43 PM
  #3444
NMRCDude's Avatar
RM, so your Pinky will be your main car then? Sounds like your not going to run your Web Special? Or is it saved for brushless.
NMRCDude is offline
Old 08-03-2003, 10:59 PM
  #3445
The pink car is going to be brushless, it will be my main car. The web special will be saved mainly for stock racing, which I'll do at big events, and I'll switch out the pink car to modified for those events. Just want to keep my web special as new as I can.
Old 08-04-2003, 09:48 AM
  #3446
JDM_DOHC_SiR's Avatar
Trader Rating: 31 (100%+)
You Rang.?
-Dave
JDM_DOHC_SiR is offline
Old 08-04-2003, 10:10 AM
  #3447
It was awful wierd not seeing you posting for the weekend, you can't take your R2 greatness away from us like that for such long periods
  #3448
And also, my Blue R2 has been sold. Dave has 1 more car he can add to his collection
Old 08-04-2003, 10:15 AM
  #3449
Regional Moderator
your not talking about dave on the other side of the pond are you
Ko Racer is offline
Old 08-04-2003, 10:20 AM
  #3450
Can you say Project car hehehehe
-Dave
