Old 07-24-2003, 04:28 PM   #3151
JDM_DOHC_SiR's Avatar
Trader Rating: 31 (100%+)
Originally posted by RedBullFiXX
Dave: While I have run springs that "STIFF" before, it was only in a really high bite situation. I am sure you have that type of surface too, but for Herm the std springs (1.4x6.00) should be closer dontcha think
......But if he runs the 1.2 mm pistions then its a whole different ball game them then the stiff springs act different than they would on the stadard 1.0mm pistion......
then again you run the #2 HPI pistion which is around 1.1mm I still think that he would be ok with the 1.5 spring range.... I also run at a mid grip outdoor track and I find that the 1.5 springs work the best..
-Dave
Ȼ4.5 Centro+α ◊ TRF 501ӽ ◊ TRF 502ӽs ◊ TRF 503 ◊ TRF 511 ◊ TRF 201ӽr ◊ TRF 211ӽ
B5m ◊ T5m ◊SC5m ◊ B64deez nutz
Speedway PAL ◊ SDRC ◊ Shop UFO ◊ SMC
JDM_DOHC_SiR is offline   Reply With Quote
Old 07-24-2003, 04:31 PM   #3152
Originally posted by Herminator
From that I can tell Dave was way out although if he had said 1.4 in that range he would of been more or less correct
Read again young one....if you look closer I Said 1.5 spring "IF" you use the 1.2mm pistion and not the stock 1.0mm pistion
-Dave
Old 07-24-2003, 04:38 PM   #3153
Herminator's Avatar
Send a message via ICQ to Herminator
I still don't see me needing to go that hard even with a larger piston hole. I've seen very few cars ever go that hard around here, our tracks are generaly not used nearly enough to get lots of grip into them, most have a few bumps and it's rarely hot.
Young one I suppose I am to you, old man
Herminator is offline   Reply With Quote
Old 07-24-2003, 04:57 PM   #3154
-Dave
Old 07-24-2003, 05:00 PM   #3155
well at least try the upper 1.4 range...the car really sticks well with a stiff set up...with the Long Arms
I have to post the set up soon because I tried this set up on a med~low bite outdoor track and it worked rather well
-Dave
Old 07-24-2003, 05:07 PM   #3156
Herminator's Avatar
-Dave
Yep will do, was thinking of going for all 1.4's upto the hardest and then one softer than kit for when I move indoors. SO 8pairs instead of 12, should be able to afford that along with a transponder mount and a few more spare bits.
Not sure if I'll be able to afford my second Cuda for quite a while may need to spend money on a big car, my Mk2 VW Polo is running well for a car thats over ten years old but sometimes I just get too fed up with it's complete lack of power and terrible brakes, not to mention it's a granny car then again it still gets me from A to B in reasonable time, heavy shoes you see
Old 07-24-2003, 05:15 PM   #3157
mand I used to have a MK2 GTI Golf with a VR6 Engine swap.. back when I was in California in 95~98..fun car...but I love my Honda now
-Dave
Old 07-24-2003, 05:23 PM   #3158
Herminator's Avatar
-Dave
Hehe that would have been a beast, unfortunatly insurance for me is stupid, my Polo has an almighty 1 litre petrol engine, can get the wheels to spin if it's wet though might be something to do with the wheel barrow tyres it has though
Would like a Honda Civic but it used to be an old persons car but is now popular with young people and insurance has been driven up accordingly now looking at a Seat Cordoba, part VW so fairly solid, infact the chassis is a mk2 Jetta chassis, ie. mk2 golf with a boot
Old 07-24-2003, 07:43 PM   #3159
Randy Caster's Avatar
Trader Rating: 46 (100%+)
-Dave
Please do post your setup. I'll be running the Hitec race next Saturday, and it sounds like a similar track.
Old 07-24-2003, 11:34 PM   #3160
Default Alternative Springs
I whipped out my digital calipers and did some measuring. 'Cuda springs are 13.9(i.d.) x 22.5. Yokomo springs are exactly the same size as 'cuda springs (anyone surprised?). Xray springs measure 13.4x26mm. The I.D. is just slightly smaller and ~3mm longer. With the 'cuda springs, I have about 6mm of preload space, so the Xray springs will fit. Rayspeed springs should fit, too.
Headbanger is offline   Reply With Quote
Old 07-25-2003, 12:20 AM   #3161
RedBullFiXX's Avatar
Trader Rating: 34 (100%+)
El Randman....Try the RROC setup should be pretty close being out doors and all....and don't forget to tighten everything
--> 12th scale Information Source <--
"Men do not quit playing because they grow old; they grow old because they quit playing."
― Oliver Wendell Holmes Jr.
Old 07-25-2003, 12:40 AM   #3162
Default How to use those uncentered ball studs?
I measured my rear toe-in and it came out 4 degrees?!? Can someone tell me how to use those uncentered ball studs?
Old 07-25-2003, 12:53 AM   #3163
Fatboy Joe's Avatar
Default Re: How to use those uncentered ball studs?
What I know is you need to turn them in a certain direction to achieve your desired rear toe-in. Although, i don't know how less toe-in you can achieve with them. Maybe the others like JDM_DOHC_SIR or RBF can help
Fatboy Joe is offline   Reply With Quote
Old 07-25-2003, 06:21 AM   #3164
there are little indentations on one side of the offset 6.8mm balls... on the forward arms have this mark poiting forward...and then on the rear you can just look at the arms to see the "about" adjustment you are making..
-Dave
Old 07-25-2003, 08:39 AM   #3165
That will be my first setup.
I bought a gallon of loctite, I figure if I let the car sit in it overnight, I shouldn't have any screws fall out
WTB Alex Racing Barracuda R2 & R3 Funkymojo R/C Items: Wanted to Buy 3 02-03-2007 01:00 PM
alex racing barracuda con81 Electric On-Road 1 12-14-2005 03:36 AM
WTT: Alex Racing Barracuda R2 for PS2 AZ_Ron Other Items: For Sale/Trade or Wanted to Buy 0 02-13-2005 07:30 PM
Alex Racing Barracuda R3-New. rcracing1973 R/C Items: For Sale/Trade 9 04-11-2004 08:29 AM
Alex Racing Barracuda Bugs Bunny Singapore R/C Racers 6 01-22-2003 11:47 PM
