Old 07-22-2003, 08:03 AM   #3091
Randy Caster's Avatar
Trader Rating: 46 (100%+)
xxxkat - The stock pistons have a really small hole in them, and they suggest using something in the range of 100-200wt oil. RBF found that using HPI #2 pistons will let you tune the car a little easier. If some of the other drivers are using 40wt oil, it would be a good place for you to start there. Much easier than finding the 100, or 200wt oils that the pistons are made for in Japan.
Old 07-22-2003, 08:52 AM   #3092
RedBullFiXX's Avatar
Trader Rating: 34 (100%+)
Originally posted by xxxkat
Small tight track,outdoors,asphalt.One question I do have is on the shocks,does the R2 need a stiff set up due to the location of the arm mounts ? right now I'm running 30wt all the way around and its like I'm using 100wt. I'm not sure what pistons are on the car(I bought the car used)What pistons should I be using?
XXX
Actualy with the very long arms a softer setup can be utilized with less chassis roll, this is one of the things I like most about the car, and also the thing that took the longest time to figure out.
The kit springs (1.4x6.0) are very soft compared with any other car out there. As El Randman said the piston holes are on the small side for the shock fluids we have in the states.
Try and find some of the HPI #2 pistons, or drill the holes out to 1.2mm. I use 40Wt Losi fluid.
For your tight track leave the standard springs on, move the shocks all the way out, top & bottom.
Droop 3mm fr & Fr
Ride Ht 5mm Fr & Rr
1/2 deg toe out Fr
Check Rr toe, should be 2.5 deg toe in (some kits were shipped with the wrong rear uprights 4 deg toe in)
And make sure to pickup a set of aluminum shaft holders, those along with the Robinson Machined spur gear will give you good durability with the drivetrain.
And remember to have fun, its not the destination....rather the journey that makes it worthwhile
--> 12th scale Information Source <--
"Men do not quit playing because they grow old; they grow old because they quit playing."
― Oliver Wendell Holmes Jr.
Old 07-22-2003, 08:56 AM   #3093
El Berger, what time do you think you'll be at the track today? I'm lookin at 1pm. Found a carpool, I'm gonna be riding with Intellegentsia to the track.
Old 07-22-2003, 09:08 AM   #3094
1ish El Cajones Randy
No El here in Hermosa
Old 07-22-2003, 09:12 AM   #3095
lol. Dont worry, I wont touch hermapherdite (sp?)
See you around 1.
Old 07-22-2003, 01:35 PM   #3096
Oasis's Avatar
Trader Rating: 36 (100%+)
I take it you guys race at so.cal?
Oasis is offline   Reply With Quote
Old 07-22-2003, 01:54 PM   #3097
John_S's Avatar
hi guys sorry to bother you but i am havin a bit of a setup problem and would apreciate any help im runin stock setup exept from the camber links are changed to longest and highest positions i race a stock 27 mvp motor with 70/24 gearing and race on a very slidy polished wood floor with shumacher yellow mini pins(the choice of tires for the track) and was still sliding all over the place even with the max traction setup and want to hook the car up a bit more even tho the laptimes where good i still feel they could have been faster
thanks for any help
John_S is offline   Reply With Quote
Old 07-22-2003, 02:18 PM   #3098
thanks for any help
John think like this ...
Go soft or Go Home
I think for the long arms it is best to run the mid camber link on the upper deck, and add a 2mm shim under the front links.
I have NEVER found the upper link position on the hubs to be of any value !
Use the kit springs or if you have the option in your case lighter springs should be better, you can judge this by the amount of chassis roll.
Old 07-22-2003, 02:45 PM   #3099
I agree. Use a lower camber link on the shock tower (or where ever it mounts) The higher you go, the more 'stiff' you make the car, ie... the roll center changes to not allow as much roll. Lowering the links will let more weight transfer, but the car may get kinda weird in the chikanes.
Pit Crew is offline   Reply With Quote
Old 07-22-2003, 04:01 PM   #3100
Herminator's Avatar
Send a message via ICQ to Herminator
I have also raced my cuda on a wooden floor using mini pins and COMPLETELY stock settings are the way to go, atleast for a start. You'll probably only want to make small changes to something like spring used on either end or shock mounting position, although I didn't change a thing in the few weeks left I had of the indoor season. If the car is sliding a lot try softer or no insirts, or get some narrow yellow mini pins. I find it's more an act of getting the car balanced rather than getting it to grip. And don't change things too quickly, with wooden floors the grip can change a huge amount in a very short space of time as the dust gets moved around.
Herminator is offline   Reply With Quote
Old 07-22-2003, 05:48 PM   #3101
JDM_DOHC_SiR's Avatar
Trader Rating: 31 (100%+)
Go soft or Go Home
Dave~man
Wait till you here about my set up that I am running with the long arms! it will totally blow you away on how it`s set up but man is it dialed
-Dave
Ȼ4.5 Centro+α ◊ TRF 501ӽ ◊ TRF 502ӽs ◊ TRF 503 ◊ TRF 511 ◊ TRF 201ӽr ◊ TRF 211ӽ
B5m ◊ T5m ◊SC5m ◊ B64deez nutz
Speedway PAL ◊ SDRC ◊ Shop UFO ◊ SMC
JDM_DOHC_SiR is offline   Reply With Quote
Old 07-22-2003, 07:59 PM   #3102
Regional Moderator
R/C Tech Charter Subscriber
Originally posted by JDM_DOHC_SiR
Dave~man
-Dave
ok dave share some info and send the pics when you get a chance i still havent got them
Ko Racer is offline   Reply With Quote
Old 07-22-2003, 09:39 PM   #3103
Default Long Arm Setup
Dave:
Its good to hear your running the R2 as it should be
Get that bad boy dialed & we can swap setups. Heh, my car is good, really good, but we can help each other to make them even better
Old 07-23-2003, 12:33 AM   #3104
Yep
Old 07-23-2003, 12:47 AM   #3105
Had a descent day at SoCal today. I couldn't get the car to work just like I wanted it to, the track was a little higher speed, and I work better on the tight twisty stuff. I was able to qualify 4'th in the pro stock A-Main, and after racing up to 2'nd place, I ended up tagging a corner dot which sent me back to 4'th where I finished. Still nothing broken except spur gears (which I did go through another one today) so I am really happy with the car still. I think part of the problem today was just me bieng out of it, had a really early morning, and I've been tired all day...
Hopefully next week I'll do better.
WTB Alex Racing Barracuda R2 & R3 Funkymojo R/C Items: Wanted to Buy 3 02-03-2007 01:00 PM
alex racing barracuda con81 Electric On-Road 1 12-14-2005 03:36 AM
WTT: Alex Racing Barracuda R2 for PS2 AZ_Ron Other Items: For Sale/Trade or Wanted to Buy 0 02-13-2005 07:30 PM
Alex Racing Barracuda R3-New. rcracing1973 R/C Items: For Sale/Trade 9 04-11-2004 08:29 AM
Alex Racing Barracuda Bugs Bunny Singapore R/C Racers 6 01-22-2003 11:47 PM
