Barracuda from Alex racing >
Like Tree1Likes
Old 07-07-2003, 07:35 PM
  #2761
R/C Tech Elite Member
Randy Caster's Avatar
Trader Rating: 47 (100%+)
BTW, thank you for posting the pics of your PAL cuda Dave, looks pretty close to the Web Edition minus the coolness of Orange!
Randy Caster is offline
  #2762
Herminator's Avatar
err, thought that was taking a long time to post, server go gaga.
lets try again....
Herminator is offline
Old 07-07-2003, 07:37 PM
  #2763
Herminator's Avatar
argh it won't work don't have webspace I can link a pic from either
Old 07-07-2003, 07:43 PM
  #2764
Herminator's Avatar
Old 07-07-2003, 07:44 PM
  #2765
Herminator's Avatar
fnaly got it to work, had to change format and made it a little small too.
Old 07-07-2003, 07:53 PM
  #2766
lol
Old 07-07-2003, 09:08 PM
  #2767
Dave: Waiting for your PM.
Tsubasa Sakai is offline
Old 07-07-2003, 11:00 PM
  #2768
Fatboy Joe's Avatar
Originally posted by JDM_DOHC_SiR
the posts are maid by the owner of speed way pal as a small favor.. and the battery strap is kind of a prototype thing that my friend was doing a while back...
-Dave
You're one lucky guy Anyway, I decided to use the battery straps of the new Yokomo SD, I installed them last night and had to grind abit on the straps to make a perfect fit. It's a pretty cheap alternative, cost me around YEN720.
Fatboy Joe is offline
Old 07-07-2003, 11:45 PM
  #2769
Damn. I just got done balancing 2 tires, it took me like 40 mins to get them perfect, I dont know how I am gonna do that to 20 more pairs without going insane. I bought a prop balancer that you hang a shaft between 2 magnets, then put the wheel on that shaft. Even with an unbalanced tire you can spin it for about 5 mins, wish my bearings could do that. I start by putting some CA on the light side of the wheel, then using zip kicker to rapid dry it. Do that as much as I can, then shave away at the heavy side of the wheel with an X-Acto. It was a bitch, but since I'll be running stock, every little thing makes a difference.
Old 07-08-2003, 12:01 AM
  #2770
ROBORAT's Avatar
Originally posted by Fatboy Joe
ROBORAT: I think they retail for U.S.$82.50 at Speedtech but they are always out of stock. I'll be having them soon together with the kits. I can't sell the R2 kits without the PAL System in stock because most of the guys in Manila like to go Mod all the time and that includes you, hehehehe
FBJ: thanks. just weighing the pros and cons of each of the cars available to me here locally - including cost. as you know im in search for a 2nd kit for TC (am not at all considering letting go of the losi). of cors in the process i might as well try something new since tried most of the others already. that would mean my choices will be the Yok-SD, Barracuda, or the Assassin ... Pro4 will be another to consider although that seems to be a bit down the road in terms of a release date.
ROBORAT is offline
Old 07-08-2003, 09:12 AM
  #2771
JDM_DOHC_SiR's Avatar
Trader Rating: 31 (100%+)
NO Problem ..Randy
-Dave
JDM_DOHC_SiR is offline
Old 07-08-2003, 09:18 AM
  #2772
Disney's Avatar
Thumbs up
thank you"""
Disney is offline
Old 07-08-2003, 09:34 AM
  #2773
I already gave the Yok SD a shot, and although it is very fast, the R2's durability is much better. I'm pretty sure both cars will handle similarly, so why not get the one that will break less parts?
Old 07-08-2003, 06:54 PM
  #2774
Hahhahahaah Good Picture Hermi`
-Dave
Old 07-08-2003, 07:13 PM
  #2775
Is that your home track Dave, or just a pic you came across?
