Old 07-23-2003, 03:11 AM   #3106
Herminator's Avatar
Send a message via ICQ to Herminator
Still going through spur gears, hmmm...
I went through a few when I first got my cuda but have been able to get the last couple to last around a month each. I think you need to tighten up your chassis better when rebuilding it. I leave all the bottom screws that go into the bulkheads slightly loose so the bulkheads are free to move. Then put the top deck screws in the same. Spin the drivetrain a little by hand and go around the top deck screws tightening them a little at a time, doing one at the front end of the car then one diagonaly opposite on the rear of the car, so on and so on. Then once all the top deck screws are done I do the bottom chassis the same way, making sure it's always on a flat surface. With alloy shaft holders you should be getting more than a day out of a spur when racing stock. Maybe you're over tightening the spur gear screws a bit too, I found I warped my kit spur gear from overtightening, and I don't have the strongest of hands, far from it.
Herminator is offline   Reply With Quote
Old 07-23-2003, 07:46 AM   #3107
JDM_DOHC_SiR's Avatar
Trader Rating: 31 (100%+)
Default Re: Long Arm Setup
Originally posted by RedBullFiXX
Dave:
Its good to hear your running the R2 as it should be
Get that bad boy dialed & we can swap setups. Heh, my car is good, really good, but we can help each other to make them even better
SUre I`ll be glad to share my set ups with you heheheh
I also Have a really Hot Set up that works on a high bit track( my local one ) with the PAL Hubs !!
Once again I was able to better my best lap and my times are way faster to.....
I`ll post the weird Long Arm set-up here in the Morning..
-Dave
Ȼ4.5 Centro+α ◊ TRF 501ӽ ◊ TRF 502ӽs ◊ TRF 503 ◊ TRF 511 ◊ TRF 201ӽr ◊ TRF 211ӽ
B5m ◊ T5m ◊SC5m ◊ B64deez nutz
Speedway PAL ◊ SDRC ◊ Shop UFO ◊ SMC
JDM_DOHC_SiR is offline   Reply With Quote
Old 07-23-2003, 07:49 AM   #3108
rocketron's Avatar
Trader Rating: 16 (100%+)
randman - on the spur gear issue on my brushless car i've not used a spur gear up (stripping ) for over 4 race days. RBF uses Robinson Machined Spurs and I'm using Kimbrough 48pt. Like mentioned prior you can overtighten the spur causing the whible - wobble effect this may contribute
the BL system seems to enjoy eating my oneway drive cups though THANKS! for the spares I'll get with steve later to replace them
rocketron is offline   Reply With Quote
Old 07-23-2003, 11:39 AM   #3109
Randy Caster's Avatar
Trader Rating: 46 (100%+)
Default Re: Re: Long Arm Setup
-Dave
I talked to Dave on the phone at SoCal last night, and he was saying you had an awesome setup, time to share, I want to see this
Old 07-23-2003, 11:45 AM   #3110
I'm going to go through the whole car and rebuild it. I dont know why it wouldn't go as fast as I wanted it to last night, when I would try to push it like I normally do, it would just break loose. I'll go through the transmission and re-align everything (although it is so free right now, spin the rear tires and it goes for about 12-15 secs!) I'm going to order the Kimbrough stuff from Steve, and I'll be sure not to overtighten it. Are you running 2 or 4 screws on the spur gear?
You were definately fast last night, did R2 owners proud No problem on the drive cups, glad they fixed your problem.
Old 07-23-2003, 11:54 AM   #3111
rocketron's Avatar
yeah a good maintenance of the car is a good idea - socal can be tough on cars. between high traction and concrete walls
i am using 2 screws on the spur - i have extra kimbrough spurs if you'd like to try one first
last nite my car was faster than the driver
Old 07-23-2003, 12:16 PM   #3112
Ron - If possible, could you pick me up a 70 tooth Kimbrough machined gear from Steve when you see him this week. I'll pay you back on Tuesday. I do regular maintenance on the car, but it's time for a complete teardown
Old 07-23-2003, 03:03 PM   #3113
Regional Moderator
ImGoinRCn's Avatar
Send a message via Yahoo to ImGoinRCn
Hi Dave and DJ...I am back from the dead...
When all else fails, aim for the quarter panel.
Several oval and off road vehicles
and a legend car nicknamed Kidney Stone.
X Factory R/C SCX-60CF
X Factory R/C X-6
ImGoinRCn is offline   Reply With Quote
Old 07-23-2003, 04:24 PM   #3114
Regional Moderator
R/C Tech Charter Subscriber
whats up heath baby? still running the cuda ? or did you go back to yokomo? you going to beat the heat in memphis?
Ko Racer is offline   Reply With Quote
Old 07-23-2003, 05:24 PM   #3115
WOw!! Welcome back buddy
-Dave
Old 07-23-2003, 05:26 PM   #3116
Herminator's Avatar
YAWN
hello
and soon it will be night night
Old 07-23-2003, 05:44 PM   #3117
Herminator's Avatar
Forgot I got these pics last week as I left, here's the new shell, done with good old cans and mounted on the fish.
Old 07-23-2003, 05:48 PM   #3118
Herminator's Avatar
Here's another shot, you can see my beautiful charger too and Nice KO tranny that should be arriving back here in the next couple days after a much needed recalibration. All on my manky pit towel, would love an ALex Racing pit towel but $30 I don't use a towel that expensive on myself
Old 07-23-2003, 05:53 PM   #3119
Herminator's Avatar
Last one, that cheapo tranny is not mine, honest it's my pitting buddy, he's spent more on cars in the last few months that I dare to count but he still uses el cheapo tranny
There are a few marks on the shell already that was after one run at Carlisle, I seemed to be magnetised wide at the emd of the striaght at the start of the day, went off there three times in three laps and had to go fetch the car myself each time, was too early for my brain to start driving I think
Old 07-23-2003, 05:58 PM   #3120
Looks good Hermi, how do you like the performance of the Alfa 2.0 body?
WTB Alex Racing Barracuda R2 & R3 Funkymojo R/C Items: Wanted to Buy 3 02-03-2007 01:00 PM
alex racing barracuda con81 Electric On-Road 1 12-14-2005 03:36 AM
WTT: Alex Racing Barracuda R2 for PS2 AZ_Ron Other Items: For Sale/Trade or Wanted to Buy 0 02-13-2005 07:30 PM
Alex Racing Barracuda R3-New. rcracing1973 R/C Items: For Sale/Trade 9 04-11-2004 08:29 AM
Alex Racing Barracuda Bugs Bunny Singapore R/C Racers 6 01-22-2003 11:47 PM
