Old 07-01-2002, 05:04 AM   #226
My Bar
jenny is offline   Reply With Quote
Old 07-01-2002, 05:06 AM   #227
The small Futaba S9550
Old 07-01-2002, 05:07 AM   #228
A few more shots from different angles
Old 07-01-2002, 05:11 AM   #229
Same same same
Old 07-01-2002, 05:12 AM   #230
Gear box
Old 07-01-2002, 05:12 AM   #231
Gear box.
Old 07-01-2002, 09:04 AM   #232
rcruv's Avatar
Nice pictures.
Why did you raise the camber link?
rcruv is offline   Reply With Quote
Old 07-01-2002, 10:17 AM   #233
Alvin's Avatar
educated guess: it will lower the roll centre of the car, in effect giving more rear traction?
Alvin is offline   Reply With Quote
Old 07-01-2002, 10:08 PM   #234
rcruv's Avatar
Isn't it the other way around?
What about having less camber change for more traction in the corner?
Jenny, time to come out and say something.
Old 07-02-2002, 07:50 AM   #235
Alvin's Avatar
well longer links/less angled links will give more roll, and less camber change.
Old 07-02-2002, 07:51 PM   #236
I've also increased the camber links length. This gives less camber changes when the shocks are compressed. Raising the camber links alone won't give less camber changes. My camber links now sit almost horizontal when the rear tires are at neutral position (with batteries) with a ground clearance at 7mm.
If at neutral position the camber links incline (outside higher than inside), the camber changes will be more than if they were horizontal at the start. During the summer season the track is much grippier. We've used a grade thicker oil and slightly stiffer springs. There really isn't all that much shock travel and roll anyway. You don't need that extra increased camber when the shocks are compressed. You have to try it out. The stock setting could be right for you already.
Old 07-02-2002, 08:17 PM   #237
rcruv's Avatar
It's for large outdoor track?
I thought the stock camber link was already too long. I actually moved to bottom hole in the front c hub which gave better overall result indoor small technical track.
Upper hole was way lazy to drive.
Has any of you tried shorten the camber link and/or more ackerman (making and moving to inner hole on front knucks)?
Maybe I'm used to TC3's sharp steering too much.
Old 07-03-2002, 03:31 PM   #238
Matt Howard's Avatar
Well I just ordered my red barracuda. how long does it take them to ship stuff to california?
Matt Howard is offline   Reply With Quote
Old 07-04-2002, 09:48 AM   #239
rcruv's Avatar
Mine took only 3 days to So Cal from HK.
I was quite surprised, 'cuz I expected at least a week or so.
Post your pictures when you get that.
Old 07-06-2002, 12:32 PM   #240
Macky's Avatar
R/C Tech Charter Subscriber
Send a message via AIM to Macky Send a message via Yahoo to Macky
Here's some pictures of mine.
Macky is offline   Reply With Quote
WTB Alex Racing Barracuda R2 & R3 Funkymojo R/C Items: Wanted to Buy 3 02-03-2007 01:00 PM
alex racing barracuda con81 Electric On-Road 1 12-14-2005 03:36 AM
WTT: Alex Racing Barracuda R2 for PS2 AZ_Ron Other Items: For Sale/Trade or Wanted to Buy 0 02-13-2005 07:30 PM
Alex Racing Barracuda R3-New. rcracing1973 R/C Items: For Sale/Trade 9 04-11-2004 08:29 AM
Alex Racing Barracuda Bugs Bunny Singapore R/C Racers 6 01-22-2003 11:47 PM
